Mijailović P. 3431 Posted August 26, 2013 Teraj kod majstora da skida alnaser/anlaser , kako god. Quote Share this post Link to post Share on other sites
Gusar 4 Posted August 26, 2013 anlaser krepo vervatno samo biksne da se nabiju nove... pola sata posla... Quote Share this post Link to post Share on other sites
Milos1 43 Posted August 26, 2013 (edited) Hvala puno na brzim odgovorima,posto imam kanal probacu da ga sam skinem,najbolje onda da promenim bixne i cetkice ako ga vec rasturam,pa da bar to eliminisem. Pozdrav! Edited August 26, 2013 by Milos1 Quote Share this post Link to post Share on other sites
Gusar 4 Posted August 26, 2013 pazi samo da kad budes vracao sve na mesto ne zaboravis zicu od pobudne struje na anlaseru... Quote Share this post Link to post Share on other sites
Pelemasca 0 Posted September 4, 2013 imam slican problem kao kolega Milos iznad.... auto 1.6 benzinac nece da zavergla,samo shkljocne tras tras vratim kljuc pokusam o5 i on upali,nekada se desava da 2-3 puta nece i onda uspem... znaci da proverim te bixne???!!!! Quote Share this post Link to post Share on other sites
Mijailović P. 3431 Posted September 5, 2013 Autonat uzubljivanja tj. Bendix !Svakako remont alnasera. Quote Share this post Link to post Share on other sites
smotuljak 0 Posted July 1, 2014 (edited) Imam Fiat Brava 1.2 16V. Kada je niza temperatura (ispod 15 stepeni-malo smesno) ima problem sa paljenjem. Vergla, ali nece da upali. Kada je temperatura visa pali bez problema. Akumulator dobar,zamenjene svecice i kablovi. U cemu je problem. Edited July 2, 2014 by neshaoct spojeno Quote Share this post Link to post Share on other sites
borat 4 Posted July 1, 2014 da li ti sastavi pa se ugasi ili uopste nece da upali? Quote Share this post Link to post Share on other sites
smotuljak 0 Posted July 11, 2014 Imam Fiat Brava 1.2 16V. Kada je niza temperatura (ispod 15 stepeni-malo smesno) ima problem sa paljenjem. Vergla, ali nece da upali. Kada je temperatura visa pali bez problema. Akumulator dobar,zamenjene svecice i kablovi. U cemu je problem.Ima plin ali uvek pali na benzin Imam Fiat Brava 1.2 16V. Kada je niza temperatura (ispod 15 stepeni-malo smesno) ima problem sa paljenjem. Vergla, ali nece da upali. Kada je temperatura visa pali bez problema. Akumulator dobar,zamenjene svecice i kablovi. U cemu je problem.Ima plin ali uvek pali na benzin vergla ali nece da upali, kad poraste temperatura upali na prvo verglanje Quote Share this post Link to post Share on other sites
smotuljak 0 Posted August 9, 2014 da li ti sastavi pa se ugasi ili uopste nece da upali?Upali na prvo verglanje, onda se ugasi i dalje samo vergla i nece da upali sve dok se spoljasnja temperatura ne poveca. Nacelno se to desava kada recimo uvece oko 6 sati ugasim auto i ne palim ga do ujutro. Quote Share this post Link to post Share on other sites
borat 4 Posted August 14, 2014 pre mesec-dva mi je posle paljenja ostala upaljena zuta lampica motora prikljucim dijagnostiku kaze p0650 kontrolka zavad obrisem gresku i sve normalno danas u voznji opet se upali ista lampica dodjem kuci ubodem dijagnostiku ono opet p0650 isto je obrisem provozam 20 km i sve opet normalno.sta bi moglo biti ima li ko ikakvu ideju? Quote Share this post Link to post Share on other sites
nesica01 0 Posted August 26, 2014 (edited) Kada hocu da startujem auto nekada upali bez problema , a nekada vergla bez da pomisli da upali. Majstor je konstatovao da na svecicama nema uopste struje i zakljucio da je bobina. Odem kupim novu , zamenimo ono isto. Sledeci zakljucak senzor radilice i neka dva releja ispod haube (crveni i crni) . Zamenimo i njih kad ono isto. Tu se ja lepo zahvalim majstoru vratim moje delove, zovnem kuma da odslepam auto kuci i dok smo ga slepali ja probam da ga upalim on prihvati (na slepanje) . Dovezem ga kuci skinemo svecice lepo baca varnicu sve u redu, pokusam da ga upalim , startuje bez problema . Dva tri dana sve OK kad ono opet, odem do prodavnice sve normalno kada sam probao da ga upalim on opet vergla kao lud ali nista ni da pipne. Skinem svecice na njima opet nema varnice. Primetio sam jos i da mu u toku voznje broj obrtaja skace ponekad sa 2000 na 5000-7000 ali auto radi normalno ne povecava gasAuto ima ugradjen sekvent plin(pre tri godine) bravo 1,2 16v 1999 .Ima li neko ideju sta bi moglo da bude Edited August 30, 2014 by neshaoct spojeno Quote Share this post Link to post Share on other sites
tox 42 Posted August 26, 2014 Pregledaj sve "mase",konektore ...,posebno gde je ECU spojen.Drugar imao slican problem na bravu 1.6. Quote Share this post Link to post Share on other sites
nesica01 0 Posted August 27, 2014 Jutros upalio bez problema. Svejedno cu danas proveriti mase i uzecu onaj sprej za kontakte i sve dzekove naprskati pa ce mo videti. Quote Share this post Link to post Share on other sites
nesica01 0 Posted September 8, 2014 Kod mene se ispostavilo na kraju da je stepmotor pravio problema. Posle njegove zamene sve je ok. Quote Share this post Link to post Share on other sites
neshaoct 9590 Posted September 8, 2014 Hvala što si se setio foruma da napišeš šta je pravilo problem, sigurno će taj info trebati nekome ko bude čitao ovu temu. Quote Share this post Link to post Share on other sites
Mijailović P. 3431 Posted September 8, 2014 Men' to sujjmivo. Nema varnicu pa se ispostavi da je step?! Quote Share this post Link to post Share on other sites
Imladja 0 Posted January 24, 2015 (edited) Brava 1.2, 16v, 2001godiste, benzin-gas , hladan pali i vergla bez problema. Nakon voznje i to recimo nekih pola sata, odnosno kada se ugreje, pri ponovnom startovanju slabo vergla i ne moze da upali , kao da je prazan akumulator. Kada se ohladi , nakon 20-ak minuta opet vergla i pali bez problema. Anlaser servisirao-isto, stavio drugi-isto. Akumulator proveravao , kazu da je OK. Napomena: pre ovog problema radio sam mu glavu i zamenio malu radilicu. Sta je uzrok i koje je resenje? Edited January 27, 2015 by neshaoct prebačeno Quote Share this post Link to post Share on other sites
MilanM 11 Posted February 12, 2015 oko nove godine riknula mi bobina, zamenjena i vracene stare NGK svecice (Nove Bosove pos 10k km vrisnule), posle toga jednog jutra nakon vedre i hladne noci nije hteo da upali. Odvucen je u garazu koja se greje upalio bez problema, od tada do sinoc svake noci ga palim kada ide temp u - i pali normalo. Medjutim sinoc dodjem kuci oko 21h i rekoh nema potrebe da ga palim pre spavanja (to je period od 00-02) kad jutros nece da upali, posle 3 sata gad ogrejalo sunce i popela se temp upalio bez problema Predlozi sta bi moglo da bude? Quote Share this post Link to post Share on other sites
johnny84 0 Posted April 27, 2015 (edited) Pozdrav svima.takav problem imam kad kola stigne do radne temperature i stanem negde posle tesko pali.skoro da je prazan akumulator. vergla jako teško napravi 2-3 krug posle pali normalni odjednom.akumlator nov antifriz isto nov.radna temperatura u sredini kako treba.ovo je normalno kad motor toplo ili neki graška.hvala ako neko zna neki rešenju.kola je brava 1.2 16v 2001 sa plasticni usisnom. Edited April 27, 2015 by neshaoct spojeno Quote Share this post Link to post Share on other sites
neshaoct 9590 Posted April 27, 2015 Pogledaj sada, nakon spajanja tema, sve ranije napisano u temi na kojoj smo. Quote Share this post Link to post Share on other sites
johnny84 0 Posted April 28, 2015 Piše u ovoj temi sve i svašta ali niko nije rešio tačno šta je problem.moguće da neki kabal je posle kratke vožnje kad otvorim vrata malo trese struja.to sam već primetio. Quote Share this post Link to post Share on other sites
johnny84 0 Posted August 4, 2015 (edited) Pozdrav svima,problem je sledeci.vec pojma nemam sta da promenim ili menjam...moguce da je vec kola treba drugi.Jutro kad hladno lepo pali ali neki pola minut tako radi kao da ide samo tri cilindar posle sve ok.kad ovako zajebano pali onda u voznji ne ide tako kako treba ne vuce.kad pada kisa i vreme sveze ima magla ili nesto takav tako lepo pali kao nikad i ide ko nenormalam.Vec ne znam sta da radim ako ovde u forumu neko ima nesto misljenje...Kad vreme lepo sunce sija zajebano pali i nece da ideAli kad pada kisa pali lepo i ide kao neki drugi kola.Sigurno ne voli sunce.ne znam. Edited August 10, 2015 by neshaoct spojeno Quote Share this post Link to post Share on other sites
neshaoct 9590 Posted August 10, 2015 Jesi li proveravao bobine, svećice? Quote Share this post Link to post Share on other sites
