Vukasin 0 Posted January 17, 2010 Samo cu reci da je sad jedan od najlepsih u Srbiji. A boga mi i sire. Toliko. Quote Share this post Link to post Share on other sites
Vukasin 0 Posted January 18, 2010 Slikeee, sliiikeeee! Quote Share this post Link to post Share on other sites
podvarak 1 Posted January 19, 2010 Jbg muljavo vreme pa se i auto izmuljao. Jedino ove dve na brzaka s pranja sto si vec video Quote Share this post Link to post Share on other sites
SasaBgmk2 0 Posted January 19, 2010 Šta reći... Prelepo... Quote Share this post Link to post Share on other sites
Niksha 1 Posted January 19, 2010 Svaka cast! 16" je prava mera Quote Share this post Link to post Share on other sites
chikavili 511 Posted January 19, 2010 Definitivno najlepsi 5-tovratni 2b koji sam video Quote Share this post Link to post Share on other sites
podvarak 1 Posted January 19, 2010 ^ Hvala drugari ... 16" je definitivno prava mera! Pre punta sam vozio twinga sa 195/45 gumama i bio je daleko neudobniji. U svakom slucaju, ja sam prezadovoljan kako se auto ponasa. Topla preporuka svim vlasnicima puntica, cak i onima sa 1.2 motorom (dok god gume ne idu sire od 195). Quote Share this post Link to post Share on other sites
the_reaper 2 Posted January 19, 2010 carski! super su legle! ako smem da predlozim grill bez znaka i da se spusti na 50/50 i bice savrsen! Quote Share this post Link to post Share on other sites
Kypck 0 Posted January 19, 2010 Definitivno najlepsi 5-tovratni 2b koji sam video Slazem se. Quote Share this post Link to post Share on other sites
Manfred 2 Posted January 19, 2010 Odlichno izgleda... antena mi malo kvari izgled, ali sve ostalo 5+ Quote Share this post Link to post Share on other sites
podvarak 1 Posted January 19, 2010 carski! super su legle! ako smem da predlozim grill bez znaka i da se spusti na 50/50 i bice savrsen!Uh gril jurim vec duze vreme. Ima ovakvih crnih kao fabricki al bez znaka samo taj mi se i ne svidja bas. Ovaj http://uk.eurotuning.biz/img/1/_2417_1.jpg je extra i kosta nekih 60eur al traze jos 60eur za slanje do nas :/A gewinde su sledece u planu, cim se oporavim malo od ovih novogodisnjih i slavskih udaraca Odlichno izgleda... antena mi malo kvari izgled, ali sve ostalo 5+ xexe, antena je dignuta samo zbog pranja, kad se obori dole ne vidi se Quote Share this post Link to post Share on other sites
MilanLaki 0 Posted January 19, 2010 Ni ovako nesto nije lose, samo treba naci (ali da bude neka normalna cifra) Quote Share this post Link to post Share on other sites
the_reaper 2 Posted January 19, 2010 drugar je na mk2b radio grill ovde kod nekog lika, ali ne ovaj z10 nego onaj sa horizontalnim ovm kao pregradama, stavicu neku fotku danas sutra koje gewinde ces jesi nasao nesto? Quote Share this post Link to post Share on other sites
podvarak 1 Posted January 19, 2010 Ajd bas baci neku sliku ako nadjes, te glomazne stvari je uvek bolje uzeti ovde jer slanje od preko kosta boga oca! A gewinde jos nisam trazio onako temeljno, verovatno cu videti nesto preko Sandokana il cu sam pojuriti s ibeja.Ova slika sto je okacio MilanLaki (tj gril) se prodaje u FK automotive shopu za 58eur. U stvari nije isti dezen, slican je Quote Share this post Link to post Share on other sites
saleTIPO 3 Posted January 19, 2010 Lepo,lepo Mozda i distancer od 10mm pozadi??? E,ne mogu da prezalim sto ti nisam uzeo one felne za mog Tipa,stvarno su lepe Quote Share this post Link to post Share on other sites
podvarak 1 Posted January 19, 2010 Moracu da nadjem nekog ko ima 10mm il tu blizu neki pa da probam ... videcemo Quote Share this post Link to post Share on other sites
the_reaper 2 Posted January 19, 2010 mozes probati sa dva od yuga ali postoji problem sa bas 10mm, zato sto glavcina viri bas tu oko 10mm, tako da su ti opcije ili da vozis bez prstena ili da biras 8mm pa da ostane 2mm da nalegne na glavcinu ili 12mm sa prstenom Quote Share this post Link to post Share on other sites
podvarak 1 Posted January 19, 2010 Da, o tome bas sad razmisljam. Imam one 5mm za jugica 4kom u garazi pa cu stavim po dva pozadi da vidim jedan krug dal grebe cisto. Ako je ok i ima malko lufta, uradicu 12mm sa prstenom, ionako treba dobijem jedan valjak taman za to. Quote Share this post Link to post Share on other sites
the_reaper 2 Posted January 19, 2010 pa ako nisi nista radio sa rubovima mozda i hoce, rubovi su idiotski bar na 3dr, moraju se ili seci ili savijati na gore Quote Share this post Link to post Share on other sites
Vukasin 0 Posted January 19, 2010 Bolje savijati nego seci Quote Share this post Link to post Share on other sites
podvarak 1 Posted January 19, 2010 Ima bolja alatka za rubove. Zasrafi se i fixira u 4 srafa od tocka nesto kao sestar a na drugom kraju te sipke ima valjak koji se rotira uz rub tamo-vamo i izvlaci ga napolje polako. Sve vreme treba fenom grejati farbu da ne pukne.To mi pricao jedan lik koji uskoro planira da napravi tu spravu pa kad vidim kako je odradio kod sebe na yugicu onda cu i ja verovatno na izvlacenje Quote Share this post Link to post Share on other sites
the_reaper 2 Posted January 19, 2010 najbolje resenje, ja sam mislio da pravim posto toga kod nas nema, tj ko ima bezobrazan je sa ciframa za peglanje Quote Share this post Link to post Share on other sites
podvarak 1 Posted January 19, 2010 ^ pa to je to!Jbt aj videcu ja s tim likom ozbiljno kolko je voljan da odradi tu spravu, vrhunski je bravar inace i moze napravi sta oce od gvozdja... a pomalo ima i tunerske krvi, tweakovo je jugica na 1600ccm Quote Share this post Link to post Share on other sites
podvarak 1 Posted February 15, 2010 Stigli novi distanceri. U pitanju je 22mm alu varijanta. Jutros bio cas fiskulture na -3 Quote Share this post Link to post Share on other sites
