totti 13151 Posted May 4, 2013 Gorane, je l' radiš u ponedeljak? Quote Share this post Link to post Share on other sites
Goran Zemun 441 Posted May 4, 2013 Ne...jel nesto hitno??? Quote Share this post Link to post Share on other sites
totti 13151 Posted May 4, 2013 Ništa što ne može da sačeka utorak ili sredu Quote Share this post Link to post Share on other sites
Goran Zemun 441 Posted May 5, 2013 ok...vidimo se...pozzzzz:) Quote Share this post Link to post Share on other sites
Djuntalica 0 Posted May 5, 2013 Super, hvala na odgovoru...od utorka cu videti da ga dovedem....hvala! Quote Share this post Link to post Share on other sites
milan-jtd 316 Posted May 11, 2013 Pozdrav Gorane, ukratko, curi mi nafta! Za vreme praznika je cale primetio da ostavljam par kapi koje nisu ulje, juce sam primetio da ostavljam baricu ispod auta! Nafta. Posle voznje nafta bukvalno curka jos neko vreme. Posto je guzva ispod haube, video sam jedino da je menjac ceo vlazan, na njega se sliva. Posao mi je kod Vas u blizini pa mi odgovara da jedno jutro dovezem auto da sredimo to, samo kazite kada, ili moram da zovnem telefonom da se zakaze?Radi se o Puntu jtd 59kW. Veliki pozdrav Milan Quote Share this post Link to post Share on other sites
Goran Zemun 441 Posted May 11, 2013 Bilo koje jutro dovezite auto i videcemo sta je problem... Quote Share this post Link to post Share on other sites
milan-jtd 316 Posted May 11, 2013 Ok hvala, mogu vec u ponedeljak da dodjem.Vidimo se. Quote Share this post Link to post Share on other sites
bane1321 5823 Posted May 12, 2013 PozdravZa proveru auta pred putovanje vazi samo termin od 08.00 ili moze malo kasnije? Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted May 12, 2013 Deo je izdvojen u novu temu:http://www.fiat-lancia.org.rs/forum/index.php?showtopic=59491 Quote Share this post Link to post Share on other sites
Goran Zemun 441 Posted May 13, 2013 Moze i kasnije, ali onda morate cekati da se oslobodi neka dizalica. Quote Share this post Link to post Share on other sites
milan-jtd 316 Posted May 13, 2013 Samo da se zahvalim i ponovo pohvalim servis! Problem resen cas posla!I srecan rad sa novom spravicom koja je stigla u servis ako klima bude zezala, znam gde cu da je proverim Veliki pozdrav Milan Quote Share this post Link to post Share on other sites
Delic9 2 Posted May 14, 2013 Gorane, jel preporučuješ pre zamene ulja da se sipa ono neko sredstvo za ispiranje motora? Koliko vidim ima mnogo gareži iznutra, pa verujem da bi bilo bolje da se to skine. I ako preporučuješ, šta da uzmem?Hvala Quote Share this post Link to post Share on other sites
Goran Zemun 441 Posted May 14, 2013 Uvek je bolje isprati motor, svi ispiraci su na istoj bazi. Svakako FIRE motori imaju problem sa zapusenjem usisa uljne pumpe. Quote Share this post Link to post Share on other sites
Delic9 2 Posted May 14, 2013 Hvala na prebrzom odgovoru. Sutra ću zvati u servis da vidim kad bi mogao veliki servis da se uradi.Pozdrav! Quote Share this post Link to post Share on other sites
Psiho 0 Posted May 16, 2013 Pozdrav Goraneuzeo sam stila 1.9 mjet dijagnostikovan je problem sa protokomerom, senzorom nivoa goriva u rezervoaru, senzorom zagadjenosti klime (mislim da sam sve lepo zapamtio)takdje bih uradio veliki servis i trebalo bi pregledati prednji trap i komplet auto.Interesuje me cena za veliki servis i ovo sto je dijagnistifikovano. Takodje me interesuje kako se zakazuje... Quote Share this post Link to post Share on other sites
zalutao 3 Posted May 16, 2013 Pozdrav Gorane, da li postoji mogucnost da dodjem neki dan rano ujutro (od 8 vi radite?) imam nekih problema sa zadnjim trapom na puntu mk2b 1.3mjtd. Skoro sam promenio amortizere u ovlastenom servisu u BiH kad sam bio i trebalo bi da su u pitanju originalni amortizeri.Ali sad imam utisak da je auto jos tvrdji nazad nego prije. I najmanje sastave na asfaltu osjetim kao da silazim autom niz stepenice... Da li je moguce da su opruge zrele za zamjenu? Quote Share this post Link to post Share on other sites
Delic9 2 Posted May 16, 2013 (edited) Gorane, jesu li iste servo letve za sva vozila Bravo/Brava/Marea grupacije? I koliko košta zamena cele letve kod Vas(ja bih doneo drugu)? Hvala Edited May 16, 2013 by Delic9 Quote Share this post Link to post Share on other sites
Goran Zemun 441 Posted May 16, 2013 Iste su letve,samo su krajevi letve razliciti,zamena je 4000din. Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted May 16, 2013 Delovi su ovde:http://www.fiat-lancia.org.rs/forum/index.php?showtopic=33155&p=909884http://www.fiat-lancia.org.rs/forum/index.php?showtopic=59556 ----------------------------- Mora da se čita prvi post (kojim je otvorena tema) jer tu npr. piše za par stvari koje su pitane, poput toga kako se zakazuje, na koji telefon, kojim danima...isto tako i: Molim Vas da se za cene i termine javite u servis...011 2193543. ili 065 2193543. Quote Share this post Link to post Share on other sites
IvanBg 1 Posted May 23, 2013 Pozdrav Gorane,zanima me koliko kosta zamena seta kvacila za fiat Bravo JTD 105 99',ja bih doneo nov set,znaci samo zamena i da lipreporucujes zamenu plivajuceg zamajca prilikom zamena seta,kao i stavljanje fiksnog ako je plivajuci otisao,posto je nov 300e... Quote Share this post Link to post Share on other sites
Goran Zemun 441 Posted May 24, 2013 Za tvoj model moze i fiksni , ali set kvacila ti onda nije isti. A zamena delova je 6000 ili 7000din...moras pitati u servisu... Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted May 24, 2013 Deo postova (odgovora) je sada ovde:http://www.fiat-lancia.org.rs/forum/index.php?showtopic=59669http://www.fiat-lancia.org.rs/forum/index.php?showtopic=59670 Quote Share this post Link to post Share on other sites
Bojan1979 0 Posted May 24, 2013 Verovatno ću tokom leta dolaziti za Bg,planirao bih čišćenje dpf filtera,zamenu ulja u aut.menjaču i proveru kočnica,ogibljenja..sve vitalne stavke koje nemogu proveriti tj.poveriti malim servisima. I koje bi po tebi bili osnovni zahvati da vozilo "očvrsne" za period od 5god. Zato bih te zamolio za neku okvirnu cifru u rds. Quote Share this post Link to post Share on other sites
cane 205 Posted May 28, 2013 (edited) Pozdrav Gorane, da li imate neko resenje za hill holder u puntu? Vise mi smeta nego sto mi koristi. Najradije bih ga skroz deaktivirao ali dolazi u obzir i da zbunimo senzor nagiba nekako pa da HH hvata samo na vecim uzbrdicama Edited May 28, 2013 by cane Quote Share this post Link to post Share on other sites
