vagenovac 4533 Posted March 14, 2020 Zapusice dpf i egr, ubijaj cenu Послато са Mi MIX 2 помоћу Тапатока 3 igor0511, djomla and Ivan reacted to this Quote Share this post Link to post Share on other sites
Ivan 17587 Posted March 14, 2020 Upravo to , je*es onda i potrosnju i sve... Napunice cumurom masinu i umrtviti mi TDI-a . 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted March 14, 2020 Deder decko, drzi ti to malo u obrtajima. Nemoj da mi davis auto. Posle treba da pribegavam seljackim metodama obaranja cene .Nadam se da ti ne preterujes sa obrtajima, da ne moram na osnovu toga da ubijam cenu. Sent from my SM-J530F using Tapatalk 2 Ivan and dekirs reacted to this Quote Share this post Link to post Share on other sites
Ivan 17587 Posted March 14, 2020 Drzao sam bre i Stildzu 10 godina, radio je kao satic... Mo's misliti tek benzinjaru, ne da ti mira dok ga lepo ne zavrtis , tek tu prede. Quote Share this post Link to post Share on other sites
Flex 1778 Posted March 14, 2020 Pusti ti to, nista bez "Vozio deda, imao kracu nogu. Nikad pun gas." Sent from my SM-J530F using Tapatalk Quote Share this post Link to post Share on other sites
TeaseR 100 Posted March 14, 2020 Na MOL-u u tosinom bunaru ima akcija do 5. Aprila. 3/5din popust na gorivo. Nema nigde na sajtu, ja slucajno video na nekom bilbordu pa otisao i pitao. 1 1 Woodoo and Ivan reacted to this Quote Share this post Link to post Share on other sites
igor0511 2874 Posted March 14, 2020 Pala je potrosnja goriva drasticno pa se svi “grebu” za musterije. 1 rkoma1986 reacted to this Quote Share this post Link to post Share on other sites
dellas 1556 Posted March 14, 2020 Ako ako nek pada malo, to mi je industrija koje mi je najmanje zao ako sve stane na neko vreme 6 djomla, rkoma1986, Flex and 3 others reacted to this Quote Share this post Link to post Share on other sites
Goksi1980 43 Posted March 20, 2020 Zamenjen maf senzor,auto ide bolje i pala potrosnja.Sipao za 1500 din evro dizel,presao 210 km.Relacija Batajnica-Zemun Polje-Dedinje uglavnom. 1 Axic reacted to this Quote Share this post Link to post Share on other sites
milandjbg 65 Posted March 20, 2020 51 minutes ago, Goksi1980 said: Zamenjen maf senzor,auto ide bolje i pala potrosnja.Sipao za 1500 din evro dizel,presao 210 km.Relacija Batajnica-Zemun Polje-Dedinje uglavnom. Zar ibpre toga nisi imao dobru potrosnju?? Kako si istanovio da ti je neispravan map senzor?? Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted March 20, 2020 Meni sad bije 15L po NBG. Razlog: devojka vozi Sent from my S10 PRO using Tapatalk Quote Share this post Link to post Share on other sites
silenci 2333 Posted March 20, 2020 a sad ces onda morati duple smene da radis 1 ISV_01 reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted March 20, 2020 Nema bato, na kucnom sam rezimu. Nit u njivu da idem, mentor i saradnik 67+g, licencu cekam vec 6 meseci, moracu da okopavam saksije po kuci Ne zalim, samo nek vozi, za sad bijemo rekord 4 babe / dan Kvalitetni brisaci bato! Sent from my S10 PRO using Tapatalk 1 Grafit reacted to this Quote Share this post Link to post Share on other sites
silenci 2333 Posted March 20, 2020 a dobro je samo opusteno,ja za 5 dana na 6 objekata radio,ne znam vise ni kako se zovem i negledam na potrosnju,bez auta nebi mogao da funkcionisem.musava skoro postala ko sluzbeni auto Quote Share this post Link to post Share on other sites
MS PK 7728 Posted March 20, 2020 Meni sad bije 15L po NBG. Razlog: devojka vozi Sent from my S10 PRO using TapatalkTrebao si neki kvalitetniji set kvacila da stavis, u stvari bolje da ai ugradio automatik Послато са SM-J330F помоћу Тапатока 1 1 Martin and ISV_01 reacted to this Quote Share this post Link to post Share on other sites
Goksi1980 43 Posted March 21, 2020 9 hours ago, milandjbg said: Zar ibpre toga nisi imao dobru potrosnju?? Kako si istanovio da ti je neispravan map senzor?? Bila je OK i ranije, palila se svaki dan Check Engine, dobio polovan na probu od majstora, to je bilo to. Na kraju uzeo nov. Quote Share this post Link to post Share on other sites
milandjbg 65 Posted March 21, 2020 Ja jos uvek nisam resio moj problem ne pali mi nista ali sam napunio rezervoar do cepa idem na dalji put pa cu videtibpravu potrosnju na otvorenom. Quote Share this post Link to post Share on other sites
igor0511 2874 Posted March 21, 2020 Meni poslednjih nedelju dana auto nista ne trosi 3 1 shomispc, djomla, Axic and 1 other reacted to this Quote Share this post Link to post Share on other sites
Goksi1980 43 Posted March 21, 2020 9 hours ago, milandjbg said: Ja jos uvek nisam resio moj problem ne pali mi nista ali sam napunio rezervoar do cepa idem na dalji put pa cu videtibpravu potrosnju na otvorenom. Na dalji put,a vanredno stanje?Mora da imas neki ausvajs Quote Share this post Link to post Share on other sites
milandjbg 65 Posted March 21, 2020 (edited) Otisao u selo,malo da odmorim i da vidim sta ce biti,povodom cele situacije. Do sela oko 280 km. Vreme idealno za testiranje. Prosecna potrosnja 3.5 lit Prosecna brzina 85 km Trajanje putovanja 3 sata i nesto. U autu dve osobe plus pun gepek ukupna tezina 320 kg minimum. Sto znaci da je aditiv za ciscenje dizni odradio pravu stvar, a i spoljna temperatura. Na istom tom putovanju pre mesec dana auto je trosio 4.5. Ja sam prezadovoljan potrosnjom, na otvorenom. A grad u Beogradu moze da potrosi od 5 pa do 9 lagano.Ali to nije merodavno. To su moji utisci sto se tice testiranja. Utisci da je auto odlican za dug put i menjac sa sest brzina pun pogodak,ali zato se u gradu pokazao malo losije i mislim da je menjac peto brzinac bolji za grad. Veliki pozdrav i ovo je kraj bavljenja potrosnjom,sad da prodje sve ovo ovo pa pravac more ako da bog. U prilogu slike. Edited March 21, 2020 by Ivan Sredjene slike i tekst 1 ISV_01 reacted to this Quote Share this post Link to post Share on other sites
Ivan 17587 Posted May 19, 2020 Udjosmo i u trecu godinu druzenja, a nikako da se za jubilej dopisem na temi o potrosnji. Bravo Sport 1.4 MultiAir Turbo 140, u dosadasnjem vlasnistvu, po cepu - okruglo 6.84 l . Izuzetno sam zadovoljan, s obzirom da fabrika deklarise 5.7 l kombinovane. Sto je tacno +1.14 l (i okruglo +20%) na fabricke fantazije. Iskreno, pre kupovine sam ocekivao do +2l na tu cifru, s obzirom da je u pitanju turbo benzinac koji ce se voziti i po BG. Ocigledno da MA tehnologija daje rezultat i u vecoj snazi (tacnije torque) i manjoj potrosnji u odnosu na klasicne, starije turbake. Cak smo se do skoro dugo vozili na cca 6.7 l (+1l na fabricku kombinovanu), ali zima+Corona ucinise svoje . PS: Posto sam omatorio za predstavljanje auta, a kada vec sumiram - samo kratak off i interesantan podatak za ljude koji propagiraju "rekla-kazala" stavove generalno o turbacima, bez mnogo iskustva iz licne prakse. Da su to sve izakane kante iz inostranstva, da ne moze da se kupi nista da valja, da se sipaju stotine EUR godisnje u odrzavanje, razlecu se zamajci, turbine, i sl... Auto od kupovine i inicijalnog servisa nije imao bukvalno ni jedan jedini kvar, niti vanrednu posetu majstoru, ukljucujuci kompletnu mehaniku i elektroniku. Jedina lampica koja se do sada upalila i "kvar" je kada mi je crkla T10 pozicija na putu do Istanbula. Over and out. 6 MS PK, igor0511, Axic and 3 others reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3431 Posted May 19, 2020 Ih, mator za predstavljanje! Šta da reče Totti-ka ?! Malo-malo pa predstavi neku matorku. Inače, ja spirio dve...tri boce od početka meseca. Kol'ko troši, nem' pojma! Quote Share this post Link to post Share on other sites
totti 13160 Posted May 19, 2020 Tottika još malo pa neće ni znati da ima auto 1 3 Mijailović P., Ivan, rkoma1986 and 1 other reacted to this Quote Share this post Link to post Share on other sites
dellas 1556 Posted May 19, 2020 Long term 11k km uzorak, 45km/h prosecna brzina - kombinacija svega - Auto put pretezno, grad takodje i malo magistrale 6.2l - 2.0tdi 150hp (kad je samo u gradu trosi pola l vise ) Uzorak od takodje par k km samo u gradu uz prosek 26 km/h - 6.6l - 1.9tdi 105hp Manji uzorak 3.0d magistrala lagana voznja 5.2l , grad 9.2l takodje lagana voznja 1 Ivan reacted to this Quote Share this post Link to post Share on other sites
