milan-jtd 319 Posted February 6, 2015 Manje kubika -> manje snage -> manje obrtnog momenta -> VISE GASA!!! Retko ko slab motor vozi lagano, svi ga bre gaze pa onda normalno da ce i trositi. Znam po sebi, kada sednem iz svog JTDa u sluzbeni 1.2 mnogo vise gazim pedalu Quote Share this post Link to post Share on other sites
RSS 0 Posted February 6, 2015 Sluzbeni je najbrzi Quote Share this post Link to post Share on other sites
milan-jtd 319 Posted February 6, 2015 A ja opet imam trip da sluzbeni vozim pazljivije nego svoj, kakvi su baksuzi samo treba jos i da mi nakace da popravljam nesto... Quote Share this post Link to post Share on other sites
RSS 0 Posted February 6, 2015 Jasno, od samog coveka zavisi kako vozi svaki auto.Nego eto, to kad se kaze uvek je smesno... Pa da budem smesan malo. Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted February 6, 2015 Koji je auto bolji od sluzbenog? Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted February 6, 2015 Kolegin sluzbeni Quote Share this post Link to post Share on other sites
M-a-r-k-o 3 Posted February 6, 2015 Manje kubika -> manje snage -> manje obrtnog momenta -> VISE GASA!!!Retko ko slab motor vozi lagano, svi ga bre gaze pa onda normalno da ce i trositi. Znam po sebi, kada sednem iz svog JTDa u sluzbeni 1.2 mnogo vise gazim pedaluA kad iz 1.2 sednes u JTD a gaziš pedalu gasa kao da si i dalje u 1.2.... Quote Share this post Link to post Share on other sites
milan-jtd 319 Posted February 6, 2015 A i to je tacno Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted February 6, 2015 Kako sad Punto 1.2 troši puno ?Par njih se hvalilo sa malom potrošnjom. Quote Share this post Link to post Share on other sites
Ivan srbin 0 Posted February 6, 2015 Ja moju Deltu jos nisam testirao , ali sa svojih 1800 kubika sve ispod 10-tke ce biti zadovoljavajuce Quote Share this post Link to post Share on other sites
Dante Bg 4 Posted February 6, 2015 Kako sad Punto 1.2 troši puno ?Par njih se hvalilo sa malom potrošnjom. Pa zavisi od stila voznje.Znas i sam kako si nam pricao za Brava.Isti auto,ista relacija ali razlicite potrosnje kod 2 vozaca Quote Share this post Link to post Share on other sites
Bogisha 9 Posted February 6, 2015 Ja ne umem da vozim štedljivo. Umem samo da vozim da mi prija. Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted February 7, 2015 Kad vozim stila, posebno po gradu - ne sacam se da sam stisao do patosa. Sa lanciom......bolje da cutim, jednom ce trebati i da se proda Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted February 7, 2015 Ja ne umem da vozim štedljivo. Umem samo da vozim da mi prija. Znaci ti si neki bahati jadna alfa od tebe Quote Share this post Link to post Share on other sites
totti 13165 Posted February 7, 2015 Ja ne umem da vozim. Quote Share this post Link to post Share on other sites
Bogisha 9 Posted February 7, 2015 Kad vozim stila, posebno po gradu - ne sacam se da sam stisao do patosa. Sa lanciom......bolje da cutim, jednom ce trebati i da se proda A sestrin punto nov, 32 hiljade prešao, greota mi da ga teram. Al šta ću. Ja ne umem da vozim štedljivo. Umem samo da vozim da mi prija. Znaci ti si neki bahati jadna alfa od tebe Nisam bahat, al što volem u žutu trakuu Quote Share this post Link to post Share on other sites
vix 1 Posted February 7, 2015 Evo sad trenutno vozim Chevrolet Spark 0.8 . Stilu zajeb. Akumulator pa pozajmio Sparka od caleta. Ko pekinezer kad laje Dobro da ga inace ne vozim, brzo bih ga upropastio. Ne mogu da ga vozim ispod 3 k obr. Uglavnom se krece 3-4.5-5 k obr. Pa shodno tome nije da malo trosi. U gradu bez 8 ne moze... Quote Share this post Link to post Share on other sites
amladenbk 1 Posted February 7, 2015 potrosnja je relativna stvar .. nekome je 7 po gradu mnogo a nekome je 11-12 normalno ...zavisi koliko kome je dubok dzep za gorivo ...ja nisam spreman da dodajem duplo od onog sto mi firma da za prevoz za mesec dana ...jos uvek se uklapam u tu cifru .... bolje da malo stedim gorivo i vozim se kolima na i sa posla nego da ostavljam svaki dan po dva sata u gradskom prevozu ...ovako sam odsutan iz kuce 8 i po sati a da idem GSB-om nema manje ispod 10 sati ... Quote Share this post Link to post Share on other sites
Evidenticar 0 Posted February 7, 2015 (edited) ...istina! Edited February 7, 2015 by Ivan Ne citiraj prethodni post Quote Share this post Link to post Share on other sites
ata 77 Posted February 7, 2015 Kada covek sracuna koliko ga kostaju amortizacija, registracija i servisi... gorivo je jos i jeftino, a usteda zanemarljiva.Najblaze receno neozbiljno mi je kad neko ima (nova) kola da bi ih provozao vikendom, a na posao ide autobusom. Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted February 7, 2015 Da nije žena.Meni je razlika 10 min i to se nekad izgubi dok nađem gde da se parkiram tako da se klackam i ne razmišljam. Quote Share this post Link to post Share on other sites
Dovla 9 Posted February 7, 2015 Očigledno se klackaš u nekoj neopterećenoj liniji Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted February 7, 2015 Brzinske i japanski tačne. Quote Share this post Link to post Share on other sites
amladenbk 1 Posted February 8, 2015 (edited) trebas da ides dvojkom da vidis sta je klackanje .. pa kad vozac zaglavi u wc kod pristanista desetak minuta .... stojis i cekas da covek izbaci .... a kad dodje do brankovog mosta onda 70 stepenika uzbrdo .... ako si srecnik pa jos radis jutarnju od 05 h ... nema bolje ...inace odradio sam juce zamenu termostata po najvecem snegu ... sve sa odzracivanjem i skidanjem akumulatora i kutijom za akumulatora 20 minuta .... ustedeo 1500 dinara i cekanje kod majstora ... odmah obradovao rezervoar .... temperatura zakucana na pola .... za nekih dva tri minuta dostigne pola .... odmah pokazuje povecanje kilometraze po litru ... danas pokazuje 15.7 km/L .... videcu sutra koja je potrosnja Edited February 8, 2015 by amladenbk Quote Share this post Link to post Share on other sites
