Memphis 15 Posted January 4, 2017 A koji auto? Obično oni svi imaju imbus broj 12 Quote Share this post Link to post Share on other sites
Multi 0 Posted January 4, 2017 @Memphis Eh da, nisam napisao. Radi se o Fiat Stilu, multijet, 16 v. Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted January 4, 2017 Samo prvo malim srafcigerom iscackaj prasinu i blato iz njega, pa onda kad stavis imbus nakucaj ga malo cekicem, obicno proklize.... Quote Share this post Link to post Share on other sites
Multi 0 Posted January 4, 2017 Hvala puno za pomoc, onda sutra kupujem imbus 12 i odradicu ovo. Quote Share this post Link to post Share on other sites
Memphis 15 Posted January 4, 2017 Ako je Diesel onda je manji ... ali ne znam točno koji ... 8 ili manje ... Quote Share this post Link to post Share on other sites
Multi 0 Posted January 5, 2017 Radi se o dizelu, 103kw. Koji sad kupiti 12 ili 8? Quote Share this post Link to post Share on other sites
Memphis 15 Posted January 5, 2017 Imbus 8 Imaš tu: https://teon-production.herokuapp.com/cars/fiat-stilo-diesel-1-dot-9-jtd/manuals/51b71df6a11460327500004d/chapters/interim-service/chapter_parts/oil-change Quote Share this post Link to post Share on other sites
Multi 0 Posted January 5, 2017 Hvala druze na pomoci, kupio sam osmicu. Veliki pozdrav! Quote Share this post Link to post Share on other sites
Multi 0 Posted January 5, 2017 Zanimaju me i iskustva sa comeline (cini mi se da se tako zove), radi se i filteru nafte? Quote Share this post Link to post Share on other sites
Multi 0 Posted January 5, 2017 Ispravka, Comline filter. Mislio sam na ovu marku filtera kakvog je kvaliteta. Dakle radi se o filteru nafte marke Comline. Quote Share this post Link to post Share on other sites
MS PK 7718 Posted January 5, 2017 Aaaa posto je? Quote Share this post Link to post Share on other sites
Multi 0 Posted January 5, 2017 15 evra ga platio. Al procitao na nekim forumima da su losi, pa kontam da ga sutra zamjenim aki vec ne valja. Quote Share this post Link to post Share on other sites
Ivan 17454 Posted January 6, 2017 Posle gomile ispisanih pozitivnih iskustava za pojedine brandove, ne razumem potrebu da se za par stotina kinti razlike eksperimentise sa no-name filterima. Quote Share this post Link to post Share on other sites
Multi 0 Posted January 6, 2017 Paa objasnicu ti. Zivim u BiH, malo mjesto, normalno i mali broj prodavnica...tako da u jednoj nemaju nikako, a u drugoj imaju samo ove. A nisam ni znao kakvog su kvaliteta.. Quote Share this post Link to post Share on other sites
Ivan 17454 Posted January 6, 2017 Nema nikakvih podataka u avataru, iz tog razloga je bio moj komentar. Hteo sam da kazem da se za iste pare moze uzeti npr. UFI i nema sta da se razmislja. Quote Share this post Link to post Share on other sites
Memphis 15 Posted January 6, 2017 On 1/5/2017 at 8:02 PM, Multi said: Zanimaju me i iskustva sa comeline (cini mi se da se tako zove), radi se i filteru nafte? Kupuj samo OEM proizvođače. Bosch, Champion, itd. ako hoćeš nešto bolje onda MANN ili Mahle. Ali po meni je Champion neki bestbuy. Quote Share this post Link to post Share on other sites
Axic 19729 Posted January 6, 2017 On 1/6/2017 at 5:19 PM, Multi said: Paa objasnicu ti. Zivim u BiH, malo mjesto, normalno i mali broj prodavnica...tako da u jednoj nemaju nikako, a u drugoj imaju samo ove. A nisam ni znao kakvog su kvaliteta.. Ako imas mogućnosti naruci neki bolji filter barem taj za gorivo,eventualnoi i onaj za ulje. Za ostala dva se ne moras toliko opterecivati za kvalitet. Quote Share this post Link to post Share on other sites
Multi 0 Posted January 6, 2017 Razumio sam sta si htio da mi kazes... Vidjecu da vratim ovaj, pa da narucim drugi. Valjda vrati posto se znam sa ovim prodavacem. Filter ulja sam uzeo od proizvodjaca MANN. U svakom slucaju hvala vam na pomoci. Quote Share this post Link to post Share on other sites
Axic 19729 Posted January 6, 2017 Za MANN nisi pogresio uopšte. Quote Share this post Link to post Share on other sites
MS PK 7718 Posted January 6, 2017 A sta je lose kod tog? Quote Share this post Link to post Share on other sites
Memphis 15 Posted January 7, 2017 Pa nije ništa loše ali bolje je da koristi kvalitetnije filtere. Po meni su svi daleko bolji od kineskih. Ali sa OEM markama ipak postoji neka kontrola kvalitete iako se i tu nađe škarta. Ja sam probao razne marke filtera i svi OEM su više manje bili ok osim poljskih. Kao što su Filtron i Denckermann. To po njima već vidiš da su lošije kvalitete i izrade.(štedi se na svemu). A Denckermann mi se raspao. Bio je kao filter goriva karton se unutra raspao. Dok sa Bosch, Champion, UFI, Purflux, Mann, Mahle nisam nikad imao problema. Jedino bi tu izbacio FRAMM njih ekipa dosta pljuje ovi kaj ih otvaraju jer imaju dosta manjkavosti u izradi a to sam vidio i na zadnjem Purflux filteru ulja kojeg sam kupio. (Sogefi grupa radi Purflux, Framm). Vidlo se ljepilo. Po meni za takav filter je nedopustivo jer je taj filter skoro duplo skuplji od recimo Championa koji je po meni neki bestbuy s obzirom na cijenu i kvalitetu. Champion zapravo radi filtere za Bosch na pojedinim tržištima i slično. Mislim svatko uzima prema nekim svojim preferencama i mogućnostima. Ali ako već kupuje filter koji je cjenovno u rangu OEM proizvođača bolje onda uzet njih. Quote Share this post Link to post Share on other sites
MS PK 7718 Posted January 7, 2017 Naravno, nego pitao sam koji problem imaju. Kod mene je Champion i najnormalnije je sve i zimi, tako da sam zadovoljan skroz. Quote Share this post Link to post Share on other sites
Axic 19729 Posted January 7, 2017 @MS PK pa tebi zimi auto stoji parkiran uz sam kotao za grejanje. Quote Share this post Link to post Share on other sites
MS PK 7718 Posted January 7, 2017 Stoji kad moze Quote Share this post Link to post Share on other sites
