Zivic12345 0 Posted August 10, 2017 Evo zvao sam majstora, pise samo Defrost Sensor i to je to Quote Share this post Link to post Share on other sites
neshaoct 9592 Posted August 11, 2017 @Zivic12345 Pogledaj ovaj post https://www.fiat-lancia.org.rs/forum/index.php?/topic/38046-fiat-stilo-ne-radi-mi-klima-curi-klima/&do=findComment&comment=1087849 Quote Share this post Link to post Share on other sites
Nikola Mihajlovic 0 Posted January 7, 2020 Pozdrav svim clanovima. Imam problem fiat stilo karavan 1.9 jtd 8v i grejanje i klima neduva... Nehladi ne greje radilo sve ok od jednom stade i nista da li neko moze da me uputi sta i kako? Hvala u napred Quote Share this post Link to post Share on other sites
MS PK 7734 Posted January 7, 2020 Ne duva ti ventilator?Послато са SM-J330F помоћу Тапатока Quote Share this post Link to post Share on other sites
sibonios 43 Posted June 18, 2023 Fiat Stilo 1.6, automatska klima se ne ukljucuje. Prijavljuje gresku defrost sensor, B1919. Instalacija proverena i ispravna. Da li je neko resio ovaj problem? Quote Share this post Link to post Share on other sites
darkman14 5900 Posted June 19, 2023 @sibonios mozda jedno od resenja https://www.fiatforum.com/threads/climate-control-frost-sensor-fault.135955/post-1469104 koliko znam, ako postoji, defrost senzor je na isparivacu. a elearn potvrdjuje da na 1.6 16v ne postoji frost senzor https://4cardata.info/elearn/192/2/2001017/2000109/2002179/192004757 Quote Share this post Link to post Share on other sites
sibonios 43 Posted June 19, 2023 Video sam taj post i tacno je da u elearnu ne postoji podatak da defrost senzor postoji na klimi motora 1.6, ali su neki ugradjivali ecu klime od 1.2. Tako pise. Nije mi jasno gde je ecu klime? Da li je na plocici za podesavanje kontrole klime ili je objedinjeno sa ecu motora? U tom postu sto si poslao link, pominje se otpornik od 20 koma na pinu 5, a to je izgleda na ecu motora jer je tu: 5 Air conditioning pressure switch A greska koju cita na mom stilu: Quote Share this post Link to post Share on other sites
darkman14 5900 Posted June 19, 2023 U onom linku stoji da defrost senzor ide na M1, M1 je ecu kod osiguraca levo od volana tako da je to to. Imas i kako konektor izgleda... Ali ako nisi imao ovaj problem, a sad ga imas, moze biti da je nesto drugo po sredi. Koliko vidim, postoji greska za jos 1 senzor i 1 aktuator. I to cini mi se klapne. Postoji li opcija da se MESom nakacis na obd? Tj imas li obd2 kabl i laptop? Quote Share this post Link to post Share on other sites
sibonios 43 Posted June 19, 2023 (edited) Imam. Ove ostale greske sam obrisao, samo ta stoji. Pogledacu opet. Na koju sliku konektora mislis? Edited June 19, 2023 by sibonios Quote Share this post Link to post Share on other sites
darkman14 5900 Posted June 20, 2023 @sibonios Imas na onom linku sto sam ostavio sa elearna i slike konektora ka ecu. Quote Share this post Link to post Share on other sites
sibonios 43 Posted June 29, 2023 Izbrisao sam greske za defrost senzor i mist senzor. Ostale su ukljucene u proxy kao prisutni senzori, ko zna kada, a problem je pri upisivanju promena u klimatronik. Paznju na problem sa upisom promena mi je skrenuo covek sa poljskog foruma jer je i on imao isti problem i resio ga je tako sto je vise puta za redom, bez ponovnog pokretanja MES-a, radio proxy poravnanje sve dok promena nije prosla. 1 darkman14 reacted to this Quote Share this post Link to post Share on other sites
darkman14 5900 Posted June 29, 2023 @sibonios sad ladi? ovaj radi... Quote Share this post Link to post Share on other sites
sibonios 43 Posted June 29, 2023 Sad treba da napunim sistem, jer sam ga ispraznio kada sam menjao cev klime, pa cu javiti. Kada sam rucno ukljucivao kompresor, preko releja, hladilo je. Nije mogao preko dugmeta iz kabine da se ukljuci kompresor. 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
sibonios 43 Posted June 30, 2023 To je to. Led dioda i dugme za ukljucivanje klime rade i bez freona, a kada sam napunio sistem, klima hladi kako treba. 1 darkman14 reacted to this Quote Share this post Link to post Share on other sites
darkman14 5900 Posted June 30, 2023 super... znači, stilo 1.6 16v definitivno nema defrost senzor, ukoliko prijavljuje grešku potrebno je da se obriše iz mes-a i odradi proxy alignement? Quote Share this post Link to post Share on other sites
sibonios 43 Posted June 30, 2023 Tako je. Moze da se desi da nece MES da upise iz prve promenu kroz proxy, ali treba zadavati naredbu dok ne prodje. 1 darkman14 reacted to this Quote Share this post Link to post Share on other sites
darkman14 5900 Posted June 30, 2023 @sibonios a otkud kod tebe upaljen taj senzor? Da li je neko menjao ecu? Jesi takav auto kupio? I jesi li izmestio ecu i sve ono sa akumulatora? Quote Share this post Link to post Share on other sites
sibonios 43 Posted June 30, 2023 Ne znam kako se ukljucio senzor. Klima je radila prosle godine, a onda se nesto pokarambasilo. ECU je ok, repariran i izmesten odavno. 1 darkman14 reacted to this Quote Share this post Link to post Share on other sites
