dulegti 1 Posted July 3, 2009 (edited) Treba mi mala pomoc..Da li neko mozda slucajno zna koje sijalice idu u farove za dugo svetlo na Alfi 156 2002 god? Za kratko je H7... Hvala unapred......Kolega ima taj auto,a devojka hoce da ga iznenadi i kupi mu xenone i sad neznamo koji set ide unutra... Edited July 3, 2009 by dulegti Quote Share this post Link to post Share on other sites
neshaoct 9591 Posted July 4, 2009 ..pitaću danas Dragona, on ima Alfu 156. Jedino ako on ne vidi temu i odgovori pre nego što se ja sutra ( danas ) probudim... Quote Share this post Link to post Share on other sites
gaggi 0 Posted July 4, 2009 Sijalica za dugo svetlo u 156 je H1.edit : index.aspKoristan sajt za tipove sijalica u svim modelima. Quote Share this post Link to post Share on other sites
dulegti 1 Posted July 4, 2009 Hvala puno na brzom odgovoru...Pozzzz Quote Share this post Link to post Share on other sites
wayedaj 0 Posted June 12, 2023 On 7/4/2009 at 1:44 AM, dulegti said: Treba mi mala pomoc..Da li neko mozda slucajno zna koje sijalice idu u farove za dugo svetlo na Alfi 156 2002 god? Za kratko je H7... Hvala unapred......Kolega ima taj auto,a devojka hoce da ga iznenadi i kupi mu xenone i sad neznamo koji set ide unutra... I can help you with that. For the high beam headlights on the Alfa Romeo 156 2002 model, the bulb type commonly used is H1 light. It's important to note that bulb types can vary depending on the specific trim level and optional equipment installed in the vehicle. It's recommended to double-check the owner's manual or consult an authorized Alfa Romeo dealer to confirm the exact bulb type for the high beam headlights in that particular model year and trim level. Quote Share this post Link to post Share on other sites
