Dante Bg 4 Posted February 25, 2015 Mica inovator Posle termosa sa Renoa 4 bas me zanima sa cega je stavio turbo Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted February 25, 2015 Od Ducata ili od autobusa Quote Share this post Link to post Share on other sites
Dante Bg 4 Posted February 25, 2015 Aaa pa zato on tera Stila 200 Km/h.To je pravi tuning Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted February 25, 2015 Zna ci celca znanje Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted February 25, 2015 A felne ce da nagura 14 od Punta, pa ce potrosnja da bude 2,6L na otvorenom, a 3,2L po gradu Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted February 25, 2015 Ma koje od punta, od Tipa ima 13 da ubaci potrosnja bar na 2, jer je direktor tako rekao Quote Share this post Link to post Share on other sites
MS PK 7728 Posted February 25, 2015 Od Bmw-a 530d pase uz minimalne prepravke. Naravno i mapa mora malo da se doradi Quote Share this post Link to post Share on other sites
Dante Bg 4 Posted February 25, 2015 A dizne?Jesi i njih menjao? Quote Share this post Link to post Share on other sites
MS PK 7728 Posted February 25, 2015 Jok, malo su razbusene samo. Nije mnogo, po 1mm Quote Share this post Link to post Share on other sites
-OTPRAVNIK- 0 Posted February 26, 2015 Imam jedno pitanje.Ne znam da li je do kvacila ali kada sam na nekoj uzbrdici ne mogu/umem da krenem.Kao da je los balans kvacilo-gas.Moze li to ikako da se regulise i o cemu se radi ako ume neko da objasni.Zeznuto je jer vise puta mi se gasi auto po gradu na cak i blagim uzbrdicama i nema sanse da krenem bez rucne.Radi se o stilu multi dzet.Ja sam prilicno neiskusan vozac ali imao sam sam ranije JTD i to mi se nije desavalo, tako da mislim da ovde nesto nije dobro podeseno. Quote Share this post Link to post Share on other sites
majkicbane 58 Posted February 26, 2015 Nema tu nikakvog podesavanja A kako ti hvata kvacilo na ravnom kad polazis? Quote Share this post Link to post Share on other sites
banjo1990 264 Posted February 26, 2015 A šta si ranije vozio, koji tačno auto sa jtd motorom? Nisu isti svi jtd motori, a ni sam prenos. Meni je recimo Punto JTD bio milina za gradsku vožnju, kako je lagano i startno kretao bez gasa maltene, ali Alfa recimo (multijet) ne može tako, nego moram dati lepo gas kada krećem. Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted February 26, 2015 Da ne kreces ti trecom prijatelju? Quote Share this post Link to post Share on other sites
igor0511 2874 Posted February 26, 2015 Iskreno ne znam za Alfe, ali Stilo najnomralnije kreće bez gasa. Štaviše po kiši i treba da se krene bez gasa ako nećete da bar malo gume proklizaju Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted February 26, 2015 (edited) Ovaj moj 16v boga mi trazi malo gasa, kao i benzinac, tj moze on da krene bez gasa ali nije to to, za razliku od drugih dizela koje sam vozao ovaj kao da hoce da se ugasi.Mislim da je to do takvog prenosa. Edited February 26, 2015 by Kuvalja Quote Share this post Link to post Share on other sites
Mijailović P. 3431 Posted February 26, 2015 Menjao turbo a sad na red došlo i kvačilo! Quote Share this post Link to post Share on other sites
-OTPRAVNIK- 0 Posted February 27, 2015 Imao sam isto Stila 1.9 samo JTD a sad je MJ, dezelasi.I na ravnom nije bas idealno polazenje ali naravno mnogo je lakse.I cale se isto zali da je imao problema na nekim uzbrdicama i da njemu isto malo smeta, tako da verujem da nije do moje nesposobnosti da izbalansiram kvacilo/gas.Pa sam mislio da li moze to nekako da se reguliste, pritegne/opusti kvacilo ili tako nesto, da bi bio laksi polazak.JTD mi je delovao bolje sto se toga tice i jos dosta stvari, MJ je samo startniji i brzi. Ne polazim trecom. Izgleda da cu morati da odem na neku uzbrdicu gde nema vozila da vezbam malo ne bi li ukapirao kako da krecem. xD Quote Share this post Link to post Share on other sites
joshibeast 74 Posted February 27, 2015 Ja baš nemam problema sa JTD-om ali kao što Kuvaja kaže, hoće i on da se ugasi, pogotovo kada je hladan.Hoće li da ide tvoj Stilo bez gasa po ravnom?Ja npr nikada nisam kretao pod ručnom, osim na polaganju. Odmah me je pokojni ćale naučio foru sapetom na kočnici.Sa dizelom mislim da mi ide još lakše to polaženje nego sa benzincem jer ovaj čupa čim uhvati lamela.Inače, kada mi se prvi put dizel ugasio imao sam osećaj da mi je ispao motor Quote Share this post Link to post Share on other sites
Markobgd 609 Posted February 27, 2015 Meni je Lybra zadnjih meseci poskakivala pri kretanju ako za nijansu ne dam jači gas nego što bi se očekivalo. Da kreneš bez gasa nije bilo šanse rekao bih. Skoro sam uradio mali servis i uz to je skidan i opran interkuler, bukvalno od tog servisa više takvih problema nemam. Lično ne verujem da to ima ikakvu vezu međusobno ali do te mere je sve došlo na ono kako i treba da bude (i kako je bilo pre pojave problema) da ne znam kako bih objasnio drugačije. Danas sam baš testirao pošto sam je vozio ceo dan a juče mi ova tema zapala za oko, krenuo sam bar 15puta bez gasa i niti jednom nije bilo problema. Naravno ni pri normalnom polaženju nema podrhtavanja. Da li je i šta naleglo u međuvremenu ne znam ali eto moje iskustvo. A bio sam se već raspitivao za set kvačila, sad će da sačeka... Quote Share this post Link to post Share on other sites
lakicevicboris 7 Posted April 14, 2015 Poz All, na mom Stilu (1.9 JTD 85/115) u zadnje vreme primetim da ide teze u prvu brzinu, ne proklizava pri kretanju, dobro vuce, a kvacilo odvaja nisko (mozda 3-5 cm od poda). Ne manifestuje se uvek ovo tesko uubacivanje ali recimo jednom dnevno, i nije bitno dal je to odmah ujutro ili uu toku dana. Nekad prodje i dan dva da je sve ok. Dal to mirise da je vreme da se menja set kvacila ? Quote Share this post Link to post Share on other sites
deki87 7 Posted April 14, 2015 Verovatno se ukopala korpa...vozi i ne diraj dok ide jedino ako ti se ne bacaju 250e... Verovatno se ukopala korpa...vozi i ne diraj dok ide jedino ako ti se ne bacaju 250e... Quote Share this post Link to post Share on other sites
lakicevicboris 7 Posted April 14, 2015 Bogami ne baca mi se lovaaaa, da ima viska onda da ovako ........ Quote Share this post Link to post Share on other sites
sale vs 0 Posted April 24, 2015 jel moze neko da mi proveri broj sasije za stila ZFA19200000461548 Quote Share this post Link to post Share on other sites
rkoma1986 1109 Posted April 24, 2015 Broj sasije ti je ZFA19200000461548 Quote Share this post Link to post Share on other sites
