TOGO 0 Posted April 22, 2009 Imaš na foto berzi 18-135 za 200 eurića, a povremeno i 18-105 VR (iz D90 kita) po istoj ceni Quote Share this post Link to post Share on other sites
Vukasin 0 Posted April 22, 2009 A taj nije VR? Nista onda od pregovora Prvo ja da uzmem 35mm f1.8, a posle cemo lako ostalo Quote Share this post Link to post Share on other sites
Damjanović 9 Posted April 23, 2009 Ajde i ja da "metem" moju sliku. Slikano prošle godine u januaru, na Temzi. Njihov rečni galeb...Slikano fuji-jem S5700.bio sam danas malko u prirodi...ima malo sigme 90mm f2.8 macro i nikon 55-200vrBravo majstore! Quote Share this post Link to post Share on other sites
Manfred 2 Posted April 23, 2009 Posle konsultacije sa "profesorom" kritike su sledece: "sa umetnicke strane ok odradjeno, ispostovano sve kako treba, sa tehnicke strane nije, blenda treba malo da se zatvori na 5.6 do 8 zbog vece zone dubinske ostrine"btw.. bice toga josh Quote Share this post Link to post Share on other sites
chikavili 511 Posted April 23, 2009 Lako ti je (ili nije) kad ti "profesor" non-stop visi nad glavom Quote Share this post Link to post Share on other sites
Manfred 2 Posted April 23, 2009 Nikako mi nije lako Taman pomislim da nesto uradim kako treba, on odmah nadje bar jednu zamerku... znaci istina. Foto filteri spadaju u kategoriju luxuzne robe u nasoj Imperiji, pa su shodno tome i odgovarajuce oporezovani...Adding a couple of filters makes a huge difference in photography. Spend a couple of hundred dollars on the right filters and, used properly, they can make a huge improvement in your images. I haven't shown how boring or bad some of the images below would have been without the polarizer or the grad ND. This is far more important that spending an extra thousand dollars on a fancier camera. When "The Blair Witch Project" stunned Hollywood with its success after being shot with a $300 video camera, the film maker was asked how he did it. "$600 worth of filters" was his answer. Necu da prevodim jer izgubi char onoga sto je covek hteo da kaze.. Quote Share this post Link to post Share on other sites
chikavili 511 Posted April 23, 2009 ima dosta smisla u tome.ja hteo da kupim neki CPL i vidim da se hoye, fujiyame i slicno krecu oko 55-70€ za 72mm, ali mi vec nekoliko ljudi reklo nesto u smislu "nemoj, to ne valja. treba ti neki ozbiljniji od bar 100€"E sad, ja kod nasih dilera ne videh te "ozbiljnije" vec samo ove "jeftine"A i mislim da cu u ovom trenutku pre te novce dati za xenone, nego za filter Quote Share this post Link to post Share on other sites
Manfred 2 Posted April 23, 2009 kvalitet filtera se razlikuje u tome da li je "uncoated", "single coated" ili "multi coated".. naravno multi coated je i najbolji, a koliko to moze da se nadje kod nas, ja pojma nemam. kako sam video kod nas su uglavnom uncoated i singlecoated...takodje hoya pravi multi coated u par razlicitih kvaliteta.. HMC (hoya multi coated), DMC (digital multi coated), Super HMC i Sperb (8 slojeva)... iskreno, ne verujem da kod nas ima to da se kupi..ali da filter znachi... znachi! Quote Share this post Link to post Share on other sites
Manfred 2 Posted April 23, 2009 iste fotke samo malkice doteran kontrast, nikakve druge obrade...i leptir cropovan i doteran kontrast.. Quote Share this post Link to post Share on other sites
Punto Abarth 18 Posted April 23, 2009 daj neke druge slike, nemoj samo cvetice i bube kao svako ko se dokopa digitalca... Znam niz ljudi koji su tako poceli, i dalje im je jedini razvoj u fotografiji bio jurenje megapixela i skidanje suma u ps-u.Daj ljude, kola, arhitekturu, akciju, prirodu... Pa da se ne zalecemo sa komentarima. Quote Share this post Link to post Share on other sites
chikavili 511 Posted April 23, 2009 Jedna od mojih omiljenih Quote Share this post Link to post Share on other sites
Manfred 2 Posted April 23, 2009 portret... takodje kontrast samo.. Quote Share this post Link to post Share on other sites
chikavili 511 Posted April 23, 2009 ...i jos jedna Quote Share this post Link to post Share on other sites
Manfred 2 Posted April 23, 2009 vili postavi POST Office Quote Share this post Link to post Share on other sites
Punto Abarth 18 Posted April 23, 2009 portret (prva slika) je vise nego korektan sa strane kompozicije, a tehnika moze jos da se dotera. Ali to je manje bitno. Fina slika. Quote Share this post Link to post Share on other sites
Manfred 2 Posted April 23, 2009 hvala hvala... jos nesto mozda interesantno... Quote Share this post Link to post Share on other sites
Punto Abarth 18 Posted April 23, 2009 zasto takav krop?Pocinjem da smaram i sam sebe, ne komentarisem vise dok ne dopremim svoje slike... Quote Share this post Link to post Share on other sites
Manfred 2 Posted April 23, 2009 heheh.. ma komentarisi slobodno.. krop je zbog uslova i kadra. Quote Share this post Link to post Share on other sites
Punto Abarth 18 Posted April 23, 2009 verovatno je bilo nesto viska na slici? Inace, ne vidim zasto bi ga toliko sekao... Quote Share this post Link to post Share on other sites
Manfred 2 Posted April 24, 2009 bilo vishka.... Quote Share this post Link to post Share on other sites
the_reaper 2 Posted April 24, 2009 djenka ova ti je ozbiljna Quote Share this post Link to post Share on other sites
igors 0 Posted April 24, 2009 Evo i par mojih slicica.. Quote Share this post Link to post Share on other sites
chikavili 511 Posted April 24, 2009 vili postavi POST Office Quote Share this post Link to post Share on other sites
Punto Abarth 18 Posted April 25, 2009 Evo nesto i od mene: Quote Share this post Link to post Share on other sites
Punto Abarth 18 Posted April 25, 2009 Pa ako budes zainteresovan za prodaju 18-135, javi jesi ti mozda zainteresovan za kupovinu IX-Nikkor 24 - 70mm f 3.5 - 5.6?Izgleda da ne navedoh, imam i ovo (i jos 3, 4 druga, al to su banane):najverovatnije cu ga prodavati... Quote Share this post Link to post Share on other sites
