ortakov 579 Posted September 19, 2020 Patent olovka - minerica 3 Zan Batist, knezevic76 and neshtry reacted to this Quote Share this post Link to post Share on other sites
neshtry 14512 Posted September 19, 2020 kliker Quote Share this post Link to post Share on other sites
ortakov 579 Posted September 19, 2020 On 9/19/2020 at 11:07 PM, neshtry said: kliker Ma nije kliker, minerica Quote Share this post Link to post Share on other sites
knezevic76 6884 Posted September 20, 2020 On 9/19/2020 at 9:41 PM, ortakov said: Patent olovka - minerica Što nereče, imam ja špijune za zazore. Quote Share this post Link to post Share on other sites
ortakov 579 Posted September 20, 2020 (edited) @knezevic76 Hvala kone Nešto me uhvatilo, rešio sam da pretresem ženin auto, to niko nije ni čistio, ni proveravao, ništa. Jednom godišnje ulje i filteri i to je to. Sad sam krenuo, prvo svećice, ulje i filteri, a u toku nedelje kočnice, antifriz, termostat ... 9 - 10 godina, od koga je (fiat) za koga je (moja žena), ODLIČAN I to ću sve u samostalnoj režiji da radim Edited September 20, 2020 by ortakov 1 knezevic76 reacted to this Quote Share this post Link to post Share on other sites
Spooky.BRE 1 Posted October 5, 2020 Koje svecice su dobre za Punto mk1 55 (1.1) '98 godiste ? Hvala unapred Quote Share this post Link to post Share on other sites
Nikola 1.6 257 Posted October 9, 2020 (edited) Nisam uspeo da nadjem temu vezano za tipove svecica pa cu pitati ovde, admin neka pomeri temu ako smeta. Za vikend planiram da uradim servis u kucnoj radinosti, e sad prosli mali servis kad sam radio rekli su mi da su svecice pri kraju i da moram da ih menjam na sledecem. Kod mene idu NGK IKR9J8 i Denso IXU27. Koja je razlika izmedju ta dva proizvodjaca? Da li vredi razlika u ceni od 600 dinara po komadu. Edited October 9, 2020 by Nikola 1.6 Quote Share this post Link to post Share on other sites
horvat 6451 Posted October 9, 2020 Idi bolje na NGK. Bilo je slucajeva da je Denso pukla, pa napravila belaj u cilindru... 1 1 Nikola 1.6 and Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
neshtry 14512 Posted October 9, 2020 Ja sam čak sačekao 2 dana dok su stigle ngk... Meni denso ne radi ni na Stihl motornoj testeri..Morao sam po Champion u Osijek Quote Share this post Link to post Share on other sites
Nikola 1.6 257 Posted October 9, 2020 Oke znaci da idem u mass, hvala 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
mlnmnc 8 Posted May 20, 2021 Koje svećice da kupim za auto iz potpisa? Prošli put sam ih menjao 2018. zato što mi je štucao auto, nije lepo vukao i prilikom zamena svećica taj problem je nestao, ali sada se ponovo javio... Šta predlažete, dao bih i koji dinar više samo da budu kvalitetne. I da li nakon 3 godina moraju da se menjaju svećice ili sam ja naleteo na neki krš? Quote Share this post Link to post Share on other sites
Milutinac 5905 Posted May 20, 2021 Samo NGK. Trebala bi biti bkr5ez oznaka 1 mlnmnc reacted to this Quote Share this post Link to post Share on other sites
mlnmnc 8 Posted May 20, 2021 Do sada sam imao Denso XU22EPR-U, koje sam platio 580 dinara po komadu. Koje su bolje, Denso ili NGK? Quote Share this post Link to post Share on other sites
Milutinac 5905 Posted May 21, 2021 19 hours ago, Milutinac said: Samo NGK Quote Share this post Link to post Share on other sites
horvat 6451 Posted May 21, 2021 21 hours ago, mlnmnc said: I da li nakon 3 godina moraju da se menjaju svećice ili sam ja naleteo na neki krš? Interval zamene svecica se meri iskljucivo u kilometrima, koliko ja znam... Quote Share this post Link to post Share on other sites
Rile_bg 347 Posted May 21, 2021 Za 1.2 16v ide DCPR8E-N, 5692 1 Axic reacted to this Quote Share this post Link to post Share on other sites
mlnmnc 8 Posted May 25, 2021 On 5/21/2021 at 4:37 PM, Rile_bg said: Za 1.2 16v ide DCPR8E-N, 5692 Kupio sam te i postavio ih i sad mi se na momente uključuje check engine, koji mi se nikad nije uključivao od kad imam auto a to je od 2013... A štucanje kad treba da ubrza iz manje brzine u veću se i dalje nastavlja, sad još gore nego sa starim svećicama... Quote Share this post Link to post Share on other sites
kakoonobese 43 Posted May 26, 2021 Jesi li menjao kablove? Quote Share this post Link to post Share on other sites
mlnmnc 8 Posted May 26, 2021 31 minutes ago, kakoonobese said: Jesi li menjao kablove? Nisam Quote Share this post Link to post Share on other sites
kakoonobese 43 Posted May 26, 2021 To je relativno jeftina i jednostavna intervenciija a pomaže za davanje dijagnoze. Moja praksa je da se priliko svake zamene svećica zamene i kablovi. 1 mlnmnc reacted to this Quote Share this post Link to post Share on other sites
Zan Batist 252 Posted May 26, 2021 prilikom svake zamjene, znaci jednom u 10 godina. Reno 4 vozim evo 30 god., fabricki kablovi i Eyquem svijecice u njega, radi normalno. U pandu 5 godina nisam taka svijecice i kablove. Quote Share this post Link to post Share on other sites
mlnmnc 8 Posted May 26, 2021 8 hours ago, kakoonobese said: To je relativno jeftina i jednostavna intervenciija a pomaže za davanje dijagnoze. Moja praksa je da se priliko svake zamene svećica zamene i kablovi. Sad sam ga vozio malo duže i primetio sam da mi "štuca" samo kada je hladan. Kada se posle zagreje nemam tih problema... Quote Share this post Link to post Share on other sites
kakoonobese 43 Posted May 27, 2021 Ukoliko se uključivao CheckEngine, poželjno je dijagnostikom pročitati o kojoj se grešci radi. To će dati smernice za dalje. Do sada smo razmatrali mogući problem sa svećicama ili kablovima. Ovo što navodiš ukazuje na druge potencijalne uzroke. Mislim da treba suziti uzroke na 2 kategorije: 1. struja (svećice, kablovi ili bobine) 2. napajanje gorivom/vazduhom (dizne, klapna,....) Prvo, nije otklonjena sumnja da su u pitanju svećice ili kablovi, Svećice su menjane pa je ta mogućnost manje verovatna ali je ne treba isključiti jer se može desiti da zazori nisu adekvatni ili svećice nisu originalne. Ukoliko imaš stare kablove koji su bili ispravni, ili nekog ko može da ti ih pozajmi, lako se može utvrditi da li oni prave problem. Kada su u pitanju bobine, opet je najlakše uzeti/pozajmiti jednu za probu. One ne moraju de se skidaju/montiraju u svrhu testa. Dovoljno je da se prebace kablovi sa stare na novu i da se tako proba. Ako se ne varam, postoje 2 bobine koje su identične pa test treba uraditi maksimalno 2 puta (za svaku bobinu). Idealna situacija je da se iz prve pogodi problematična bobina (ako je ona problem) i da se izbegno dalje testiranje. Nemamo informacije o prethodnim intervencijama na sistemu napajanja gorivom/vazduhom. Ukoliko su u neko skorije vreme čišćene dizne, mogao bi se isključiti i taj uzrok. Po pitanju dotoka vazduha, uvek je moguće proveriti zaprljanost klapne i po potrebi naprskati CarbCleaner . Tom prilikom naprskati detaljno sve šupljine i klapnu sa obe strane. Ostavi se da odstoji 10-ak minuta pa se postupak ponovi (ukoliko je bilo jako zaprljano). Nemoj da te iznenadi teže paljenje motora nakon ovog tretmana i kratkotrajan nepravilan rad. To traje dok se ne eliminiše CarbCleaner pa se rad motora automatski stabilizuje. Postoji tema u kojoj je objašnjena kalibracija parametara usisa vazduha (mislim da se pritisne gas da ide do 4000 obrtaja na nekoliko sekundi , i tako 2-3 puta). Raspisao sam se, a ne znam da li je ovo uopšte od bilo kakve pomoći....... Quote Share this post Link to post Share on other sites
Jackkk 108 Posted May 27, 2021 15 hours ago, mlnmnc said: Sad sam ga vozio malo duže i primetio sam da mi "štuca" samo kada je hladan. Kada se posle zagreje nemam tih problema... Proveri dizne obavezno. Pre par godina sam imao sličan problem. Auto je povremeno štucao, ja uradim mali servis, zamenim svećice i kablove usput i ne rešim problem. Par dana posle malog servisa upali se check engine a auto pocne nenormalno da trokira i štuca. Jedna dizna je skroz otišla, ostale su bile ok, svakako sam zamenio sve 4 i problem je nestao. Quote Share this post Link to post Share on other sites
