golf sdi 2 Posted September 17, 2015 Kao što kolega reče,servis u Pinosavi kod Dragomira je na glasu kao jedan od najboljih i najkorektnijih,pa neka čovek obavezno reklamira. Quote Share this post Link to post Share on other sites
Markobgd 609 Posted September 17, 2015 (edited) Ma čuo se on sa njima već sigurno...nek rešavaju, dogovaraju...Meni je samo bezveze momenat da se tako na prvu menja set sa sve zamajcem i da se ispostavi da i sa novim ista stvar....najlakše je menjati redom. (i najskuplje obično) Edited September 17, 2015 by Markobgd Quote Share this post Link to post Share on other sites
milan_gt 0 Posted September 17, 2015 I ja imam sve pohvale za Dragomira i servis u Pinosavi Quote Share this post Link to post Share on other sites
totti 13165 Posted September 17, 2015 Ma čuo se on sa njima već sigurno...nek rešavaju, dogovaraju...Rešiće I ja imam sve pohvale za Dragomira i servis u PinosaviVidi ovog što mu samo pertle vire Quote Share this post Link to post Share on other sites
milan_gt 0 Posted September 17, 2015 (edited) Pa kad covek pravi dobar rostilj Edited September 17, 2015 by milan_gt Quote Share this post Link to post Share on other sites
igor0511 2882 Posted September 17, 2015 Jal to onaj Bosanac iz Pinosave?Kolega se kune u njega Quote Share this post Link to post Share on other sites
skile86 539 Posted September 17, 2015 Cudi me da nisu videli da nije u setu kvacila problem kad su ga skinuli... Quote Share this post Link to post Share on other sites
igor0511 2882 Posted September 18, 2015 Ja sam došao do jako zanimljivog zaključka pa bih vas molio da neko potvrdi/demantuje Da li je tačno da se ecu resetuje pri bilo kom upisu mape?Sve mi se čini da je tako. A ako sam u pravu ne bi bilo zgoreg na starim kolima čak i ponovo upisati istu mapu, čisto da se ecu malo resetuje. Quote Share this post Link to post Share on other sites
MS PK 7732 Posted September 19, 2015 Ima logike Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted September 19, 2015 Ma kakav reset ecua, prilikom upisa mape se ni bord ne resetuje Da se stvarno resetuje ecu izgubio bi vreme, datum i trazio bi kod za fabricki radio, a to se nikom nije desilo prilikom upisa mape, makar ne da sam ja cuo Quote Share this post Link to post Share on other sites
totti 13165 Posted September 19, 2015 Pa šta ima da ga resetuješ... Nije to Android Quote Share this post Link to post Share on other sites
igor0511 2882 Posted September 19, 2015 Ma kakav reset ecua, prilikom upisa mape se ni bord ne resetuje Da se stvarno resetuje ecu izgubio bi vreme, datum i trazio bi kod za fabricki radio, a to se nikom nije desilo prilikom upisa mape, makar ne da sam ja cuo Tačno, ali da li si 100% siguran da se potrošnja, kod radia i vreme čuvaju u ecu-u? Recimo meni je resetovana potrošnja pri promeni cajgera iako je rađeno bez skidanja akumulatora. @Totti pa realno nema smisla da se ecu zaglupi, ali nekako imam osećaj da se to kod mene desilo Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted September 19, 2015 Ma kakav reset ecua, prilikom upisa mape se ni bord ne resetuje Da se stvarno resetuje ecu izgubio bi vreme, datum i trazio bi kod za fabricki radio, a to se nikom nije desilo prilikom upisa mape, makar ne da sam ja cuo A kakve veze ima motorni komp sa satom, radiom i predjenom kilometrazom?Uzmi skini motorni i vrati i nece se nista resetovati, te stvari nisu povezane sa motornim, nego sa body-em. Quote Share this post Link to post Share on other sites
igor0511 2882 Posted September 19, 2015 Eto logičnog objašnjenja. Ono što me je navelo da pomislim da se ecu resetuje je to što sam od više ljudi čuo da nakon ponovnog upisa čak i iste mape auto drugačije ide. Quote Share this post Link to post Share on other sites
vicent 1263 Posted September 19, 2015 Body komp. i motorni ECU su dva različia kompa. Sa novom mapom ECU se resetuje. Quote Share this post Link to post Share on other sites
igor0511 2882 Posted September 19, 2015 Zahvaljujem Quote Share this post Link to post Share on other sites
Mahoney 0 Posted September 19, 2015 Nakon zamjene mafa bi bilo pozeljno resetovati ecu,bolje ide Quote Share this post Link to post Share on other sites
vicent 1263 Posted September 19, 2015 Upravo zato se i kaže da remap mora da "legne" kroz par stotina km. ecu nakon izmene mape (ili delova koji daju parametre), usaglašava novo-dobijene vrednosti sa ostatkom hw i sw.Resetovanje nakon zamene map, maf i sl. nije obavezno, jer će sve da se usaglasi nakon par sati rada. Quote Share this post Link to post Share on other sites
Markobgd 609 Posted September 26, 2015 Ma čuo se on sa njima već sigurno...nek rešavaju, dogovaraju...Rešiće I ja imam sve pohvale za Dragomira i servis u PinosaviE sad sretoh komšiju i kaže sve se rešilo uspešno. Išao do njih u servis da prekontrolišu, rekli mu da mora da "nalegne" set i da će problem nestati nakon par stotina km i po njegovim rečima stvarno nestalo proklizavanje!? Šta je, kako je 'bem li ga ali sve fercera kako treba kaže!Eto da ne ostane na pljuvanju ako za to nema osnova. Quote Share this post Link to post Share on other sites
FantomX 5 Posted September 26, 2015 Mrzi majstore da odmaste zamajac Quote Share this post Link to post Share on other sites
Markobgd 609 Posted September 26, 2015 (edited) Misliš da je to moguć problem? Nikada mi ne bi palo napamet! Edited September 26, 2015 by Markobgd Quote Share this post Link to post Share on other sites
FantomX 5 Posted September 26, 2015 Naravno, desava se. Drugo, zamajac ostaje stari, treba 200/300km da lepo nalegne nova lamela na malo krivudav zamajac Quote Share this post Link to post Share on other sites
Markobgd 609 Posted September 26, 2015 (edited) To drugo je normalno, kao i kod zamene pločica. Biće onda da je komšija samo bio nestrpljiv sa potezanjem auta. Edited September 26, 2015 by Markobgd Quote Share this post Link to post Share on other sites
FantomX 5 Posted September 26, 2015 Bas tako, nece bas odmah po gasu da drzi nakon zamene, mada mu je pomogao da se brze razradi Quote Share this post Link to post Share on other sites
