Mateja_ 10 Posted November 7, 2025 Da li nakon zamene serva mora da se radi proxy alignment? punto 1.3 mjet 2003. Quote Share this post Link to post Share on other sites
Sinisa011 13 Posted November 7, 2025 Posle zamene senzora ugla volana mora da se radi kalibracija. Ali za promenu motorića serva po meni ne treba. Pitaj jos nekog. 1 Axic reacted to this Quote Share this post Link to post Share on other sites
neshtry 21988 Posted November 8, 2025 (edited) Mora kalibracija i mora proxy Edited November 8, 2025 by neshtry 1 Mateja_ reacted to this Quote Share this post Link to post Share on other sites
Zan Batist 517 Posted November 10, 2025 ne mora proxy, mijenjao na pandu kad sam je kupio, samo adjustment. Quote Share this post Link to post Share on other sites
Goran Zemun 498 Posted November 10, 2025 5 hours ago, Zan Batist said: ne mora proxy, mijenjao na pandu kad sam je kupio, samo adjustment. Koja je sličnost u elektro volanu Punta i Pande? Quote Share this post Link to post Share on other sites
Zan Batist 517 Posted November 10, 2025 5 minutes ago, Goran Zemun said: Koja je sličnost u elektro volanu Punta i Pande? osjecam prekor u pitanju. Odgovor: oba koriste el motor u stubu volana i senzor pozicije volana. Quote Share this post Link to post Share on other sites
Goran Zemun 498 Posted November 10, 2025 15 minutes ago, Zan Batist said: osjecam prekor u pitanju. Odgovor: oba koriste el motor u stubu volana i senzor pozicije volana. Ma neeee....nisam hteo nikog da prekoravam. Samo hocu da kažem da ova dva vozila nose potpuno različite sisteme elektro volana. Bas nista nije isto. Isto tako procedure nisu iste. Quote Share this post Link to post Share on other sites
Zan Batist 517 Posted November 10, 2025 Dakle, za zamjenu senzora pozicije volana na puntu mk2, kolko kapiram @Mateja_ to pita, treba proxy aligment? 1 Mateja_ reacted to this Quote Share this post Link to post Share on other sites
Goran Zemun 498 Posted November 10, 2025 1 hour ago, Zan Batist said: Dakle, za zamjenu senzora pozicije volana na puntu mk2, kolko kapiram @Mateja_ to pita, treba proxy aligment? Pitanje se odnosilo na ceo servo a ne na senzor. Pročitajte pitanje od početka. 1 Mateja_ reacted to this Quote Share this post Link to post Share on other sites
Mateja_ 10 Posted November 11, 2025 Da na ceo servo ne na senzor Quote Share this post Link to post Share on other sites
Goran Zemun 498 Posted November 11, 2025 16 minutes ago, Mateja_ said: Da na ceo servo ne na senzor Kada menjate ceo servo trebalo bi uraditi proxi. Zato sto menjate i centralu. 1 Mateja_ reacted to this Quote Share this post Link to post Share on other sites
Mateja_ 10 Posted November 11, 2025 Hvala puno na odgovoru Gorane. :))) Quote Share this post Link to post Share on other sites
shuxx 24410 Posted December 11, 2025 Na mom Z10, se povremeno ukoči volan, i izbaci grešku za servo. E sad, to isto i nestane posle nekog vremena, ili posle gašenja motora. Otac vozi auto, i do sad mu se dva puta desilo. Da li je to crkavanje u najavi.... Quote Share this post Link to post Share on other sites
Milos1 759 Posted December 11, 2025 @shuxx Ako je pocelo da se desava sad sa hladnim danima prvo fokus na akumulator i punjenje. Ako je to okej onda da, prvi simptomi, verovatno senzora polozaja volana. Z10 je punto mk2b a oni mislim da nemaju releje koji su na prethodniku bili mana pa motor crkava prakticno nikad 1 shuxx reacted to this Quote Share this post Link to post Share on other sites
shuxx 24410 Posted December 12, 2025 Bre meni se slično desilo pre 2 gos. Ali nije bio vožen dugo, pokriven ceradom. Možda neka vlaga. Ocu se dešava posle 29 km vožnje, kad ode do sela. Kad dođe kući i ja ga proverim sve ok. Setih se da je možda do akumulatora, pa sam ga dopunio. Ima i on nekih 4 god. Z10 je 2007 godište... Italijan, ne pravljen u srb. Quote Share this post Link to post Share on other sites
MiloshBg 3149 Posted December 12, 2025 Alternator i akumulator prva stvar za proveru. 3 Milos1, Axic and shuxx reacted to this Quote Share this post Link to post Share on other sites
shuxx 24410 Posted December 12, 2025 Aj to rešavam za vikend Quote Share this post Link to post Share on other sites
Milos1 759 Posted December 12, 2025 (edited) Pazi, ako ima 4god to im je otprilike i vek danas. A to sto ga napunis ne mora da znaci da je dobar, opadne mu startna struja tek toliko da na ostrim motanjima, u piku kad servo povuce najvise struje, servo zeza. Na nekom vagenu sa elektro/hidraulicnim servom dzabe radili remont alternatora jer je akumulator bio los bez vidljivih naznaka. Palio je i vruc i hladan na zub, verglao po zvuku odsecno i veselo, napon dobar, sve dobro, ali na vecim motanjima se desi da oteza volan, pocne da secka u voznji i na dijagnostici se videlo da napon pada i na 10,5v cak tad. To je zato sto, kad su popaljeni svi potrosaci, alternator ne moze da odrzi te velike pikove vec akumulator mora da preuzme na sebe i da koliko treba u tim milisekundama, ispegla napon i posle se opet normalno dopuni. Kad on izgubi udarnu struju komp se zbuni za vreme tih pikova, a posle kad ti meris deluje sve normalno. Posle remonta kad se problem nastavio na reklamaciji kod elektricara, onaj nije hteo ni da ga pogleda, samo kaze "onda nov akumulator i vozi". Tako je i bilo, godinu dana vise nikad nije trznuo Zato imas one price da na novije automobile ne smeju oni najjeftiniji akumulatori, i to je u neku ruku tacno, jer skuplji premium akumulatori tu udarnu struju uglavnom imaju vecu za isti kapacitet. Zato ja stavim taj jeftiniji ali veci, tako da dobijem i vecu udarnu od tog manjeg skupljeg, i vise rezervnog kapaciteta i nema brige Na puntisi sam skinuo plastike i stavio 60-icu i preporodio se po pitanju struje u odnosu na malog fabrickog prdavca 40-icu Edit: a i sam si sebi odgovorio za situaciju od pre 2 godine, tad nije bio dugo vozen(ispraznio se aku, malo izvukao motorni racunar) i odmah zezao servo. Puntici su bas osetljivi na slab akumulator. Sad mozes imati isti efekat iako se vozi svakodnevno ako je oslabio, a da se po verglanju i ne primecuje Idi do nekog akumulator servisa, oni mogu da ti testiraju CCA(cold cranking amps) njihovim aparatom i odmah kazu dal je do toga Edited December 12, 2025 by Milos1 1 shuxx reacted to this Quote Share this post Link to post Share on other sites
shuxx 24410 Posted December 12, 2025 Otići će tatko do servisa za akumulatore da ga provere, alternator i anlaset servisirani prošle god ili preprošle. Znaću uskoro da li je do njih. Quote Share this post Link to post Share on other sites
MiloshBg 3149 Posted December 12, 2025 Na tim starijim vozilima taj elektro servo je ubedljivo najveci potrosac. 1 shuxx reacted to this Quote Share this post Link to post Share on other sites
shuxx 24410 Posted December 12, 2025 Majstor rekao da je loš akumulator. Kod mene je 4 god, ali je bio star 1 god kad je kupljen. Kupljen nov, pa će vidimoooo 1 Milos1 reacted to this Quote Share this post Link to post Share on other sites
Axic 24198 Posted December 12, 2025 On 12/11/2025 at 10:24 PM, shuxx said: Na mom Z10, se povremeno ukoči volan, i izbaci grešku za servo. E sad, to isto i nestane posle nekog vremena, ili posle gašenja motora. Otac vozi auto, i do sad mu se dva puta desilo. Da li je to crkavanje u najavi.... Verovatno jeste, tako je i kod sestre počelo. Nov akumulator, uradjen komplet alternator ali jednostavno sve češće je počeo da pali crvenu lampicu i stvrdne volan. To bar danas nije skupo, zameni i teraj dalje. Quote Share this post Link to post Share on other sites
