salevs 11 Posted October 31, 2022 Majstor je iz vršca, iva električar imaš na google br tel 1 Sinisa011 reacted to this Quote Share this post Link to post Share on other sites
kakoonobese 43 Posted November 4, 2022 Popravljeno kod Milosa Viline vode. Cena je 16000 dinara. Milos je super lik ! Preporucujem ga.... 1 vicent reacted to this Quote Share this post Link to post Share on other sites
dudule1 0 Posted November 26, 2022 Fiat punto kragujevacki 1.3 mtj...kada sam placao parking karticom, naletim levim tockom i ocesem od ivicnjak i od tada mi vuce u desnu stranu.....sta bi moglo biti....da li mogu da resim tom kalibracijom i ko to radi ili je nesto drugo u pitanju. ....da se nije iskrivila guma ....gde ti mogu da proverim ...da nije nesto otislo na trapu Quote Share this post Link to post Share on other sites
neshtry 14852 Posted November 26, 2022 (edited) Za početak idi kod trapadžije,pa će te on već uputiti gde treba Edited November 26, 2022 by neshtry 1 nemanja84bg reacted to this Quote Share this post Link to post Share on other sites
dudule1 0 Posted November 27, 2022 On 11/4/2022 at 12:48 PM, kakoonobese said: Popravljeno kod Milosa Viline vode. Cena je 16000 dinara. Milos je super lik ! Preporucujem ga.... Jel imate kontakt Quote Share this post Link to post Share on other sites
kakoonobese 43 Posted November 30, 2022 0658006818 Quote Share this post Link to post Share on other sites
Rexona 0 Posted November 30, 2022 Evo i ja da napisem nesto. Meni je takodje senzor ugla volana menjao Iva iz Vrsca i kostao je nov 9500 din. plus nekih 30e za ruke. Majstor rece da se ugao volana pravi u Meksiku, a obavezno traziti garanciju jer imate 2 godine na sam ugao volana. Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted March 11, 2023 Mozda je malo off, ali ima veze sa volanom. Jel moze neko da mi kaze koliko krugova se vrti volan Puntu 2? Quote Share this post Link to post Share on other sites
Axic 20048 Posted March 13, 2023 @YUgisa mislis od sredine pa kad namotas levo ili desno koliko krugova se okrene volan do punog namotaja ? 1 YUgisa reacted to this Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted March 13, 2023 Da ili ukupno sa skroz levo na skroz desno Quote Share this post Link to post Share on other sites
Aleksaa 0 Posted July 24, 2023 Zdravo ljudi imam problem fiat grande punto menjana je letva volana i volan je poludeo namotam pun desni i sam namota pun levi. Tvrde da treba kalibracija da se odradi. Da li je neko imao slican slucaj? Quote Share this post Link to post Share on other sites
MiloshBg 1020 Posted July 25, 2023 Mora kalibracija! 2 Aleksaa and MS PK reacted to this Quote Share this post Link to post Share on other sites
puntitj 0 Posted July 30, 2023 Drago forumaši Mislim da moj problem treba da postavim ovde. Ne mogu volanom da skrenem udesno! Udara u kraj. Dakle, mogu pun ulevo, da ispravim - ali ni makac udesno. Da napomenem da je moj Punto 2 iz 2001. i NEMA SERVO! Quote Share this post Link to post Share on other sites
Milos1 43 Posted July 30, 2023 Nesto sa letvom volana najverovatnije. https://novi.kupujemprodajem.com/automobili-delovi-i-alati/auto-volani-i-upravljanje/fiat-punto-188-99-12-letva-volana-bez-serva/oglas/94328888?filterId=2411146611 Polovne su 25-30e, fala bogu rasprostranjen je auto, ima ih dosta i u delovima tako da bi trebalo relativno povoljno da resis problem 1 puntitj reacted to this Quote Share this post Link to post Share on other sites
puntitj 0 Posted July 30, 2023 1 minute ago, Milos1 said: Nesto sa letvom volana najverovatnije. https://novi.kupujemprodajem.com/automobili-delovi-i-alati/auto-volani-i-upravljanje/fiat-punto-188-99-12-letva-volana-bez-serva/oglas/94328888?filterId=2411146611 Polovne su 25-30e, fala bogu rasprostranjen je auto, ima ih dosta i u delovima tako da bi trebalo relativno povoljno da resis problem hvala ti samo još jednu sumnju da otklonim ako nemam servo - da li to znaci da nemam ni taj senzor ugla volana? Quote Share this post Link to post Share on other sites
Milos1 43 Posted July 30, 2023 Tako je, cista mehanika. 1 puntitj reacted to this Quote Share this post Link to post Share on other sites
Swiper 2 Posted September 4, 2023 Pozdrav svima, Imam nedoumicu, danas sam bio kod jednog majstora da mi ocita preko dijagnostike gresku i izbacilo je sledece (slika). E sad, sta moze da bude problem? Ovo nije moj auto, ne vozim ga cesto ali me tasta zamolila da ga sredim kod majstora Naime, cesto se desava da odjednom ne radi senzor. Ne znam tacno kada i kako, ja retko vozim taj auto i desilo mi se jednom da nakon paljenja ne radi, ugasim i upalim auto i proradi. Da li napamet menjati senzor ili pak probati sa nekim majstorom koji se razume u materiju i da isproverava preko dijagnostike i proba da podesi, odradi kalibraciju ili sta vec pre samog menjanja. Ja sam iz Nisa i ne poznajem nijednog takvog. Pitao sam isto i mog autoelektricara i on mi telefon rekao da se menja senzor Auto je inace Zastava 10 1.2 8V. Hvala unapred. Quote Share this post Link to post Share on other sites
neshtry 14852 Posted September 4, 2023 Menjati pod hitno,može da radi tako,a možeš da završiš i u kanalu porad puta vrlo lako… Evo ti broj od našeg Gorana i INK do teme na forumu Quote Share this post Link to post Share on other sites
Swiper 2 Posted September 4, 2023 3 hours ago, neshtry said: Menjati pod hitno,može da radi tako,a možeš da završiš i u kanalu porad puta vrlo lako… Evo ti broj od našeg Gorana i INK do teme na forumu Stvarno moze da se desi da zablokira volan zbog tog senzora? Quote Share this post Link to post Share on other sites
tvzmaj 39 Posted September 4, 2023 2 hours ago, Swiper said: Stvarno moze da se desi da zablokira volan zbog tog senzora? Pre ce da ti otpadne tocak nego da ti se desi da zablokira volan zbog senzora. Kada servo otkaze u voznji volan ide teze a nekad se oseti i imupls trzaja koji (mozda) moze da zbuni neukog vozaca pa da nastavi pravo. Kod Punta se to desava i kada je sve ispravno. U uputstvu za koriscenje pise ako vam se upali lampica servo, lampica imobilajzera... itd - ugasite pa upalite auto. To se veoma retko desava i na 100% ispravnom autu, ali se desava i opisano je u uputstvu. Inace da senzor zablokira volan, bregastu, radilicu nema mogucnosti. Nije to lager. Senzor volana menjate kada ste 100% sigurni da je do njega. Ja za malo da ga zamenim, no kako sam izdzekao sve iz kompjutera za servo i ukljucio vise nemam problema. Quote Share this post Link to post Share on other sites
neshtry 14852 Posted September 5, 2023 senzor hoće da skreće u stranu bez kontrole( jer šalje loše informacije upravljaču) a motor kada crkne oteža volan Quote Share this post Link to post Share on other sites
Swiper 2 Posted September 12, 2023 Zamenio sam senzor, videcemo kako ce da se ponasa. Video sam na netu (YT) da je lik rastavio senzor i da ga je lepo ocistio i da radi kako treba. Tako da, ako neko hoce da otvara i cisti imam jedan za njega 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
alfini0507 1653 Posted September 12, 2023 Daj link tog YT linkaSent from my Redmi Note 9 Pro using Tapatalk Quote Share this post Link to post Share on other sites
Swiper 2 Posted September 13, 2023 1 alfini0507 reacted to this Quote Share this post Link to post Share on other sites
adex01 0 Posted September 21, 2023 Pozdrav, jucer mi se desilo pri punom motanju da je volan trznuo malo i potpuno otezao, kad se ugasi i ponovo upali sve je normalno. Testirao sam ga i svaki 4-5x pri punom motanju volan se trgne i oteza. Vidio sam da ima dosta takvih slucajeva, ali ne mogu nikamo upratiti šta se ispostavio kao problem Quote Share this post Link to post Share on other sites
