ForrestGump 6 Posted October 11, 2015 Planiram da ugradim ručicu tempomata na moj Stilo. Kada završim, interesuje me da li bi bio voljan da mi FES-om uključiš lampicu na tabli, pošto nemam nikakvu dijagnostiku za Fiat? Quote Share this post Link to post Share on other sites
nemanjas 0 Posted October 11, 2015 ako dolazis nekad u sabac ja cu.Al imas i tu blize nekog javice se neko Quote Share this post Link to post Share on other sites
Ogi 0 Posted October 11, 2015 Moze javi se kad ugradis. Quote Share this post Link to post Share on other sites
ForrestGump 6 Posted October 11, 2015 Dogovoreno, hvala ti unapred. Kad završim kontaktiraću te. Pozdrav Quote Share this post Link to post Share on other sites
Rax011 0 Posted November 2, 2015 Dodji ja cu ti to zavrsiti kolegijalno!Spremi kod karticu ako iskljuci signalizaciju pri proxy proceduri!Pozdrav! Quote Share this post Link to post Share on other sites
c00der 0 Posted November 16, 2015 Ljudi da li zna neko gde mogu da nadjem oblogu volana za novog brava sa mestom za rucicu tempomata ? Quote Share this post Link to post Share on other sites
Ivan 17587 Posted November 16, 2015 Odgovarajuca tema za ovakva pitanja: https://www.fiat-lancia.org.rs/forum/index.php?/topic/41777-gde-mogu-da-kupim/Tema o otpadima i njihovim kontaktima: https://www.fiat-lancia.org.rs/forum/index.php?/topic/5602-fiatlanciaalfa-romeo-otpadi/ Quote Share this post Link to post Share on other sites
statichawk 72 Posted November 17, 2015 Ljudi da li zna neko gde mogu da nadjem oblogu volana za novog brava sa mestom za rucicu tempomata ?Nije bas fabricki, ali moze od alfe tempomat ako ne nadjes tu plastiku Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted December 23, 2015 danas uzeo tempomat, da li ima neko ljubazan sa foruma ko bi mi preko dijagnostike aktivirao temp? ja imam FES, ali onaj sa blututom i nece da se konektuje Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted December 24, 2015 Odakle si?Moze neko da ponese na skup pa da ti aktivira... A to mozes da vidis u temi o redovnim okupljanjima....Ako si blizu Batajnice ukljucicu. ti ja Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted December 24, 2015 sa Cukarice sam, nije mi bas blizu Bataja ajde videcu u nedelju ako neko ponese Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted December 30, 2015 sad otisao kod druga da mi prikaci tempomat, ukljucimo ga preko dijagnostike, kad ono nista.. izgleda da ima samo dzek a nema instalaciju do motornog kompa sta sad raditi? Quote Share this post Link to post Share on other sites
MilanStilo 2 Posted December 30, 2015 Nista! Srediti instalaciju do motornog kompa ili prodati rucicu Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted January 2, 2016 Polako sa prodaju i sredjivanje instalacije.Kao prvo on mora da radi i bez aktiviranja dijagnostikom, sa njom se ukljucuke samo lampica na tabli.1.Da li ste pratili na dijagnostici komande da li reaguju, upaljen-ugasen, +-......2.Da li ste pogledali na dijagnostici kako rade prekidaci kocnice i kvacila i da li rade?3. Nemoze da bude samo dzek bez instalacije, mora on na necemu da stoji ali prebroj koliko zica ima na tom dzeku od auta, moze da se desi da ti fali jedna zica, a to mozes naci u ovoj temi, ali moras malo da prelistas.....Javi sta je od svega ovog. Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted January 5, 2016 vratio se Stilo iz CG pa mogu sad da cackam oko tempomata na dzeku imam 5 zica, prekidaci kocnice i kvacila rade, prikljucicu opet tempomat i probati da ga aktiviram u toku voznje pri 60-70 na sat pa javljam sta sam uradio Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted January 5, 2016 (edited) @Kuvalja hvala puno na savetima, uspeo sam jos samo preko dijagnostike da aktiviram Edited January 6, 2016 by neshaoct popravio link za sliku Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted January 8, 2016 za one koji nece da citaju temu od pocetka:-dzek ispod volana-tempomat u dzek-u cetvrtoj i petoj radi samo tempomat-aktivacija preko dijagnostike FIAT > STILO 1.9JTD > Body > CAN Setup / PROXI Alignment Procedure > Adjustments (F7) > Cruise control light > click Execute (F10) > choose: Enabled > go to: PROXI Alignment Procedure > click Execute (F10) > when you got success to all systems than turn the key OFF > wait for 15-30 seconds > turn key ON > turn the cruise switch on aktivirana lampica Quote Share this post Link to post Share on other sites
lakicevicboris 7 Posted January 8, 2016 Moje neko skromno misljenje da tempomat radi preko 40km/h ili 50km/h, a to ne mora biit 4-5 brzina. Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted January 8, 2016 Ja nisam uspeo u trecoj.. Quote Share this post Link to post Share on other sites
nemanjas 0 Posted January 8, 2016 pa nije ti menjac automatik pa da ecu zna u kojoj je brzini,ja bi mogao i u 1 da aktiviram tempomat al moram preko 30km/h da idem Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted January 8, 2016 Pff ovaj moj mjet zna sve Quote Share this post Link to post Share on other sites
Ivan 17587 Posted January 9, 2016 Koliko se secam, brzina mora biti iznad 30 km/h, a menjac u 4. ili 5. stepenu prenosa. Quote Share this post Link to post Share on other sites
Danilo1 1159 Posted January 9, 2016 moja greska, radi i u trecoj preko 40-50km/h Quote Share this post Link to post Share on other sites
Ivan 17587 Posted January 9, 2016 Ja proverih za svaki slucaj, ipak se dobro secam, e sad ako je nesto izmenjeno... Ovo je iz uputstva za Stilo posle restyle: Quote Share this post Link to post Share on other sites
