Zarkusi 2 Posted September 22, 2014 Da li je neko u Nišu voljan i ima opremu da mi upali lampicu za tempomat? Moj vag/kkl kabl ne pristupa body sekciji. Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted September 22, 2014 Da si malo bliži, par minuta posla. Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted September 22, 2014 Eee vidis, kod mene to nije ispelo Na testu lampice - pali se.Uradio proxy i kaze nema sta da pegla. A lampu ne upali kad se upali tempomat Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted September 22, 2014 Uspelo kod kolege Steel-a još mu i alarm proradio. Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted September 22, 2014 Verujem ti. Al eto.... Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted September 22, 2014 Možemo da probamo. Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted September 22, 2014 Mozemo. Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted September 22, 2014 Kolega, ne treba uraditi samo proxy, nego prvo imas da aktiviras lampicu, ENABLE/DISABLE, pa tek onda proxy, evo za tebe sam uradio PS, da vidis gde je sta, dole oznacenim crvenim kvadratom ti je gde sve treba da udjes da bi dotle dosao, a gore strelica da vidis gde se aktivira lampica, pa se onda otvori onaj prozor gde treba da izaberes Enabled. Takodje ako nemas ELM, mozes i na mene da racunas pa ko ti bude blize. edit: mislim da proxy sada ni ne moras da radis, posto je vec odradjen, tako da je CC prijavljen bodiu, mislim da je dovoljno samo ovo sa slike odraditi Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted September 22, 2014 Aaaa pa jesam. Prvo proxy, pa posle ovo, pa testirao lampu, pa opet proxy ali nista....Meni i ne smeta sto ne svetli, ali eto, ako treba da svetli, onda da svetli! Quote Share this post Link to post Share on other sites
Sale2810 4 Posted September 22, 2014 Sve sto treba da svetli,mora da svetli Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted September 22, 2014 Ako imas elm probaj ponovo samo da aktiviras indikator, bez testova i bez proxy-a, pa iskljuci fes, pa skini sa kontakta, onda upali auto i probaj, mora da se negde nesto zabagovalo pa zato nije aktiviralo diodu. Ako nemas elm, kad budes u prolazu javi se da se dogovorimo ili sa Ivanom, ko ti bude blizi. Quote Share this post Link to post Share on other sites
Zarkusi 2 Posted September 23, 2014 A ja da vas cekam na auto putu kad sledece godine krenete u Grcku na more Quote Share this post Link to post Share on other sites
kolega.jankovic 23 Posted September 23, 2014 @zarkusi-tempomat radi sve kako treba vec par meseci, samo lapica ne svetli@kuvalja-pokusacu opet, imam elm, uradicu sve opet pa da vidim. Ako sam uspeo na tabli od Punta benzinca da upalim sijalicu za grejace.......majku mu...... Quote Share this post Link to post Share on other sites
Sale2810 4 Posted September 23, 2014 Ma mora da moze,samo polako,isprati sve detalje i mora da se upali Quote Share this post Link to post Share on other sites
Zarkusi 2 Posted October 4, 2014 Stigo danas. Sutra palim lampicu. Quote Share this post Link to post Share on other sites
milos.becejac 5 Posted October 20, 2014 Jel radio neko ovo na Puntu 1.2 8v ? Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted October 20, 2014 Ne moze na Punta Quote Share this post Link to post Share on other sites
milos.becejac 5 Posted October 21, 2014 e-e punto moj sta je docekao Quote Share this post Link to post Share on other sites
Sasa_NS 54 Posted October 21, 2014 Ima da može, samo da i to dođe na red. Quote Share this post Link to post Share on other sites
milos.becejac 5 Posted October 21, 2014 AJDE SALE LEGENDO ! Quote Share this post Link to post Share on other sites
lakicevicboris 7 Posted November 16, 2014 Ja sam takodje sam ugradio tempomat na stilu (nije neka nauka jer vec je imao konektor kod volana), sve lepo sredio, vratio masku (donju), probao i tempomat radi ko suza. Al problem mi se pojavio kad sam hteo da dam levi zmigavac rucica zmigavca se sama vrati nazad, ona guma oko rucice je vraca nazad, cim ti guumu podignem tj izvadim iz lezista rucica zmigavca radi ok (kad dam desni zmigavac nema taj problem). E sada ja bih hteo da isecem malo tu gumu al ne znam kako, a ne bi voleo da je isecem pa nesto ukakim. Jel imao neko takav problem i ako jeste kako je resio. Unapred sse zahvaljujem svima na odgovoru. Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted November 16, 2014 samo malo zarotiraj gumu dok ne nadjes dobar polozaj. Quote Share this post Link to post Share on other sites
lakicevicboris 7 Posted November 16, 2014 Probacemo i to.Hvala na odovoru Quote Share this post Link to post Share on other sites
pskundric 0 Posted January 16, 2015 Nabavio sam skoro ručicu tempomata od Alfe 147, vidim ljudi ugrađuju bez problema tu istu ručicu i u novog Fiata Bravo! Međutim ja ne mogu da pronađem konektor, predpostavljam da ga i nema... Šta da radim? Quote Share this post Link to post Share on other sites
