yunoise 0 Posted January 12, 2015 Sipam NIS-ov UltraD i nisam imao nikakvih problema ovih dana, na -17 palio bez problema, a bas sam se navozao, preko 2500km. Quote Share this post Link to post Share on other sites
coa565 10 Posted January 7, 2017 (edited) Kod mene sad -23 kresnu punto iz prve. Pustio sam ga 3put na grejace i verglao jedno 10 sekundi i upali iz prve. A komsije passat b5.5 2.0 TDI jedva upalio... Edited January 12, 2017 by neshaoct prebačeno Quote Share this post Link to post Share on other sites
MS PK 7734 Posted January 7, 2017 Pa kad si ga ti radio.. Quote Share this post Link to post Share on other sites
Axic 20048 Posted January 7, 2017 (edited) 51 minutes ago, MS PK said: Pa kad si ga ti radio.. Ja sad palio Punta 1.3 jednom sacekao grejace, zaverglao mozda sekundu i lagano upalio. U rezervoaru obican ED sa OMV-a negde oko cetvrtine ima goriva, temperatura pokazuje -16 mada sto rece neko od kolega nije ovo nista za novije dizele. Edited January 7, 2017 by Axic Quote Share this post Link to post Share on other sites
Mijailović P. 3449 Posted January 7, 2017 Pa da , dvojako dejstvo. Za ćumuraša zakačiš pušnicu pa odimiš i šunkicu. Quote Share this post Link to post Share on other sites
@bane@ 102 Posted January 8, 2017 Vec je sve nadimljeno samo jos promaja da odradi svoje kobasice su vec gotove Quote Share this post Link to post Share on other sites
Vule 795 Posted January 8, 2017 Koliko sam čuo u poslednja dva tri dana, smrzla nafta sa NIS-a i to onaj Ultra D, bar 5 drugara mi se javilo sa istim problemom. OMV (običan) kod mene, pali kao metak MOL i OMV, sve ostalo je za zaobilaženje po ovom minusu, mada naravno nema pravila, ali bolje sprečiti nego lečiti Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted January 8, 2017 Ja čuo da se ljudi kod nas žale na OMV i njihov dizel, godinama i brat i ja sipamo na NISu i nema problema Quote Share this post Link to post Share on other sites
rocket 643 Posted January 8, 2017 Kako vam pali na ovim temperaturama? Meni je do pre 3 dana palio na pola kljuca,ali juce I jutros oko 7h ujutru,na minus 16 jedva! juce je iz drugog duzeg verglanja,a jutros iz cetvrtog!!! Dok sam verglao provalio sam da mi prvi put u toku verglanja popalio lampice za abs,asr I jos neka sr...a! Da li to znaci da je akumulator oslabio? Ponavljam da je do pre 3 dana na temperaturama koje su bile oko -5 do -10 palio kao mina. Inace natankao sam pun rezervoar na nisu I to onog dizela sa aditivima I sledece jutro problem sa paljenjem Quote Share this post Link to post Share on other sites
rocket 643 Posted January 8, 2017 On 1/8/2017 at 9:45 AM, Vule said: Koliko sam čuo u poslednja dva tri dana, smrzla nafta sa NIS-a i to onaj Ultra D, bar 5 drugara mi se javilo sa istim problemom. OMV (običan) kod mene, pali kao metak MOL i OMV, sve ostalo je za zaobilaženje po ovom minusu, mada naravno nema pravila, ali bolje sprečiti nego lečiti Tacno. Sipao sam u petak uvece pun rezervoar na NIS-u I to bas taj ultra D I juce ujutru,kao I jutros jedva ga upalim!!! Pre toga palio na pola kljuca!!! On 1/8/2017 at 10:59 AM, Easy Rider said: Quote Share this post Link to post Share on other sites
Easy Rider 14 Posted January 8, 2017 1 hour ago, Vule said: Koliko sam čuo u poslednja dva tri dana, smrzla nafta sa NIS-a i to onaj Ultra D, bar 5 drugara mi se javilo sa istim problemom. OMV (običan) kod mene, pali kao metak MOL i OMV, sve ostalo je za zaobilaženje po ovom minusu, mada naravno nema pravila, ali bolje sprečiti nego lečiti u punta sam sipao na NISu, UltraD, pali bez greske jyce, na minus beskonacno Mada je moj punto palio i bez svih grejaca, tako da nije merodavan. U Alfu sipao samo na MOLu, zadnji put na OMWu, da probam njihov i uporedim u odnosu na MOL, ali ubi minus pa nije relevantno sad. U svakom slucaju, Alfu upalila posle 2,3 sekunde verglanja. medjutim, ono sto sam primetio, kada sam uporedjivao NIS i MOL dizel, Alfa mi mnogo krupnije radi na NISovom dizelu (oba sa aditivima). To bilo jesenas i ne sipam NISov dizel u Alfu @rocket pa stvarno, mnogo mi bilo lepo kad sam konkurente uporedjivao sa mojom Alfom Quote Share this post Link to post Share on other sites
rocket 643 Posted January 8, 2017 ma sad sam sipao na NIS-u I nikad vise! A, sto se sajta tice tu lepo mogu benzinci da se uporede sa nasim JTD-ovima Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted January 8, 2017 Nije tu sve do goriva, ima i do akumulatora.Sem ako bas bas nece da vam upali, a vergla ko lud.Caletu NIS-ov dizel nece da upali, devojci MOL. Caletu zena isisala aku, moja sama, a i nije bio neki, slusao sam kako pali.U 5 ujutro na -17, 5 puta sam palio grejace i auto mi je bukvalno upalio na pola kljuca. A grejace sam palio, jer ne zelim da se muci, a sasvim sigurno bi upalio i iz prve, ali bi to bilo malo bucnije verovatno.Dobro odrzavan auto, pun akumulator, bar 10 litara goriva i mema brige. Quote Share this post Link to post Share on other sites
Easy Rider 14 Posted January 8, 2017 On 1/8/2017 at 11:13 AM, rocket said: ma sad sam sipao na NIS-u I nikad vise! A, sto se sajta tice tu lepo mogu benzinci da se uporede sa nasim JTD-ovima vidis, nije mi palo na pamet da uporedjujem moju Alfu sa benzincima ... Eto mi zanimacije dok grlim radijator Quote Share this post Link to post Share on other sites
igor0511 2882 Posted January 8, 2017 Napraviste nauku od paljenja kola zimi ja nemam tih problema, 5 godina samo sipam NISov dizel i nikad nista nije zezalo. Prvu zimu je Stilo kod mene stajao mesec dana u dvoristu, bilo oko -10 i upalio bez problema. Quote Share this post Link to post Share on other sites
milan-jtd 319 Posted January 8, 2017 Jutros u 5 sati na - 17, sa jednim grejanjem je upalio posle 3-4 sekunde verglanja, ali je akumulator sveže dopunjen da ne bi bilo iznenađenja. Sipam ultra D I do sada nisam imao problema. A Varta me malo zeza, ili ne drži struju ili alternator zakazuje polako, moracu to da ispitam Quote Share this post Link to post Share on other sites
MS PK 7734 Posted January 8, 2017 Koja je razlika u tom grejanju par puta u odnosu na jednom, sem sto dobro ispraznis akumulator? Quote Share this post Link to post Share on other sites
@bane@ 102 Posted January 8, 2017 Ja sipam adi dizel o onih lopova naftahema bem li ga jutros upali bez problema znaci valja gorivoI nikad negrejem vise puta samo jedared(sam on duze greje nego inace)Primeti se da je aku malo izgubio snagu zboog mraza ali bez problema je upalio. Quote Share this post Link to post Share on other sites
Vule 795 Posted January 8, 2017 2 hours ago, beli_Punto said: Ja čuo da se ljudi kod nas žale na OMV i njihov dizel, godinama i brat i ja sipamo na NISu i nema problema Ja poslednjih 6 godina sipam na OMV, jedno vreme sam točio MaxxMotion ED pa onda prešao na običan, nikakvu razliku bar na mom motoru nisam primetio u bilo kom smislu, nikada nije zaledio, zapušio filter i slično Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted January 8, 2017 Sto se tice grajanja vise puta, ne znam tacno po cemu kompjuter odredjuje duzinu grejanja, mislim da je vezano samo za spoljnu temperaturu. Tj nije povezano nikako sa nekom drugom temperaturom do koje se dolazi koriscenjem grejaca. Na internetu se moze pogledati razlika izmedju novih i koriscenih grejaca, kao u razlika izmedju jacih i nepoznatih brendova. Kad vidis kako se koji zagreva i zamislis da se svaki greje X sekundi bez obzira da li je polovan ili novi onda pomislis da mu nece skoditi par grejanja. Mislim da oni ne izvuku puno struje, to je zanemarljivo na toliki akumulator, nije to ringla koja radi 5 min dok ne prokljuca voda. Sto bi rekli ne moze da skodi, a ako ne skodi... Quote Share this post Link to post Share on other sites
Bingodalton 738 Posted January 8, 2017 Jeste, akumulator odaje svoje slabosti. Quote Share this post Link to post Share on other sites
totti 13165 Posted January 8, 2017 Ja koliko znam, kompjuter za merodavno uzima temperaturu rashladne tečnosti. Inače bi i po minusu svaki put palio grejače iako je motor na radnoj temperaturi, a to ne radi. Quote Share this post Link to post Share on other sites
MS PK 7734 Posted January 8, 2017 Ma da Bingo al oni su sami tamo u komori, nisu ko baklje pa sa im prsne nafta i pale vatru. Ovi se ugreju i cekaju verglanje i nista se ne desava Quote Share this post Link to post Share on other sites
Dezurni 399 Posted January 8, 2017 To što zagreju tu istu komoru, to nema veze? Quote Share this post Link to post Share on other sites
MS PK 7734 Posted January 8, 2017 Kakve veze ima on kad pali pali, kad nece grej ga 5 puta isto je U ostalom, sta ti znas o dizelima Quote Share this post Link to post Share on other sites
