Zan Batist 252 Posted May 20, 2021 @zelsav, bas je svejedno.. naravno ispostovat specifikacije. 6 god shell helix ultra 5w-40, postalo mi skupo.. zadnji put Petrol premium power 5w40 (Texaco ulje, samo pakuju) i sve kako treba. 2 horvat and zelsav reacted to this Quote Share this post Link to post Share on other sites
MS PK 7718 Posted May 20, 2021 Kolege ima li ko od vas iskustva sa PSA 1.6 HDI motorima,16V 90 ks,vezano za izbor ulja? Po tipu i verziji motora (DV6-9HX) vidim da nema DPF pa može skoro sve,po oil finder-ima prvo C2 pa i A3/B4. Opet,problemi sa turbom,pritiskom ulja i rešetkom uljne pumpe govore da baš i nije svejedno.. Hvala unapred.Ja mislim da je tu problem samo u intervalu zamene uljaПослато са SM-A307FN помоћу Тапатока 2 totti and zelsav reacted to this Quote Share this post Link to post Share on other sites
zelsav 17 Posted May 21, 2021 @Zan Batist Upravo je Shell HU 5w40 u motoru,mislim da cu nastaviti sa Motul X-cess koji sipam u stila i mastera,PSA B71 2296 odobrenje.Hvala. @MS PK To i jeste sustina problema,korektna je servisna istorija ali cu ipak skinuti karter da malo istrazim 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
MS PK 7718 Posted May 21, 2021 Ako, ne moze da skodi Послато са SM-A307FN помоћу Тапатока 1 zelsav reacted to this Quote Share this post Link to post Share on other sites
virke 73 Posted May 27, 2021 (edited) U Punta 1.4 Natural Power sipao zadnjih par servisa Seleniju Multipower Gas 5w40. Cena oko 1200 rsd po litru. Moze li neko da preporuci nesto jeftinije a da je u tom rangu-klasi ,naravno moze i bolje :)D ili da ne diram nista? Edited May 27, 2021 by virke Quote Share this post Link to post Share on other sites
neshtry 14511 Posted May 27, 2021 Ne diraj ništaSent from my motorola one macro using Tapatalk 1 notalone reacted to this Quote Share this post Link to post Share on other sites
Axic 19719 Posted May 27, 2021 10 hours ago, virke said: U Punta 1.4 Natural Power sipao zadnjih par servisa Seleniju Multipower Gas 5w40. Cena oko 1200 rsd po litru. Moze li neko da preporuci nesto jeftinije a da je u tom rangu-klasi ,naravno moze i bolje :)D ili da ne diram nista? Sve što ima specifikaciju koja ide za taj motor možeš sipati. Selenia nerealno skupa a imaš prilično širok izbor jeftinijih i kvalitetnijih i ulja sa modernijom tehnologijom npr. Shell, Motul, Castrol, FAM... 1 shuxx reacted to this Quote Share this post Link to post Share on other sites
MS PK 7718 Posted May 28, 2021 ...Dijamant, Sunce, Vital... , tako ispada po tebi? Послато са SM-A307FN помоћу Тапатока 2 Woodoo and dusman13 reacted to this Quote Share this post Link to post Share on other sites
Axic 19719 Posted May 28, 2021 20 hours ago, Axic said: Sve što ima specifikaciju koja ide za taj motor možeš sipati. @MS PK 1 1 Woodoo and Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
MS PK 7718 Posted May 28, 2021 Sto da ne kad kazes da su ova ostala jeftinija i kvalitetnija od nerealno skupe Selenie , eto i Fam si tu stavio Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
virke 73 Posted June 1, 2021 Gledao Shell i po sajtu mi treba Rimula ako sam ja dobro skapirao ali to ulje se prodaje samo u buricima Pustio sam poruku na fejsu ovlascenom distrubiteru da mi kaze koje mi ulje treba ali se nesto ne javlja Quote Share this post Link to post Share on other sites
Ivan 17446 Posted June 1, 2021 On 5/27/2021 at 1:15 PM, virke said: U Punta 1.4 Natural Power Koji Punto, koje godiste, koliko kW tacno - pa vidi po Shell Oil Selectoru? Koliko se secam, sipali su i ECT ulja u 5-40 gradaciji u Natural Power (Helix Ultra ECT, Helix HX7 ECT, Helix HX8 ECT). Ali bolje proveri, nisam bas u toj prici odavno. Quote Share this post Link to post Share on other sites
virke 73 Posted June 1, 2021 Nema nijednog natural power. 57kw, 2012god u oil selectoru. Nema ni evo a ni grande p. Znam da moze da se sipa svasta ali... Quote Share this post Link to post Share on other sites
Ivan 17446 Posted June 1, 2021 (edited) 3 hours ago, virke said: Nema nijednog natural power. 57kw, 2012god u oil selectoru. Nema ni evo a ni grande p. Ima, ima, samo treba da znas kako se sta zove . Nisu to dzaba Zabari koji komplikuju i brljaju: Grande Punto do 2009., Punto Evo od 2009. do 2011., pa opet Punto od 2012. Dobro sam ti rekao sudeci po ovome, idu 5-40 ECT ulja (Emissions Compatible Technology). Uokvirio sam ti - po Shell selectoru preporuka je Helix HX8 ECT, alternativa su Helix Ultra ECT ili Helix HX7 ECT: Edited June 1, 2021 by Ivan Quote Share this post Link to post Share on other sites
virke 73 Posted June 1, 2021 Ma znam kako se zove auto ali mozda ne trazimo na istom mestu. Nije ni bitno. Hvala u svakom slucaju. zanimljiv je podatak da se to ulje menja na oko 8-9k km Quote Share this post Link to post Share on other sites
MiloshBg 954 Posted June 2, 2021 Ima li neko iskustva sa Sintium uljima? Skoro uzeh cenovnik od Slodesa i ponuda Sintium ulja je odlicna, cene jos bolje, slobodno mogu reci pa duplo jeftinije od Selenie. Quote Share this post Link to post Share on other sites
vicent 1261 Posted June 2, 2021 Imaš u temi, više nas koristi Syntium. U tri svoja auta već 10 god. ga koristim. Moje lično mišljenje da je jednako dobro (možda i bolje) od Selenie. Petronas je prozvođač oba ulja a Slodes je njihov zastupnik. Svakako ga menjam na 10 hkm, nemam zamerki. Poslato sa JSN-L21 pomoću Tapatoka 2 Axic and PremieRacing reacted to this Quote Share this post Link to post Share on other sites
MS PK 7718 Posted June 2, 2021 Koriste kolege sa foruma od prvog dana i svi su zadovoljni.@vicent koje si sipao u punta jtd?Послато са SM-A307FN помоћу Тапатока Quote Share this post Link to post Share on other sites
vicent 1261 Posted June 2, 2021 Syntium 3000 a ima 3000AV, to je za motore sa DPF. Gradacija ista 5-40. Ima i bolje, Syntium 5000. Ono je 5-30 gradacije.Poslato sa JSN-L21 pomoću Tapatoka 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
Ivan 17446 Posted June 2, 2021 6 hours ago, MiloshBg said: Skoro uzeh cenovnik od Slodesa i ponuda Sintium ulja je odlicna, cene jos bolje Kolega sve rece - licno nisam koristio, ali samo da dodam da cesto kada sam kupovao (motorno/menjacko ulje za sebe ili nekog drugog), upravo su za Syntium imali 4+1 l gratis akcije. Za 1910 ccm je bilo idealno, na stranu vec odlicna cena u poredjenju sa Seleniom (skoro duplo jeftinije). @vicent I ti si video Hamiltona na Kanarevom brdu ? 1 vicent reacted to this Quote Share this post Link to post Share on other sites
neshtry 14511 Posted June 2, 2021 Ja sam ovo uzeo na preporuku,pa ću videti kakvo je…. Quote Share this post Link to post Share on other sites
vicent 1261 Posted June 2, 2021 Kolega sve rece - licno nisam koristio, ali samo da dodam da cesto kada sam kupovao (motorno/menjacko ulje za sebe ili nekog drugog), upravo su za Syntium imali 4+1 l gratis akcije. Za 1910 ccm je bilo idealno, na stranu vec odlicna cena u poredjenju sa Seleniom (skoro duplo jeftinije). [mention=1228]vicent[/mention] I ti si video Hamiltona na Kanarevom brdu ?Družimo se, dam mu poneki savet i tako...Poslato sa JSN-L21 pomoću Tapatoka 1 3 Axic, MS PK, Ivan and 1 other reacted to this Quote Share this post Link to post Share on other sites
Gagy.GM 59 Posted June 2, 2021 Ja koristim Syntium 3000 vec 7 godina na 3 auta i nemam zamerki. Na Bravu 1.2 mi je bilo mnogo bolje od Selenije 20k gde se na jutarnjem paljenju culi ventili par sekundi a na Syntiumu nikad.Menjano na 8/9000km i trosio je do 700gr a Selenije do 1l.Punto 1.3mjet ga nije trosio a u Alfu sam skoro sipao pa cu videti kako se ponasa. Quote Share this post Link to post Share on other sites
Mijailović P. 3396 Posted June 11, 2021 (edited) Ovo ce sigurno znati ovaj cistokrvni svaba @totti Pretpostavljam da je fransiza ali ne vidim podatke o proizvodjacu. Drugar iz Delmax-a mi nudi ovo ulje pa da se malo raspitam. https://www.swdrheinol.com/en/product catergory/engine-oils-for-passenger-cars/ Edited June 11, 2021 by Mijailović P. Quote Share this post Link to post Share on other sites
totti 13151 Posted June 11, 2021 Čim "made in Germany" stoji, ne može to da bude loše Sent from my SM-G770F using Tapatalk 1 Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
