horvat 6456 Posted June 11, 2021 (edited) Totti bi i Angelu...samo nek je Svapsko Edited June 11, 2021 by horvat 3 4 saledelagano, Mijailović P., totti and 4 others reacted to this Quote Share this post Link to post Share on other sites
Mijailović P. 3431 Posted June 11, 2021 Nadjoh da je spominjano. Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted June 11, 2021 1 hour ago, horvat said: Totti bi i Angelu...samo nek je Svapsko Videeeee Angele sto se picnula Quote Share this post Link to post Share on other sites
Mijailović P. 3431 Posted June 11, 2021 Ajmo strucnjaci. Komentarisite! Quote Share this post Link to post Share on other sites
neshtry 14783 Posted July 9, 2021 (edited) Edited July 9, 2021 by neshtry 2 dach@ and knezevic76 reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted July 29, 2021 Malopre caskam sa majstorom, kaze mi da je uzeo neko "novo" ulje - Magneti Marelli, koji je u stvari prepakovan Shell. Made in Italy navodno... Uvoznik je bas Warner iz Subotice. 2 zelsav and neshtry reacted to this Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted August 11, 2021 Videh danas Mannol ulja, nemacka, cisto kada sam uzimao aditiv za DPF od istog proizvodjaca a generalno je dosta jeftiniji od npr Wynns/TuneUp i slicnih po ceni od 780RSD (za aditiv je cena). Nisam vidjao Mannol skoro, neka iskustva? Vidim da ima par 5W-30 koja bi odgovarala za mog Bravka po Mannol oil selector-u odavde. Quote Share this post Link to post Share on other sites
notalone 150 Posted August 12, 2021 Po meni prvi uslov za dugotrajnost motora sa 45 godina vozačkog iskustva: ulje uvek najkvalitetnije ( bez obzira na cenu, jer ne menja se svaki dan) i zamena na propisanim intervalima. Prosto! Quote Share this post Link to post Share on other sites
Jackkk 108 Posted August 12, 2021 7 hours ago, ISV_01 said: Videh danas Mannol ulja, nemacka, cisto kada sam uzimao aditiv za DPF od istog proizvodjaca a generalno je dosta jeftiniji od npr Wynns/TuneUp i slicnih po ceni od 780RSD (za aditiv je cena). Nisam vidjao Mannol skoro, neka iskustva? Vidim da ima par 5W-30 koja bi odgovarala za mog Bravka po Mannol oil selector-u odavde. Tast sipa Mannol u Punta 2, za sada se dobro pokazalo. Prešao je sa Selenie jer je motor gutao ulje. Sa Mannolom je to primetno bolje, možda jednom između servisa dospe malo. 1 ISV_01 reacted to this Quote Share this post Link to post Share on other sites
Zvezdo 980 Posted August 12, 2021 Ja nasuo u vagena. Ništa lošije ili bolje nego preskupo VW OEM ulje. Cena je malo preko 500 din po litru na pakovanju od 5 litara. 1 ISV_01 reacted to this Quote Share this post Link to post Share on other sites
gand 21 Posted August 12, 2021 Da li moze u Slodesu da se kupi ulje na licu mesta ili samo moze da se naruci? Quote Share this post Link to post Share on other sites
dach@ 4904 Posted August 12, 2021 @gand ima prodavnica,kupuješ na licu mesta 1 gand reacted to this Quote Share this post Link to post Share on other sites
Axic 19969 Posted August 12, 2021 14 hours ago, notalone said: Po meni prvi uslov za dugotrajnost motora sa 45 godina vozačkog iskustva: ulje uvek najkvalitetnije ( bez obzira na cenu, jer ne menja se svaki dan) i zamena na propisanim intervalima. Prosto! Pre bih se složio za ovo drugo oko propisanog intervala za zamenu kao bitniju stvar. Jedno je kvalitenije, drugo manje kvalitenije ali ni to drugo neće oštetiti motor niti ono prvo toliko sačuvati kad se medjosobno uporede. Quote Share this post Link to post Share on other sites
Reacher Gilt 2175 Posted September 14, 2021 (edited) Pre neki dan sam dolio ~ 1/2 l ulja jer sam pri proveri primetio na meraču da je nivo spao nešto ispod polovine. Prešao sam od zamene ~ 5K, i za to vreme je potrošio oko tih pola litra, možda malo manje ... I malopre gledam onu čantricu i skontam da sam se za*eb'o, dolio sam total 7000 10w40 umesto 9000 5w40. Od tog dolivanja sam preš'o ~ 500 Km ... 'el će da mu bidne nešto ? Inače, nakon dolivanja sam par puta proveravao nivo jer nisam bio siguran koliko da dolijem, i koliko sam primetio ulje ima ok boju, auto se normalno ponaša, i tako to. Da teram ovako do sledeće zamene, il' da ga istočim i sipam novo ? Edited September 14, 2021 by Rasta Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted September 14, 2021 Bice ok, iako ne valja mesati razlicite gradacije pa ni iste gradacije razlicitih proizvodjaca. Mali je udeo dodatog ulja u ukupnoj zapremini. Teraj do zamene. Sto kaze moj kolega, sto se tice Nive i potrosnje ulja, bitno da ima ulja. 2 Reacher Gilt and shuxx reacted to this Quote Share this post Link to post Share on other sites
Reacher Gilt 2175 Posted September 14, 2021 (edited) Ok, tako sam nekako i ja razmišljao, al' reko' bolje da pitam ... Punto mi nije trošio gram ulja između zamena, pa sam se odvik'o od dolivanja ... A ovo po litre što mi je ostalo, da ne dolivam više njega, nego da pazarim čantricu 5w40 ? Edited September 14, 2021 by Rasta Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted September 15, 2021 Ofc da ces uzeti ulje fabricki propisano za njega Nije ti ovo 'blagi prelaz sa 5w-40 na 10w-40' Sto si dolio ulja koje nije za njega, dolio si, vrat se korjenima 1 Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
neshtry 14783 Posted September 26, 2021 (edited) Zna li neko nešto o ovome? Navodno ulje od semenki bundeve... Edited September 26, 2021 by Ivan Sredjen format, skinut TT potpis Quote Share this post Link to post Share on other sites
MS PK 7728 Posted September 26, 2021 (edited) Za u tiganj? Prvi put vidim 5000milja!? 8000km interval Edited September 26, 2021 by Ivan Skinuti visestruki TT potpisi 3 stex_pb, neshtry and dusman13 reacted to this Quote Share this post Link to post Share on other sites
Djuk85 2984 Posted September 26, 2021 Znači menja se na 4... To za vegane Sent from my Redmi Note 8 Pro using Tapatalk 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted September 26, 2021 Sprdnja, naravno da ne postoji tako nešto. Sent from my 3310 using Tapatalk Quote Share this post Link to post Share on other sites
neshtry 14783 Posted September 26, 2021 I ja mislim... Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
darkman14 5892 Posted October 28, 2021 Resio da odradim mali servis pre zime i ono iznenadjenje, zaskoci me tigar. Ovo je januar ove godine ovo je sada 1 Decak Iz Vode reacted to this Quote Share this post Link to post Share on other sites
horvat 6456 Posted October 28, 2021 Ista prica sa Mobil1 0w40 Ako ti je neka uteha... Quote Share this post Link to post Share on other sites
ISV_01 4023 Posted October 28, 2021 (edited) Motul 5w-30 8100 EFE isto skuplji tako da... Edited October 28, 2021 by ISV_01 Quote Share this post Link to post Share on other sites
