Ivan 17454 Posted March 28, 2020 (edited) 15 minutes ago, bogar said: hvala bracki, izgleda da cu morati da ispustam Würth Proveri jos malo po netu, vidi onaj Stalker blog o uljima. Generalno ne mora da znaci da neko ulje nije odgovarajuce, mozda samo nema sertifikat tog proizvodjaca. Ali mene buni sto ima sertifikat, ali koji nije odgovarajuci. Imas i po netu, evo pogledaj i sam razliku izmedju G2 i S2: Fiat 9.55535-G1 Qualification for gasoline engine lubricants granting fuel economy and extended drain. Fiat 9.55535-G2 Qualification for gasoline engine lubricants with standard characteristics. Fiat 9.55535-H2 Qualification for gasoline engine lubricants, granting high performances and high viscosity at high temperatures. OEM recommended product also meets API: SM, ACEA A3-04/B3-04. Fiat 9.55535-H3 Qualification for gasoline engine lubricants granting very high performances. Fiat 9.55535-D2 Qualification for Diesel engine lubricants with standard characteristics. Fiat 9.55535-M2 Qualification for lubricants with extended drain. OEM recommended product also meets ACEA B3-04/B4-04, GM-LL-B-025. Fiat 9.55535-N2 Qualification for lubricants with a very good characteristics for turbocharged engines, Diesel and gasoline, with extended drain. Minimum requirement is ACEA A3/B4-04. Fiat 9.55535-S1 Qualification for Diesel and gasoline engine, with exhaust treatment system, lubricants, granting fuel economy and extended drain. OEM recommended product is also approved to ACEA C2. Fiat 9.55535-S2 Qualification for Diesel and gasoline engine, with exhaust treatment system, lubricants, with extended drain. OEM recommended product also meets: ACEA C3-04, MB 229.51 and API: SM/CF. Fiat 9.55535-GS1 ACEA C2 based, 0W30 viscosity, mid-SAPS engine oil for the latest gasoline engines of the Fiat Group (Fiat, Alfa-Romeo, Lancia). Fiat 9.55535-DS1 ACEA C2 based, 0W30 viscosity, mid-SAPS engine oil for the latest diesel engines of the Fiat Group (Fiat, Alfa-Romeo, Lancia). @zelsav Otprilike je i kod mene uvek stajalo toliko, mozda zavisi i od filtera ulja. A potrosnja je apsolutno u toleranciji, pogotovo kad se uzme u obzir koliko je motor presao . Stila sam uzeo vrlo mladog, sa malom kilometrazom i tada je suv kao barut trosio minimum 1-1.5 dl Selenie WR. Neznatno vise je trosio i kad sam ga prodao pre 2 godine, posle pune decenije u vlasnistvu. @MS PK Standardno je cca 10 EUR/l ovde po radnjama. Imas i kanticu od 5l. Edited March 28, 2020 by Ivan 3 zelsav, MS PK and bogar reacted to this Quote Share this post Link to post Share on other sites
zelsav 17 Posted March 28, 2020 13 minutes ago, bogar said: @Ivan hvala bracki, izgleda da cu morati da ispustam Würth Sent from my CLT-L29 using Tapatalk Ovo je bure od 200l?Mislim da puno majstora ovo forsira pri zameni, verovatno imaju dobre uslove kod Wurth-a ali drži se ipak full synth ulja. @Ivan Treba uzeti u obzir i to što često ulazi u "race" mod @MS PK U Kit-u je bilo oko 1200/l,momak koji uzima na bure u Mass-u mi je dao za nešto malo više od 1000/l 1 MS PK reacted to this Quote Share this post Link to post Share on other sites
bogar 22 Posted March 28, 2020 @zelsav Hahahha jeste moj matori je mehanicar, pa ga tutnuo meni imas dobro okoSent from my CLT-L29 using Tapatalk 1 zelsav reacted to this Quote Share this post Link to post Share on other sites
Darko Kg 15 Posted April 7, 2020 ac.shell.com Da li je neko probao ovu aplikaciju za proveru Shell ulja? 1 dekirs reacted to this Quote Share this post Link to post Share on other sites
horvat 6451 Posted April 7, 2020 Interesantno! Secam se, jednom sam u Tempu naisao na Shell ulje, i ta nalepnica sa zadnje strane uopste nije ni mogla da se odlepi tako kao list sveske Quote Share this post Link to post Share on other sites
vagenovac 4525 Posted April 7, 2020 Ja porucih ravenol iz subotice sad, opet motul izvisio Quote Share this post Link to post Share on other sites
Darko Kg 15 Posted April 7, 2020 Ja sam nasao jednu flasu Shell-a, uvoznik Orbico i kad ukucam bar kod, ne daje mi podatak da je orginal. Quote Share this post Link to post Share on other sites
Home 56 Posted April 7, 2020 Ne znam sta da vam kazem za shell...Taj barkod nije prosao ni sa ambalaze ulja koje je kupljeno u sred Berlina... Sent from my POCOPHONE F1 using Tapatalk 1 Darko Kg reacted to this Quote Share this post Link to post Share on other sites
Home 56 Posted May 22, 2020 Ravenol VMO 5*40 posle 9960km. Apsolutno ludilo od maziva. Grande 1.4 16v dosuto oko 400 grama.Sent from my POCOPHONE F1 using Tapatalk Quote Share this post Link to post Share on other sites
vagenovac 4525 Posted May 22, 2020 Sipao sam i ja ravenol u bmwa sad pre par hiljada km, istrazivao nesto i vidim da je kvalitet vrhunski, tj. ako se gledaju njihove vrhunske serije, jer imaju preko 20 serija ulja, prave skoro sve gradacije itd. Hteo sam mobil sipati, jer je serija mobil 1 uglavnom najbolja ili u samom vrhu, ali nema mobil 1 nema za novi bmw standard, vec samo mobil super serija koja je za klasu ispod i sasvim obicno/prosecno ulje, nije ista tehnologija uopste iako su oboje kao sintetike. 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
neshtry 14518 Posted May 23, 2020 Jel probao neko Burdhal ulja? Poslato sa POT-LX1 pomoću Tapatoka Quote Share this post Link to post Share on other sites
danijel55 694 Posted May 23, 2020 Pogledaj temu zanimljivi primerci ,u delti hf samo to ulje sipa, al gradacija 0-60. Quote Share this post Link to post Share on other sites
neshtry 14518 Posted May 23, 2020 Trkačko ulje? Poslato sa POT-LX1 pomoću Tapatoka Quote Share this post Link to post Share on other sites
djomla 8385 Posted May 23, 2020 Par drugara mehaničar koriste Bardhal, kažu da je ok. Sent from my 3310 using Tapatalk 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4525 Posted May 23, 2020 Gledao sam specifikacije bardahla u gradacijama/standardima za BMW i mogu reci samo da je 5w30 nesto ispod proseka, dok su 5w40 i 0w40 (jedva) prosecni. Dakle bardahl ulje nije lose, ali nema govora o nekom kvalitetu, jedino moze biti prednost ako je jeftinije od konkurencije i sto nema kopija pa znas da ces dobiti ulje trazenog standarda/specifikacije. 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
Desmo 428 Posted May 28, 2020 2 neshtry and Milutinac reacted to this Quote Share this post Link to post Share on other sites
neshtry 14518 Posted June 14, 2020 Evo Repsol u Renault 4 bagiSent from my motorola one macro using Tapatalk 1 Djuk85 reacted to this Quote Share this post Link to post Share on other sites
dach@ 4904 Posted June 23, 2020 (edited) Nije loš klip i vezi ulja,malo duži za gledanje ali interesantan. Edited June 23, 2020 by Ivan Embedovan video Quote Share this post Link to post Share on other sites
neshtry 14518 Posted June 23, 2020 (edited) @dach@ Dino je inače lekar specijalista kućne medicine(opšte prakse u BiH) Edited June 23, 2020 by Ivan Sredjen tag, skinut TT potpis Quote Share this post Link to post Share on other sites
vagenovac 4525 Posted June 24, 2020 Bas sam uzeo jos jednu turu ravenola za drugi auto Послато са Mi MIX 2 помоћу Тапатока Quote Share this post Link to post Share on other sites
totti 13151 Posted June 24, 2020 Ebeš ti sve ovo kad nema više Bergoline ulja u konzervama Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
vagenovac 4525 Posted June 24, 2020 Meni je zao sto je izbor ulja kod nas jako skrnav i siromasan, cak i kod brendova koji su kod nas na glasu, dostupni svuda i odlicno se prodaju, ako hoces neko specificno ulje nema, a da ne spominjem brendove koji nisu izvikani na nasim prostorima. Recimo trazio sam motul bmw specific nema kod nas iako postoji na sajtu, trazio sam mobil 5w50 novi tip ulja, imaju samo stari tip (peak life kojeg je posle zamenio x1, pa x2). Aral pravi dobra ulja, imaju 10ak vrsta, kod nas mogu da se nadju 2-3 vrste u principu. Za fuchs je jos gore, ja sam nasao samo 2 tipa da prodaju kod nas, a isto vrhunsko ulje. Ravenol kod nas ne drzi racing performance ulja, cak ni 5-6l na lageru. Inace ravenol ima jednu od najvecih paleta ulja, mislim da prave skoro 100 tipova motornih ulja, a kod nas pitanje je ako ima 10 vrsta. Rowe, kroon i amsoil odlicna ulja, u nemackoj mogu da se nadju kod nas ne. Quote Share this post Link to post Share on other sites
MS PK 7718 Posted June 24, 2020 Ne isplati im se samo za tebe da lageruju Послато са SM-A307FN помоћу Тапатока 1 vagenovac reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4525 Posted June 24, 2020 Hahah pa valjda ima jos ludaka, nisam ja #prvinabalkanu koji je trazio to ulje Послато са Mi MIX 2 помоћу Тапатока Quote Share this post Link to post Share on other sites
Home 56 Posted June 24, 2020 (edited) Ja sam jurio Amsoil...nema pojma da se kupi kod nas, jedino da mi neko donese od preko... Edited June 25, 2020 by neshaoct pismo Foruma Quote Share this post Link to post Share on other sites
