neshtry 14851 Posted January 20, 2020 To je za milutinov primerPoslato sa POT-LX1 pomoću Tapatoka Quote Share this post Link to post Share on other sites
totti 13165 Posted January 20, 2020 Rodney, you dipstick Čak neretko može biti i manje od 1 litre min-max. Kod Focusa 1.6 benzinjare je to 0.7 litara.Bilo kako bilo - da, ovde nije litar u pitanju ni pod razno Sent from my SM-G950F using Tapatalk 2 dekirs and Milutinac reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 20, 2020 Koliko da dolijem da ne idem kod majstora zbog toga samo?Grande punto 1.4 16V sipan Motul 5w40 6100Sent from my SM-A520F using TapatalkPa oko ovog primera je pocela diskusija. Za njega si rekao da se dolije 1.5lSent from my SM-J530F using Tapatalk Quote Share this post Link to post Share on other sites
neshtry 14851 Posted January 20, 2020 Ne to, tu ide od prilike litar, pola litra pa merenjePoslato sa POT-LX1 pomoću Tapatoka Quote Share this post Link to post Share on other sites
Flex 1778 Posted January 20, 2020 Litar je previse, ruku mogu da dam. Sent from my SM-J530F using Tapatalk Quote Share this post Link to post Share on other sites
neshtry 14851 Posted January 20, 2020 Možda za malko... Poslato sa POT-LX1 pomoću Tapatoka Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted January 20, 2020 Odustajem. 1 3 Axic, Djuk85, djomla and 1 other reacted to this Quote Share this post Link to post Share on other sites
rage_man 130 Posted January 20, 2020 Ok ljudi, da spustimo tenziju, dolicu 1dl pa cu pratiti situaciju.Sent from my SM-A520F using Tapatalk Quote Share this post Link to post Share on other sites
danijel55 700 Posted January 20, 2020 Da se i ja ukljucim.Na mikri razlika izmedju min i max je oko 800g grubog merenja.Bilo kako bilo bolje dolij kao sto kolege kazu 2-3dec,pa vozi malo ili kad dolijes upalis auto,odradi min ,ugasis pa vadi merac i vidi koliko mu jos fali. Quote Share this post Link to post Share on other sites
neshtry 14851 Posted January 20, 2020 Reći će koliko je sipao,na kraju...Sipaj po 2dl Poslato sa POT-LX1 pomoću Tapatoka Quote Share this post Link to post Share on other sites
ISV_01 4032 Posted January 20, 2020 Ma da nije to Alfa 1 horvat reacted to this Quote Share this post Link to post Share on other sites
dekirs 4819 Posted January 20, 2020 Sipaj bre 2 litre, koga *ebe neka preliva. Ima se moze se 1 2 djomla, Flex and ISV_01 reacted to this Quote Share this post Link to post Share on other sites
vagenovac 4533 Posted January 20, 2020 Donja granica na sipci za merenje ulja oznacava RADNI MINIMUM kolicine ulja sa kojom motor nesmetano radi, tada se uglavnom dosipa ulje da ne bi spao ispod kolicine ulja sa kojom nesmetano radi. Gornja granica je RADNI MAKSIMUM kolicine ulja sa kojom motor nesmetano radi. Dakle kolicinu ulja u motoru treba drzati u opsegu izmedju minimuma i maksimuma, nije dobro da izlazi van projektovanog radnog opsega, kao sto nije dobro da je ulje ispod minimuma, tako nije dobro ni da je iznad maksimuma. Mislim pa gume kada duvas jer vidis da su malo ispustile ne kazes rokni jos 1-2 bara pritiska, vec se trudis da to izmeris i da bude u predvidjenm opsegu, a kamoli za motor i motorno ulje... 2 djomla and MS PK reacted to this Quote Share this post Link to post Share on other sites
totti 13165 Posted January 20, 2020 Jednom poznaniku se u Crnoj Gori upalila lampica za ulje. Posle telefonskih konsultacija da ga verovatno fali, rečeno mu je da ode na pumpu, kupi ulje i dolije.E sad, on je dolivao dok se ulje nije pojavilo kod čepa Sent from my SM-G950F using Tapatalk 1 6 Mijailović P., Bingodalton, Zan Batist and 4 others reacted to this Quote Share this post Link to post Share on other sites
dekirs 4819 Posted January 20, 2020 7 minutes ago, vagenovac said: Mislim pa gume kada duvas jer vidis da su malo ispustile ne kazes rokni jos 1-2 bara pritiska, vec se trudis da to izmeris i da bude u predvidjenm opsegu, a kamoli za motor i motorno ulje... Ja brate to odokativnom metodom, nagazim je malo nogom ako je slicno na obe strane, mos to da tera 1 3 rage_man, horvat, ISV_01 and 1 other reacted to this Quote Share this post Link to post Share on other sites
rage_man 130 Posted January 20, 2020 Ja brate to odokativnom metodom, nagazim je malo nogom ako je slicno na obe strane, mos to da tera oplakahSent from my SM-A520F using Tapatalk 1 dekirs reacted to this Quote Share this post Link to post Share on other sites
totti 13165 Posted January 20, 2020 Metoda ofrlje... Copyright by Složna braća Sent from my SM-G950F using Tapatalk 4 1 neshtry, djomla, dekirs and 2 others reacted to this Quote Share this post Link to post Share on other sites
MS PK 7732 Posted January 20, 2020 Tako je jednom covelu u pz-jca stalo 9-10l ulja Послато са SM-J330F помоћу Тапатока 1 djomla reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted January 20, 2020 Sipni litar, 'ebe ti se, a onda hvataj @neshtry za gušu kad izbije neđe taj višak. J B T 1 dekirs reacted to this Quote Share this post Link to post Share on other sites
dekirs 4819 Posted January 20, 2020 Ili jos bolje neka @neshtry sipa a ti spremi govnjivu motku 2 ISV_01 and djomla reacted to this Quote Share this post Link to post Share on other sites
neshtry 14851 Posted January 20, 2020 Od svega pravite komediju Reći će na kraju koliko je sipao, valjda... Poslato sa POT-LX1 pomoću Tapatoka Quote Share this post Link to post Share on other sites
MS PK 7732 Posted January 20, 2020 Jednom prilikom kad sam bio na malom servisu sa kamionom u koji staje nekih 32l ulja, nece da ga ispustaju na karteru nego da ga isisaju masinom. Em sto traje em sto imam losa iskustva sa tim na mom autu em ima digitalni merac na displeju. Kao izvukli i sipaju 30l. Uso majstor i da pogleda nivo na bord-u. Gleda neke parametre, ne valjaju. Ajde zameni senzor, opet ne valja. Ajde dijagnostike, probe celo popodne, opet ne valja. Reko brate , to g.vno nije izvuklo staro ulje garantujem. Posle par sati ajde da me poslusaju, da ispuste ulje da vide koliko ima, kad...nemaju ambalaze! 60l ulja bilo u motoru 3 3 ISV_01, rage_man, neshtry and 3 others reacted to this Quote Share this post Link to post Share on other sites
djomla 8386 Posted January 20, 2020 Mi barem komediju, da je tebe poslušao bila bi tragi-komedija. 1 1 Milutinac and dekirs reacted to this Quote Share this post Link to post Share on other sites
neshtry 14851 Posted January 20, 2020 Videćemo mlađo, možda i ne bude... Imam neka iskustva sa tim motorom Quote Share this post Link to post Share on other sites
djomla 8386 Posted January 20, 2020 Litar rođeni? Bem mu sitno žito. Elem @rage_man slikaj, snimaj, dokumentuj kako umeš i znaš dosutu količinu, ako stane litar svi prelazimo na Lassu i uvodimo novu mernu jedinicu za količinu ulja. 1 nsh. 2 1 neshaoct, Mijailović P. and ISV_01 reacted to this Quote Share this post Link to post Share on other sites
