majkicbane 58 Posted May 28, 2016 A ne postoji za benzince Selenia 5w40? Sad vidim da su i Gold i 20k 10w40? Quote Share this post Link to post Share on other sites
Dante Bg 4 Posted May 28, 2016 Postoji Selenia K~1100 i Selenia K Pure Energy ~1200,oba 5w 40... Quote Share this post Link to post Share on other sites
MS PK 7732 Posted May 28, 2016 Jel si sipao aditiv? Quote Share this post Link to post Share on other sites
Dante Bg 4 Posted May 28, 2016 Nisam Mozda naspem sam kasnije. Quote Share this post Link to post Share on other sites
Kaniđa 1 Posted May 28, 2016 22 hours ago, Vlada kg said: Meguin oils of Germany; Nemačko ulje iz iste fabrike u kojoj se proizvodi Liqui Moly, znaci ista fabrika a dva brenda. Mi smo direktni uvoznici i distributeri Meguin brenda. Pokrivamo putnicki, komercijalni i teretni program. Licno ga i ja koristim u Puntu Clasic. Necu sada mazati druga ulja i pricati negativno o njima, reci cu samo ko je jednom probao Meguin ostao je na njemu, ima i ovde ljudi sa foruma ali i mnogi drugi. Sve ostalo mozete pogledati na www.meguin.de www.elankg.co.rs Jes ti iz Iline vode? Quote Share this post Link to post Share on other sites
Vlada kg 0 Posted May 28, 2016 On 5/28/2016 at 4:22 PM, Kaniđa said:Jes ti iz Iline vode? Jesmo iznad parka kada se krene ka Sanel-u... Quote Share this post Link to post Share on other sites
Kaniđa 1 Posted May 28, 2016 Bas sam skoro prolazio tuda pa videh. Quote Share this post Link to post Share on other sites
Vlada kg 0 Posted May 29, 2016 (edited) Tu je firma tj veleprodaja Meguin ulja Edited May 29, 2016 by Ivan Ne citiraj prethodni post Quote Share this post Link to post Share on other sites
Gagy.GM 59 Posted May 31, 2016 Koja je cena Meguin ulja 10-40 I 5-40? Quote Share this post Link to post Share on other sites
DjoleKG 0 Posted June 1, 2016 Low emission 5w40 je 900 din Sintetic Premium 10w40 je 700 din Super performance 10w40 je 600 din Universal 15w40 500 din Sintetic Premium 10w40 je sintetika a ne polusintetika kao vecina 10w40 ulja Quote Share this post Link to post Share on other sites
Vlada kg 0 Posted June 1, 2016 Hvala Djole imaces rabat 5% kad budes menjao na svom autu!!! Quote Share this post Link to post Share on other sites
Jaarul Hades 2 Posted June 13, 2016 Koje ulje sipati u Alfa Romeo 156, 1.9 jtd, Selenia 20k Super Performance ili polusintetiku 10w40 za turbo dizele? Ispod haube pise 20k. Hvala unapred. Quote Share this post Link to post Share on other sites
Markobgd 609 Posted June 13, 2016 Zar nije 20K za benzince? Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted June 13, 2016 Bas tako, moguce da je vezni lim od benzinca.... Za jtd ide 5w40 sto je selenia Wr ili eventualno 10w40 selenia turbo diesel, ako si bas odlucio da bude selenia. Quote Share this post Link to post Share on other sites
Jaarul Hades 2 Posted June 16, 2016 Pise na onoj nalepnici 20k performer, turbo diesel, wr racing. Verovatno cu da sipam Wr 5w40. Tek sam uzeo Alfu 156, pa cu odmah da promenim ulje i filtere. Bivsi vlasnik nije bas bio azuran. Sva sreca pa je presao nekih 15-20 hiljada za 5 godina, inace bruka. Quote Share this post Link to post Share on other sites
purke 1 Posted July 20, 2016 On 5/27/2016 at 6:45 PM, Vlada kg said: Meguin oils of Germany; Nemačko ulje iz iste fabrike u kojoj se proizvodi Liqui Moly, znaci ista fabrika a dva brenda. Mi smo direktni uvoznici i distributeri Meguin brenda. Pokrivamo putnicki, komercijalni i teretni program. Licno ga i ja koristim u Puntu Clasic. Necu sada mazati druga ulja i pricati negativno o njima, reci cu samo ko je jednom probao Meguin ostao je na njemu, ima i ovde ljudi sa foruma ali i mnogi drugi. Sve ostalo mozete pogledati na www.meguin.de www.elankg.co.rs Vlado, koja je preporuka, po iskustvu, za alfine twinspark motore 1.8 16 V koji trose svako ulje koje ubacim? :-) Quote Share this post Link to post Share on other sites
vicent 1263 Posted July 20, 2016 Već 6-7 zamena sipam Syntium 3000, nikakve zamerke nemam, uzimam direktno od uvoznika "Slodes". Kantica od 4lit je 2100 rsd, dodatni litar je 550 rsd. Quote Share this post Link to post Share on other sites
Markoni Bg 74 Posted July 20, 2016 Ima li neke razlike u ondosu na WR 5w40 , da li je tisi,bucniji...itd ? meni se cini da se WR posle 6-7000km ''razbije'' motor postane dosta bucniji a ulje kao voda. Quote Share this post Link to post Share on other sites
Axic 20046 Posted July 20, 2016 @Markoni Bg I kod mene je isti taj Syntium 3000AV u Multijetu i reci cu ti samo da cu uskoro na sledecem malom servisu ponovo njega sipati. Skroz OK ulje, ne mogu se setiti posle koliko je pocrnelo ali nema potrosnje ulja to znam. Isto kao i kolega @vicent uzimam gacdirektno u Slodesu. Quote Share this post Link to post Share on other sites
vicent 1263 Posted July 20, 2016 Meni je Selenia počinjala da čekića na oko 9hkm, uvek menjam na 10 hkm. Syntium ne menja zvuk do 10 hkm, tj do zamene. Potrošnje ulja nema, tj, ne dolivam ga, tako da mi 5-i litar stoji već dve godine u gepeku ! Quote Share this post Link to post Share on other sites
Vlada kg 0 Posted July 22, 2016 Idi na www.elankg.co.rs ili www.meguin.de imas tamo preporuke za svaki model, ukucas karakteristike i vidis. Ja licno sipam Synteric Premium 10w40 sintetika samo nosi oznaku 10w. Imamo i Ultru 5w40 dobro je i ono... Quote Share this post Link to post Share on other sites
dudule1 0 Posted July 22, 2016 Pozdrav Meni je na Shell Helix HX7 5w40 posceo da lupa na 6000km na 1.3 multijet. sada sam sipao Fuchs Titan Supersyn 5w-40, pa cemo videti kako ce se pokazati. Quote Share this post Link to post Share on other sites
Vlada kg 0 Posted July 22, 2016 Cije je to ulje sto si sipao, koji proizvodjac? On 7/20/2016 at 8:57 PM, vicent said: Meni je Selenia počinjala da čekića na oko 9hkm, uvek menjam na 10 hkm. Syntium ne menja zvuk do 10 hkm, tj do zamene. Potrošnje ulja nema, tj, ne dolivam ga, tako da mi 5-i litar stoji već dve godine u gepeku ! Zar ne menjas na 10.000km ili godinu dana? On 7/20/2016 at 9:20 AM, purke said: Vlado, koja je preporuka, po iskustvu, za alfine twinspark motore 1.8 16 V koji trose svako ulje koje ubacim? :-) Syntetic Premium 10w40, sintetika ai nosi oznaku 10w. Ja sipam u svoja kola. A mozes i Ultru 5w40... Quote Share this post Link to post Share on other sites
dudule1 0 Posted July 22, 2016 On 7/22/2016 at 0:32 PM, Vlada kg said: Cije je to ulje sto si sipao, koji proizvodjac? Zar ne menjas na 10.000km ili godinu dana? Fuchs, nemacki proizvodjac http://fuchs-eu.lubricantadvisor.com/default.aspx?lang=eng menjam na 10000 ali sam izvadio Shell sto je poceo da lupa. i jos jedna stvar u puntu u karteru i cevi od uloska od filtera ostaje jedno 300-400 gr starog ulja, pa kada se izvadi na cep ulije se 3l ako se menja na sisaljku stane tacno 3,5 l, tj ostane 0,5l starog crnog ulja, pa ako se neko pita sto mu je ulje odmah crno nakon zamene eto odgovora. Quote Share this post Link to post Share on other sites
