alfini0507 1653 Posted September 2, 2020 Imas da mu predlozis neki konkretan primerak? Sent from my Redmi Note 3 using Tapatalk Quote Share this post Link to post Share on other sites
Flex 1778 Posted September 2, 2020 Moj 99% ide kod burazera, tako da nisam na njega gadjao. Sent from my SM-J530F using Tapatalk Quote Share this post Link to post Share on other sites
daca punto 5 Posted September 2, 2020 ne znam stvarno kada sam pogledao tih 10-ak Stila znači ja nisam mogao da verujem šta ljudi nude za 1800-2000 evra leševi ali baš leševi pa sam se pitao šta će nekome takav auto da ga unakazi pa da ga proda tj uvali nekom uzme pare i magla. Tako da videću imam šuraka u dizeldorfu pa valjda su tamo održavaniji nego ovde i putevi su tamo bolji nego ovde trebalo bi da bude ok. Sent from my SNE-LX1 using Tapatalk Quote Share this post Link to post Share on other sites
The Punisher 6614 Posted April 3, 2021 Ispljuva 1.2 16v samo tako.... 2 1 dach@, profa_chb and bit reacted to this Quote Share this post Link to post Share on other sites
Bole99 1 Posted May 9, 2021 (edited) Dobar dan, nasao sam na oglasima dva syila jedan je 1.8 benzin/plin 2004 godiste a drugi je 1.9 jtd 2002. Sta vi predlazete sta je bolje? Edited May 20, 2021 by Ivan Spojeno Quote Share this post Link to post Share on other sites
Ivan 17667 Posted May 20, 2021 @Bole99 Nepotrebno otvorena tema spojena je sa postojecom o kupovini Stila. Quote Share this post Link to post Share on other sites
djordje123 0 Posted October 10, 2021 (edited) Pozdrav, Gledam da uzmem Stila 1.6 16v, zanimaju me iskustva i da li je isplativije da uzem 1.9 jtd? I da li se moze naci dobar stilo za 1500e? Edited October 10, 2021 by Ivan Spojeno Quote Share this post Link to post Share on other sites
Dzimbo 1009 Posted October 10, 2021 Zaobidji 1.6 16v, previse problema ga prati, ima nas ovde koji su ga posedovali i zazalili, 1.9 jtd je vec druga prica. Quote Share this post Link to post Share on other sites
Ivan 17667 Posted October 10, 2021 @djordje123 Nepotrebno otvorena tema u tehnickom podforumu, spojena je sa postojecom o kupovini Stila. U kojoj jos malo pa deceniju i po pisemo o kupovini, Stilo je raskupusan do u najsitnija crevca od strane bivsih vlasnika (a jos detaljnije u tehnickim temama, Uradi sam, itd...). Tako da slobodno malo prelistaj ako ozbiljno planiras kupovinu, sigurno ce koristiti. Apropo 1.6, u najkracem se otprilike svodi na receno u prethodnom postu. Imas i ovu temu, upravo dilema koja te zanima - diskusija o izboru upravo izmedju 1.6 i legendarnog 1.9 JTD: https://www.fiat-lancia.org.rs/forum/index.php?/topic/40444-stilo-16-16v-ili-19-jtd/ Quote Share this post Link to post Share on other sites
Flex 1778 Posted October 10, 2021 Bolji izbor je 1.9JTD ali ih je manje dobro odrzavanih tako da sve dobro pregledaj. Postao je novi Golf 2 i samo se sipa gorivo i tera, a odrzavanje nikakvo. Sent from my SM-A307FN using Tapatalk 1 Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
nemanja018 1 Posted September 20, 2022 (edited) Pozdrav, planiram da uzmem jednog stila 1.6+plin i procitao sam boga oca sve u vezi njega ali su to uglavnom sve stare teme. Hteo sam da vidim sta bi vi rekli da li se isplati uzeti sad benzinca sa ovim cenama goriva i da li je moguce da stilo ima toliko problema sa elektronikom da bukvalno kad god das kontakt neka greska se pojavi jer sam iz svega procitanog i pregledano shvatio da se to desava. Tacnije ovaj primerak sam planirao da uzmem: https://www.polovniautomobili.com/auto-oglasi/20388106/fiat-stilo-16-16v?pickedMessage=1#_=_ Pa rekoh da vidim sta mislite da li je ovo mnogo i to. Edited September 20, 2022 by Ivan Spojeno Quote Share this post Link to post Share on other sites
Ivan 17667 Posted September 20, 2022 (edited) @nemanja018 Nepotrebno otvorena tema spojena je sa postojecom o kupovini Stila. 47 minutes ago, nemanja018 said: da li je moguce da stilo ima toliko problema sa elektronikom da bukvalno kad god das kontakt neka greska se pojavi Kod neodrzavanih leseva nista cudno. Decije bolesti su imale verzije sa pocetka produkcije, zbog gomile nove generacije elektronike razlicitih proizvodjaca. Ali i da se pojavi problem, sve se odavno lako i jeftino resavalo, naravno ko je hteo da posveti iole malo svog vremena i truda. Znam ih jos par koji se voze bez bilo kakvih lampica i izgledaju tip top. Posto kupujes 1.6, verovatno si vec citao oko boljki za tu verziju, vec cuveni motorni racunar, itd... Ako vec ides na atmo benzinca - da li si mozda razmisljao o restyle varijanti (2004+), sa 1.4 motorom od 95 KS? Ispeglane boljke sa elektronikom pocetnih serija, kvalitetniji enterijeri, sa motorom starije ali proverene konstrukcije, jeftinim za odrzavanje, doduse malo tanjih performansi... Edited September 20, 2022 by Ivan 1 nemanja018 reacted to this Quote Share this post Link to post Share on other sites
nemanja018 1 Posted September 21, 2022 (edited) @Ivan Gledam i njih ali ih je dosta manje bar ovde u okolini Nisa(ima jedan kod Jagodine), Sad jbg ne isplati mi se da idem prema bg-u da bi na kraju kad dodjem video da je krs. Iso sam najdalje 100-150km, inace na ovom iz oglasa je izgoreo jedan ecu pa je stavljen drugi i izmesten. Sta mislite o 1.6 iz 2005 opelov motor ima i plin jedino mi se kod njega ne svidja sto je beo. Nadjoh sad i ovaj deluje mi da je restajling po stopovima da li je i kod njega bolje odradjeno kao kod 1.4 2004+? https://www.polovniautomobili.com/auto-oglasi/20490421/fiat-stilo-16?attp=p0_pv0_pc0_pl1_plv0&show_date=true Edited September 21, 2022 by nemanja018 Quote Share this post Link to post Share on other sites
nemanja018 1 Posted September 21, 2022 Evo ga i ovaj 1.4 https://www.polovniautomobili.com/auto-oglasi/20452911/fiat-stilo-16v?attp=p0_pv0_pc0_pl1_plv0&show_date=true Quote Share this post Link to post Share on other sites
djole81ar 514 Posted September 21, 2022 13 hours ago, nemanja018 said: Tacnije ovaj primerak sam planirao da uzmem: https://www.polovniautomobili.com/auto-oglasi/20388106/fiat-stilo-16-16v?pickedMessage=1#_=_ Pa rekoh da vidim sta mislite da li je ovo mnogo i to. Jbt.e 2001 godište 1.500eur benzinac, ja mojeg jedva prodao pre tri godine, 2005. godište, dizel, za 1.250eur... gde su otišle cene tj. obezvredile pare... 2 Mijailović P. and nemanja018 reacted to this Quote Share this post Link to post Share on other sites
nemanja018 1 Posted September 21, 2022 Nenormalno nenormalno. Quote Share this post Link to post Share on other sites
Ivan 17667 Posted September 21, 2022 (edited) Kod starijih modela, taj uticaj generalnog rasta cena je minimalan. Mnogo vise zavisi od stanja auta. 36 minutes ago, djole81ar said: ja mojeg jedva prodao pre tri godine, 2005. godište, dizel, za 1.250eur Godinu i kusur pre tebe - 2002. JTD, za skoro duplo vecu cifru. Posle par poziva, bio je na oglasima celih par sati. Vec pre toga sam kesirao i kuci dovezao Sporta, Stildza je bio mazen i pazen skoro 10 godina kod mene i racunao sam da nece biti problema sa prodajom. 1 hour ago, nemanja018 said: Nadjoh sad i ovaj deluje mi da je restajling po stopovima da li je i kod njega bolje odradjeno kao kod 1.4 2004+? Jeste, ovo ti je restyle. Lako se prepoznaje po zadnjim stopaljkama, FIAT znak je na sredini gepeka, bolji materijali enterijera.... Jedino sto je oprema bas tanka za Stilo, ovo je neki Active ili Actual (crne plasticne kvake, gumeni volan i menjac, bez MF komandi, kasetas radio, klima rostiljka...). Oni su isli sa 15'' celicarama, pa su i ove Dynamic 16'' dodate naknadno. Polomljen je prednji branik sa vozacke strane i evidentno cvaknuto krilo, mozda i nosaci fara. Generalno bih gledao restyle, vrlo je mala razlika u ceni. Ispeglani su problemi sa elektronikom, daleko bolji enterijeri. Nema one lepljive plastike u donjem delu, tapaciri i nebo se ne odlepljuju, bolji materijali, bolja sedista. Resavani su i neki tehnicki problemi tipa pucanja prednjih opruga iz prvih serija - i sa drugacijim oprugama ali i sa samim lezistem opruge gde se ranije skupljala voda (ako vec opruga+amortizer nisu i zamenjeni). Izbacen 1.2 16v i ubacen 1.4 16v, kod dizela novije MultiJet verzije, itd... Ima toga, najbolje su bili uradjeni oni iz izlaznih serija (pogotovo 2006., takav vozi drugar i dan danas i vrhunski ga i dalje sluzi, naravno 1.9 MultiJet) ali im je i cena jaca. Edited September 21, 2022 by Ivan 1 1 profa_chb and nemanja018 reacted to this Quote Share this post Link to post Share on other sites
djole81ar 514 Posted September 21, 2022 3 minutes ago, Ivan said: Godinu i kusur pre tebe - 2002. JTD, za skoro duplo vecu cifru. Svaka čast. Izvinjavam se @nemanja018 ovi sa oglasa koje si naveo su sve extra najbolji primerci stila, nisu prosečni, zato im je cena takva. 1 nemanja018 reacted to this Quote Share this post Link to post Share on other sites
Ivan 17667 Posted September 21, 2022 (edited) @djole81ar Vec su i tada bas popadale cene, slatko sam se navozao sa njim, a prodat je da ne ode bas za kesicu kikirikija . @nemanja018 Na ove sam verzije mislio, kraj produkcije, daleko su najbolje uradjeni: https://www.polovniautomobili.com/auto-oglasi/19713892/fiat-stilo-14-16v?attp=p0_pv0_pc0_pl1_plv0 Ovaj je malo iznad cifara oglasa koje si ti postavljao, ali niko ne brani da se pogleda i proba sa nekom "bezobraznom" ponudom. Ako se planira na neki vremenski period, a ako je duze registrovan, odradjeni servisi, dobre gume, u dobrom stanju - moze da bude cak i povoljnije od nekog lesa na kraju. Jos je i kod tebe u Nisu, uvek mozes da protegnes noge, pogledas i da ti posluzi kao referenca. Edited September 21, 2022 by Ivan 2 nemanja018 and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
Flex 1778 Posted September 22, 2022 Kad vidim mrtvu rezervu, smrkne mi se. Obicno je dobar pokazatelj i kako je auto odrzavao kad nije mogao gorivo da sipa. A zacenio ga je kao da je nov. Sent from my M2103K19G using Tapatalk 2 nemanja018 and Reacher Gilt reacted to this Quote Share this post Link to post Share on other sites
profa_chb 18 Posted September 26, 2022 @nemanja018 moj je bio 1.4 95 KS, 2005. godište sa preko 200000 km, nisam imao problema sa lampicama. Palio je ček endžin samo kad crkne lambda sonda, ili ako dugo nije paljen. Oprema Active, ali bože moj. 1 nemanja018 reacted to this Quote Share this post Link to post Share on other sites
