totti 13151 Posted December 3, 2019 Kod mene je BMS integrisan i izjedna sa minus klemom. A ako se neko pita da li će S&S raditi i sa običnim akumulatorom - da, radiće. 2 djomla and bane1321 reacted to this Quote Share this post Link to post Share on other sites
Nikola 1.6 257 Posted December 4, 2019 Na koju foru je u topstopautu Exide jeftiniji nego kod uvoznika? https://www.topstopauto.rs/index.php/proizvodi/akumulatori-ponuda/exide/akumulator-12v-53ah-d-540a-exide-premium-carbon-171323-detail https://www.akumulator-shop.rs/proizvod/exide-premium-ea530-12v-53ah/ Quote Share this post Link to post Share on other sites
djomla 8385 Posted December 4, 2019 Stavili manju marzu Quote Share this post Link to post Share on other sites
mlnmnc 8 Posted December 13, 2019 (edited) Koji biste mi akumulator preporučili za Punta 1.2 16v, 6 brzina, Sporting, 59KW? Ovaj stari je dotrajao pa bih morao da ga zamenim novim. Da li neki od 45AH ili možda jači? Edited December 14, 2019 by neshaoct spojeno Quote Share this post Link to post Share on other sites
neshtry 14517 Posted December 13, 2019 Ja imam Magnum 55ah, tada je bio najeftiniji od 55ah ... Morao sam da isečem deo kućišta da bi stao. Celu stranicu što je prema hladnjaku i faru, sada mogu bilo koji aku da stavim. Bitno je, ako ne stavljaš fabričku dimenziju i kapacitet, da ne preteraš, jer alternator neće moći da postigne da ga dopunjava. 55ah je po meni max https://www.kemoimpex.com/auto-delovi/akumulatori/12v-55ah-l-magnum Quote Share this post Link to post Share on other sites
mlnmnc 8 Posted December 13, 2019 Koliko dugo imaš taj akumulator i da li imamo iste Puntiće? Quote Share this post Link to post Share on other sites
neshtry 14517 Posted December 13, 2019 (edited) Moj je sa 8 ventila, do sada sam ga 3 puta registrovao... Edited December 14, 2019 by neshaoct prebacio sliku na FLCS server Quote Share this post Link to post Share on other sites
mlnmnc 8 Posted December 13, 2019 3 godine imaš taj akumulator? Quote Share this post Link to post Share on other sites
neshtry 14517 Posted December 13, 2019 Otprilike... Poslato sa POT-LX1 pomoću Tapatoka 1 mlnmnc reacted to this Quote Share this post Link to post Share on other sites
Axic 19728 Posted December 13, 2019 (edited) @mlnmnc imaš u Metrou Biloxxi 3999 onaj od 45Ah i 400A udarne struje, vidi samo da bude neki sa najsvežijim datumom proizvodnje i isteraće 3 godine bez problema. Mada imamo već temu o akumulatorima Edited December 14, 2019 by neshaoct popravio link 2 neshaoct and kakoonobese reacted to this Quote Share this post Link to post Share on other sites
rage_man 128 Posted January 5, 2020 Koji akumulator za Grande 1.4 16V sa klimom?Auto sam kupio sa Bosch cini mi se 53Ah, nisam siguran da li je po fabrickim specifikacijama adekvatan pa valja pitati.Unapred zahvalan na odgovorima.Sent from my SM-A520F using Tapatalk Quote Share this post Link to post Share on other sites
Ivan 17454 Posted January 5, 2020 Fabrika kaze ovako (eLearn) - naravno, ne moras se drzati toga kao pijan plota : Quote Share this post Link to post Share on other sites
rage_man 128 Posted January 5, 2020 Ako sam dobro razumeo tabelu,moze se ici od 50 do 60Ah , u tom rasponu...ne videh da je i jedan obelezen sa jednom * za verzije sa klimom? Edit: ipak jeste, sad videh Sent from my SM-A520F using Tapatalk Quote Share this post Link to post Share on other sites
Urra 0 Posted January 5, 2020 33 minutes ago, Ivan said: Fabrika kaze ovako (eLearn) - naravno, ne moras se drzati toga kao pijan plota : A koji je za Punto Evo 1.3 od 62 kw, sa start-stopom? Quote Share this post Link to post Share on other sites
Axic 19728 Posted January 5, 2020 (edited) @Urra kod tebe mora AGM koji su predviđeni za automobile sa start-stop sistemom. @rage_man vidi zbog dimenzija onog kućišta akumulatora koji možeš da ubaciš. Da ne bude kupio nov a ne može da ti stane. Inače kod mene u Puntu 1.2 16v Monbat izdržao 26 meseci, taman kad je istekla garancija počeo da zeza. Otišao do Metroa i kupio Biloxxi od 45Ah 400A, 4400 dinara a stari Monbat ću na nekom otpadu prodati za 500, 600 dinara. Edited January 5, 2020 by Axic 2 Urra and Martin reacted to this Quote Share this post Link to post Share on other sites
rage_man 128 Posted January 5, 2020 @Axic naravno premericu stari, mene je vise interesovalo da pri kupovini novog ne preteram sa Ah, inace je 90% gradska voznja.Da li je 55Ah neka sredina? Sent from my SM-A520F using Tapatalk Quote Share this post Link to post Share on other sites
bane1321 5823 Posted January 5, 2020 2 hours ago, Urra said: A koji je za Punto Evo 1.3 od 62 kw, sa start-stopom? Proveri šta piše na akumulatoru (AGM ili EFB), pa na osnovu toga traži. Imaš diskusiju o tome stranicu, dve ispred na ovoj temi! 2 Urra and Ivan reacted to this Quote Share this post Link to post Share on other sites
Ivan 17454 Posted January 5, 2020 (edited) @rage_man Otprilike taj raspon, zavisi i od ponude proizvodjaca koga gledas. Iz glave znam da recimo Exide Premium CB ima 47, 53 pa 61Ah. S tim sto moderni akumulatori imaju znatno vece udarne struje (sto je naravno samo plus). Recimo za taj od 53Ah, udarna struja je 540A. 1 hour ago, Axic said: @Urra kod tebe mora AGM koji su predviđeni za automobile sa start-stop sistemom. Ne mora da znaci, vozila sa Stop&Start koriste EFB akumulatore ako su mikro-hibrid1 (uglavnom vecina narodnih sa S&S) ili AGM akumulatore za mikro-hibrid2 (sa sistemima regenerativnog kocenja). AGM akumulatori su primetno skuplji, sa drugacijom tehnologijom, zbijenijim plocama izmedju kojih je sloj od fiberglasa, a omogucavaju do 5 puta brze punjenje i do 3 puta vecu izdrzljivost. AGM akumulator se mora zameniti sa AGM, a EFB moze sa EFB ili AGM. Na sve to, pojedina vozila imaju i BMS jedinicu (Battery Management System) za kontrolu punjenja takvih akumulatora na minus klemi, pa se dodatno mora ukljuciti i dijagnostika i prijavljivanje novog accu . Raspitivao sam se malo generalno i za sebe posto imam Stop&Start, ali jos uvek nista prakticno jer je auto stigao sa maltene novim Magneti Marelli S&S akumulatorom, od 60 i kusur Ah. Edited January 5, 2020 by Ivan 2 Urra and gorank82 reacted to this Quote Share this post Link to post Share on other sites
Axic 19728 Posted January 5, 2020 @Ivan predajem se od sada kad neko pita bilo šta vezano za akumulatore neću više reč da prozborim s tobom, povlačim se. Quote Share this post Link to post Share on other sites
bane1321 5823 Posted January 5, 2020 (edited) 1 hour ago, Ivan said: Ne mora da znaci, vozila sa Stop&Start koriste EFB akumulatore ako su mikro-hibrid1 (uglavnom vecina narodnih sa S&S) ili AGM akumulatore za mikro-hibrid2 (sa sistemima regenerativnog kocenja). AGM akumulatori su primetno skuplji, sa drugacijom tehnologijom, zbijenijim plocama izmedju kojih je sloj od fiberglasa, a omogucavaju do 5 puta brze punjenje i do 3 puta vecu izdrzljivost. AGM akumulator se mora zameniti sa AGM, a EFB moze sa EFB ili AGM. Sa kakvim predznanjem se ide u kavanu! Edited January 5, 2020 by bane1321 Quote Share this post Link to post Share on other sites
Djuk85 2981 Posted January 5, 2020 [mention=16656]rage_man[/mention] Raspitivao sam se malo Kako izgleda kad se mnogo raspituješ? Sent from my Redmi 4X using Tapatalk 1 1 rage_man and Axic reacted to this Quote Share this post Link to post Share on other sites
Ivan 17454 Posted January 5, 2020 (edited) Nove tehnologije, sta cu, moram - jedino ako neces da te po radnjama vozaju sa poluinformacijama. 16 minutes ago, bane1321 said: Zar nije obratno? EFB je, koliko se secam, za mojega Resoa bio skuplji od AGM! Moguce da zavisi i od proizvodjaca ili amperaze, generalno je AGM tehnologija za najzahtevnija vozila. Konkretno Exide, 60Ah - AGM su bili 2000 din skuplji od EFB kada sam zvao (slagacu te za tacan iznos, ali reda velicine 16.000 din vs 14.000 din). Slicno je vazilo i za vece amperaze. Svakako su oba tipa primetno skuplji od klasicnih akumulatora, za vozila bez Stop&Start. Edited January 5, 2020 by Ivan 1 Djuk85 reacted to this Quote Share this post Link to post Share on other sites
bane1321 5823 Posted January 5, 2020 Moj zez, zato sam I ispravio post. EFB je jeftiniji od AGM, moj je upravo EFB! Quote Share this post Link to post Share on other sites
totti 13151 Posted January 5, 2020 Šta se misli pod prijavljivanjem novog aku dijagnostikom, tj šta se desi ako se ne prijavi? Pošto iz mog iskustva se ne desi ništa .A ovaj Axic... valjaju mu Monbati i Biloxiji, a Tigar ne valja Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
rage_man 128 Posted January 6, 2020 Uzet Exide 60Ah 540A 3 god garancije, 7100 din za gotovinu u Kit komercuSent from my SM-A520F using Tapatalk Quote Share this post Link to post Share on other sites
