totti 13151 Posted August 15, 2020 3 knezevic76, chikavili and neshtry reacted to this Quote Share this post Link to post Share on other sites
neshtry 14519 Posted August 15, 2020 2 knezevic76 and silenci reacted to this Quote Share this post Link to post Share on other sites
Boris90 367 Posted August 15, 2020 Rusi u zadnje vreme objavljuju dosta zanimljivih snimaka. Prvi put da vidim Mi-24 u ovoj ulozi Quote Share this post Link to post Share on other sites
neshtry 14519 Posted August 15, 2020 Korona ih opametila... Quote Share this post Link to post Share on other sites
silenci 2316 Posted August 15, 2020 djavolje kočije Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted August 16, 2020 2 Desmo and neshtry reacted to this Quote Share this post Link to post Share on other sites
Desmo 428 Posted August 16, 2020 (edited) On 8/15/2020 at 3:34 PM, totti said: Sent from my SM-G950F using Tapatalk A civilima uvaljuju "nove" modele automobila na svake tri godine. Introduction February 1955 Status In service https://en.wikipedia.org/wiki/Boeing_B-52_Stratofortress Introduction June 1957 Status In service https://en.wikipedia.org/wiki/Boeing_KC-135_Stratotanker Greyhound jos uvek u upotrebi, prevozi pisma do kopna i nazad Hawkeye i P3 orion isto prelepi avioni. Introduction August 1962[1] Status Active P3 koristi NOAA za izvidjanje uragana: Edited August 16, 2020 by Desmo 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted August 16, 2020 Kako radi kontrola leta na Frankfurtskom aerodromu. Ređa ih na dva minuta. Quote Share this post Link to post Share on other sites
Ticma 533 Posted August 19, 2020 I na manje, imaju uslove i brze izlaznice... Quote Share this post Link to post Share on other sites
totti 13151 Posted August 19, 2020 O'Hare beše najprometniji na svetu po broju poletanja/sletanja? Quote Share this post Link to post Share on other sites
chikavili 511 Posted August 19, 2020 Bio nekada. Pretekli ga Peking, Dubai, Atlanta i jos neki. Ne secam se tacno poretka Edit: ispravljam se. po poletanjima i sletanjima O’hare je i dalje na prvom mestu. Ono je po transferu putnika Sent from my Texas Instruments Scientific Calculator using Tapatalk Quote Share this post Link to post Share on other sites
Ticma 533 Posted August 19, 2020 Ali broj operacija po jednoj pss i tehnologiji rada, svi se uce na Frankfurtu. Quote Share this post Link to post Share on other sites
silenci 2316 Posted August 20, 2020 a Nikola Tesla,jos kad se zavrse svi radovi Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted August 20, 2020 On 8/14/2020 at 9:52 AM, ivan.ik said: Računica je 23 miliona € godišnje subvencije i još 5 miliona € za letove iz Niša i Kraljeva a deca se leče SMS-om. Pa šta lete koji đavo kad imaju među skupljima karte. I kako Rayan I ostalo društvo opstaje sa smešno jeftinim kartama? Računica je bezveze, a poređenje nema osnova. LCC i klasični avio-prevoznici se ne porede međusobno. Mada, danas i ti klasični na kraćim linijama uvode plaćanje skoro za sve dodatno, tj. uvode hibridni model. Rayan i društvo nema ''smešno jeftine'' karte, nego ima ''smešno jeftinu'' kartu...dve ili tri. Da li ima nekoga ko veruje da je moguće imati 200 putnika po 20 evra, leteti 120 minuta, platiti takse za oba aerodroma od te cene, i da opet ostane aviokompaniji? Ali, 200 putnika od kojih njih 3 ili 5 plati do 20 evra, a preostalih 195 plati skuplje od toga (90-100 evra) na kraćem letu, plus se sleti na neki sporedni aerodrom zbog manjih taksi, plus se uglavnom ima subvencija od tog aerodroma (kao što u regionu daju Tuzla ili Skoplje za Wizz), ne koriste se aviomostovi nego se putnici u najboljem slučaju transportuju autobusima od aviona do gejta, plus je razmak između sedišta manji kako bi ih više stalo u avion, plus ne može nikakav prtljag jer se on doplaćuje (može samo ručni u kabinu), plus drugačija (manja) prava u slučaju otkazivanja leta....e, to već vidimo da jeste moguće i isplativo jer ima uspešnih LCC prevoznika. On 8/14/2020 at 12:16 PM, totti said: Juče kucam bezveze BG - Štokholm na Wizz-u za Septembar... 5500 povratna karta Doduše samo za mali kabinski prtljag, al' opet... Nijedna LCC kompanija neće imati jeftine karte ako ne mora da ih ima. Cene iz Beograda preko LCC kompanija su takve baš zbog postojanja jake Air Serbia. Kad sutra ne bi imali domaćeg jakog avioprevoznika, karte preko LCC iz Beograda ne bi ostale tu gde su sada, nego bi porasle u nebo. Iako vlada neka fama da se Air Serbia štiti, pogledajte samo koliko LCC letova ima iz Beograda....a, pogledajte koliko LCC letova ima iz npr. Zagreba. E, to u Zagrebu se zove zaštita domaćeg prevoznika, i dobro je da u Beogradu nije tako. 2 bit and Mijailović P. reacted to this Quote Share this post Link to post Share on other sites
neshtry 14519 Posted August 20, 2020 A AirSerbia je po uslugama mnogo odskače od LCC....Rajan je izmislio avio transport za AirSerbia.Sve uračunanjivo,izračunaš kući i to ti je. A kod ove naše.... Avantura! Imam sveža iskustva sa Rajanom do Londona i AirSerbia za New York.... Quote Share this post Link to post Share on other sites
neshaoct 9584 Posted August 20, 2020 (edited) 48 minutes ago, neshtry said: A AirSerbia je po uslugama mnogo odskače od LCC....Rajan je izmislio avio transport za AirSerbia.Sve uračunanjivo,izračunaš kući i to ti je. Nije. Ne poredi se LCC sa klasičnim avio-kompanijama na taj način. Za obe vrste usluge ima mesta (što tržište pokazuje) jer ljudi imaju različite potrebe. Nekome odgovara da kupuje kartu mesec dana (ili više) unapred, nekome ne. Nekome odgovara da sleće na glavni aerodrom, a neko nema problem da sleti i na 100 kilometara daleko. Neko ima problema sa komforom u kabini, nekome je svejedno za manji prostor za noge jer je ionako npr. neki kraći let u pitanju pa će izdržati, itd, itd.... Ima jedan svetski poznati primer koji se dogodio Lufthansi u Minhenu. Lik je platio njenu skupu biznis kartu (oko 750 evra), i kao jedno od prava koje mu pripada je i pravo da može da pomeri svoj let za bilo koji drugi datum, bilo kada, bez ikakvih penala. Takođe, imao je i pravo pristupa Lufthansa salonu na aerodormu u Minhenu, odnosno da jede i pije šta god poželi. I, on tako dođe, pokaže kartu, oni ga puste u salon, on pojede, popije...i ode da odloži let za sledeći termin. Na dan novog leta lik opet dođe sa validnom biznis kartom, opet uđe u salon, opet pojede i popije šta god želi...i opet ode da pomeri let za sledeći termin. Onda narednog termina opet dođe sa validnom biznis kartom...i pogađaš već šta je lik radio. Ništa od toga ne može da radi sa LCC, ali može sa klasičnim avio kompanijama jer one nude takvu uslugu. I Air Serbia ima svoj Lounge na BEG. Lik je tako uradio 35 puta. Lufthansa mu je posle nekih godinu dana poništila tu kartu i vratila njegovih 750 evra. On je kupio opet drugu kartu sa očiglednom namerom da ponovi sa njom sve isto...i tek tada ga je Luftika dala na Sud. Epilog sudskog postupka je da je lik morao da plati 1.980 evra Lufthansi za tih njegovih 35 boravaka, odnosno prosečno nešto preko 55 evra po svakoj poseti. Edited August 20, 2020 by neshaoct 3 SalacUE, Mijailović P. and ata reacted to this Quote Share this post Link to post Share on other sites
neshtry 14519 Posted August 20, 2020 Ta prava ,onaj ko je leteo sa AirSerbia,a uspeo da ih upotrebi,nek se javi da ga vidim....i da malko popričam,živo me zanima kako je uspeo,pored one male kesice grickalica...Ozbiljan sam! Sent from my motorola one macro using Tapatalk 2 Zvezdo and knezevic76 reacted to this Quote Share this post Link to post Share on other sites
knezevic76 6885 Posted August 20, 2020 Ta prava ,onaj ko je leteo sa AirSerbia,a uspeo da ih upotrebi,nek se javi da ga vidim....i da malko popričam,živo me zanima kako je uspeo,pored one male kesice grickalica...Ozbiljan sam! Sent from my motorola one macro using Tapatalk Slažem se, meni je Air Srbija LCC po svim parametrima osim po ceni karata i veličini aviona.Sa Rajanom do švabije, znam da nisam platio kesicu "ribica" i znam da sam platio više nego duplo jeftiniju povratnu kartu al opet, jedino što su ranije rezervisane karte i nisam poleteo iz BGa.Sve u svemu, AirSerbia je po mom skromnom mišljenju, daleko od onoga što treba da bude.Послато са SM-A715F помоћу Тапатока 2 Grafit and Zvezdo reacted to this Quote Share this post Link to post Share on other sites
Desmo 428 Posted August 24, 2020 3 1 Grafit, SalacUE, ivan.ik and 1 other reacted to this Quote Share this post Link to post Share on other sites
totti 13151 Posted August 24, 2020 Sent from my SM-G950F using Tapatalk 2 Woodoo and knezevic76 reacted to this Quote Share this post Link to post Share on other sites
Desmo 428 Posted August 26, 2020 C-124 Globemaster making a delivery, ironic, since delivery is synonymous with giving birth, and that immediately came to mind, small airplane from big one 2 Martin and knezevic76 reacted to this Quote Share this post Link to post Share on other sites
neshtry 14519 Posted August 27, 2020 Kako je kul 1 chikavili reacted to this Quote Share this post Link to post Share on other sites
SalacUE 758 Posted August 27, 2020 A tek da ga Alfa šlepa Poslato sa NOVA 5T pomoću Tapatoka 1 neshtry reacted to this Quote Share this post Link to post Share on other sites
Boris90 367 Posted August 30, 2020 2 ata and neshtry reacted to this Quote Share this post Link to post Share on other sites
ata 77 Posted August 30, 2020 Žvaće, žvaće... aaa... Treba u obaveznu opremu natovcima uvrstiti i pelene... 2 Boris90 and SalacUE reacted to this Quote Share this post Link to post Share on other sites
