stefan148 0 Posted February 18, 2009 mislis uvucenije su za 6mm... Quote Share this post Link to post Share on other sites
the_reaper 2 Posted February 18, 2009 rub bi trebalo da bude ok, samo da ti ne pravi problem sa amortom, jvaljaj sta se zbiva Quote Share this post Link to post Share on other sites
Vukasin 0 Posted February 18, 2009 da, uvucenije su... Valjda ce biti no problem, nabavicu i distance od 5mm... Danas kupujem nove gume 195/45... Quote Share this post Link to post Share on other sites
Vukasin 0 Posted February 18, 2009 Kupljeneeeeee Quote Share this post Link to post Share on other sites
chikavili 511 Posted February 18, 2009 Pretpostavljam neke za skijanje? Quote Share this post Link to post Share on other sites
Vukasin 0 Posted February 19, 2009 Barum Bravuris 195/45/16" 4 kom. 25000 sa popustom 15% Sad jos samo da se odlucim za boju. Opet me vuce na belo, jbg, mala je felna i dosta je "gusta" za crno... Al opet... Videcemo... Quote Share this post Link to post Share on other sites
the_reaper 2 Posted February 19, 2009 ja b' to u belo, vec znas da izgleda bolesno Quote Share this post Link to post Share on other sites
chikavili 511 Posted February 19, 2009 Superturismo definitivno bolje izgleda u beloj boji, al bi na primer crna ultaraleggera legla ko dupe na noshu Inace, problem za crnu varijantu je sto ST ima mali spoljni falc i ne verujem da bi lepo ispala crvena linija.Mada ni crni Superturismo uopste nije los, ali u velikim precnicima: Quote Share this post Link to post Share on other sites
Vukasin 0 Posted February 19, 2009 Leggera je drugo, to su decacki snovi... a ST bar da je 17... Jel imate nekog ko farba i peskira felne za pristojne pare? da nije usranko ili roki... posto oni samaraju sa ciframa... Quote Share this post Link to post Share on other sites
the_reaper 2 Posted February 19, 2009 cuo sam za nekog decka na bulevaru da je ok i sa cenama i sa radom, ali ne znam zasto mislim da sam to cuo od tebe? jesi uradio nesto za distance Quote Share this post Link to post Share on other sites
Vukasin 0 Posted February 19, 2009 Nabavio sam jugova 2, nabavicu jos 2 ali mislim da ce mi trebati od 1cm za pozadi. Sutra idu felne na farbanje, pa kad se sredi tu, montaza guma i onda probe s distancima i kurcima Jel si slobodan ti ovih dana da isprobamo sa 12mm distancom, kad stavim gume? Quote Share this post Link to post Share on other sites
the_reaper 2 Posted February 19, 2009 moze naravno, okreni me kad metes gume pa se dogovaramo a gewinde? Quote Share this post Link to post Share on other sites
Vukasin 0 Posted February 19, 2009 Gewinde cim resim 16ice Taman da ode ovaj sneg... Quote Share this post Link to post Share on other sites
Vukasin 0 Posted February 20, 2009 Odneo sam danas na plastifikaciju, preveliki je sex i trosak crno sa crvenim lipom, a i bas sam skeptican po pitanju izgleda na 16" felni. Mozda cu da oprobam belo sa crvenim lipom al otom potom. Sutra stavljam nove gume i isprobavam varijante sa distancima, nabavio sam 6 jugovih od 5mm pa da vidimo... Quote Share this post Link to post Share on other sites
Vukasin 0 Posted February 21, 2009 E pa ljudi, od ovog ne moze bolje na ovom autu, definitivno!!!Jos kad legnu gewinde, savrsenstvo! Quote Share this post Link to post Share on other sites
Goxy 0 Posted February 22, 2009 video sam felnice sinoc na mom parking,stwarno su sexyyyyy ...pun pogodak... Quote Share this post Link to post Share on other sites
MilosLB 9 Posted February 22, 2009 extra su,super mu stoje,svaka čast. Quote Share this post Link to post Share on other sites
the_reaper 2 Posted February 22, 2009 kao sto sam vec rekao. . . PORNO Quote Share this post Link to post Share on other sites
chikavili 511 Posted February 25, 2009 Uzivo izgleda mnogo dobro. 16" je stvarno prava mera za look tog auta. Jos samo da turis gewinde, pa da vidis kako ce se ponasati (u izgled ne sumnjam )Kad planiras da ofarbas onu desnu stranu pa da sve bude tip-top? Quote Share this post Link to post Share on other sites
Vukasin 0 Posted February 25, 2009 Na prolece! Sad sam prao kola, krivo mi je sto nisam poneo aparat, nije sto je moj ali je brutalan (S leve strane hahahah) I da... Moram da se resim one impotencije s leve strane Quote Share this post Link to post Share on other sites
zaki 0 Posted February 25, 2009 Kako dobro stoje! Quote Share this post Link to post Share on other sites
Vukasin 0 Posted February 28, 2009 E pa nema vise sindroma Vukasin! Montirane gewinde i zamenjene solje usput... Nazad je legao jedno... pa sta znam, 30mm a napred recimo 50mm, plus sto moze da se zavrne jos 4-5cm Tvrd je taman koliko treba, idealno, nisam ga jos provozao muski, tako da ne mogu jos da prenesem utiske, ali cini se da je to to, samo jos da se usteluje sve kako valja i raj... Quote Share this post Link to post Share on other sites
NenadAleksic 0 Posted February 28, 2009 Odlican posao uradjen. Quote Share this post Link to post Share on other sites
