tatamata 2 Posted September 18, 2010 tako blizu a tako daleko nadam se da sam upravu, a ako ne izvinte na šali.5 - SVC, volume changing withcar speedThe SVC function makes it possibleto automatically adapt the volumelevel to the speed of the car, increas-ing it as the speed increases to main-tain the ratio with the noise levelinside the passenger compartment.Press 15 (<<) or 6 (>>) to changeSVC setting, thus passing from OFFto the selected gain level (from 1 to7). High gain level values correspondto proportionally higher volumeincreases according to speed.The display will show the currentstatus of the function:“SPEED VOLUME OFF” =function off“SPEED VOLUME: +3” = func-tion on and gain level indicationPozdrav Quote Share this post Link to post Share on other sites
nidza 621 Posted September 18, 2010 Sad sam malo zbunjen? Ja sam više puta raskačinjao akumulator i nikad mi nije tražio nikakav kod?ni meni... samo treba sto pre da se zameni... mislim da je rok 15 minMa jok, mislim da to možda važi za naknadno ubačene uređaje - oni koji su išli fabrički valjda ne bi trebali da izgube kod?Nagađam, nisam siguran, jer je bilo situacija kad je auto bio raskačen satima sa akumulatora. Quote Share this post Link to post Share on other sites
erikc3000 0 Posted September 20, 2010 mozda niste znali to ... kad imas daljinski stisnes da otvoris vrata i drzis dugme i stilo sam otvara prozore isto i sa zakljucanjem ako drzite dugmic on sam zatvara ali pazite samo toliko vremena koliko vi drzite Quote Share this post Link to post Share on other sites
Mijailović P. 3449 Posted September 21, 2010 Sto se tice koda za radio u autu (originalni) , definitivno ga trazi samo pri promeni uredjaja ! Znaci , mozes i raskaciti isti pa ga vratiti nece zahtevati kod! PROVERENO ! Quote Share this post Link to post Share on other sites
tatamata 2 Posted September 25, 2010 a ako zatraži evo ovde kako ga pronaćiali mi avast kaže da je malver, pa skidate na svoju odgovornost ili potražite na drugom mestu.Pozz Quote Share this post Link to post Share on other sites
Stylo 1 Posted September 25, 2010 Za sta sluzi onaj otvor pored volana sa desne strane, tj pored brave? Quote Share this post Link to post Share on other sites
LordMarcus 0 Posted November 3, 2010 (edited) *1ja sam dobio dva kljuca, oba kod, ali nijedan sa dugmicima, ali auto ima daljinsku i kako mi je receno alarm, mada ja ga nisam uspeo aktvirati. a uz kljuceve sam dobio dva kruzica precnika sirine kljuca sa crnim dugmetom u sredini koji radi lock/unlock, a sam krug je plave boje kao i kljuc o ima fiatom logo urezan...probao sam ovo sa prozorima i nece da radi...*2ne mogu da ubacim kljuc u bravu vrata ni na vozacevim ni na suvozacevim?*3jel postoji osvetljenje ona tri tockica za temp, vent i pravac duvanja, n centralnom stubu, jer kod mene je sve u mraku, samo sijaju ona tri tastera ispod? Edited November 3, 2010 by Lord Markus Quote Share this post Link to post Share on other sites
sasha015 34 Posted November 3, 2010 1. 2 kljuca sa dugmicima(skakavca).To je valjda standard.Ostalo sve mislim da je budzeno i pravljeni ljucevi pa kodirani.Skakavci novi su skuplji 2 puta valjda od obicnog bez komandi.2.OPet je nesto zbudzeno.Kljuc mora da udje u bravu.3.Postoji osvetljenje.Mora da se skine cd plejer i onda da se odvrne piksla i onda se skida ta plasticna maska oko dugmica za ventilaciju.Ovde oprez da ne puknu zabice na ukrasnoj plastici..Dugmici se samo izvuku,a pikslu je potrebno skinuti jer onda imas pristup plasticnim zabicama sa donje strane ukrasne plastike.Cd plejer se vadi da bi imao pristup zabicama sa gornje strane ukrasne plastike.(3 zabice dole -3 gore i onda se skine ukrasna platika i imas pristup sijalicama.Takodje postoji osvetljenje piksle i osvetljenje oko upaljaca(meni ovo ne svetli,mrzi me da se cimam oko menjanja)Imas uputstva na forumu i slike kako se sve skida...potrazi malo Quote Share this post Link to post Share on other sites
ivan73 337 Posted December 8, 2010 Za sta sluzi onaj otvor pored volana sa desne strane, tj pored brave? E ova ti je dobra! I ja se pridruzujem pitanju. Quote Share this post Link to post Share on other sites
Branko 0 Posted December 8, 2010 ^^^ Ja sam tu uglavio BT GPS reciver extra se uklopio, kao da je za njega pravljen a i dovoljno viri napolje da bi imao dobar prijem satelita. Ako ga jos neko koristi za nesto neka da ideju! Quote Share this post Link to post Share on other sites
speedster 0 Posted December 8, 2010 Da nije za START/STOP dugme? Quote Share this post Link to post Share on other sites
kAcA 0 Posted December 8, 2010 ^^ Jeste. Bas za to Quote Share this post Link to post Share on other sites
boki 10 Posted December 9, 2010 Ako ga jos neko koristi za nesto neka da ideju! ja tu stavim flasu od 2L koka-kole... Quote Share this post Link to post Share on other sites
ivan73 337 Posted December 9, 2010 Aaaaa... to mora da je neko japansko pakovanje... Quote Share this post Link to post Share on other sites
Ac Milan 0 Posted January 6, 2011 Poz svima ... Imam jedno pitanje da libi mi radili grejaci na retrovizoru ako bi uzeo obicno staklo i stavio na levi retrovizor ? Posto mi je neko skinuo staklo sa retrovizora :wallbash: Quote Share this post Link to post Share on other sites
ChobbyNS 303 Posted January 6, 2011 Vidim da si milanista,ali ajde odgovoricu ti Nece raditi grejaci sa obicnim staklom,ali mozes probati ovde da nazoves,vidim da je staklo s grejacem 5 evra http://www.tuning-shop.rs/fiat_auto_delovi_2.htmlForza Inter Quote Share this post Link to post Share on other sites
mikistilo5 0 Posted April 11, 2011 U potrazi za kljucem (rezervom) koji naravno nisam dobio na placu u NS gde sam kupio stila nailazim na raznorazne cene cak do 15000 dinara i ne mogu da verujem da su te cene u rasponu od 6500 do 15000 dinara,uglavnom ima jedna pijaca Novom Sadu, Satelit,tamo mi je covek koji ima kljucarsku radnju(bravar)rekao da je cena kljuca sa cipom 6500 din,sto mi se cini ajde i ok cenom u odnosu na druge.http://homemademachine.dzaba.com/forum.htmNa rucici zadnjih vrata postoji mikroprekidac preko koga verovatno elektomagnet dobija masu i on je kriv u vecini slucajeva za takve i slicne kvarove oko ne otvaranja zadnjih vrata,nije ga tesko zameniti a slican kosta u radio klubu NT oko sto dindzi ,zato sa malo zdravog razuma izbegavas trosak od 30-40 evra koliko traze za polovnu rucicu zadnjih vrata pozdrav.http://homemademachine.dzaba.com/forum.htm Quote Share this post Link to post Share on other sites
DADO44 0 Posted October 26, 2011 Memorisanje polozaja retrovizora pri voznji u rikverc ? O tome je bas skoro bilo reci...Imam podizace na vratima od vozaca i za ostle prozore, al nisam skonto kako da podesim ove retrovizore za voznju u rikverc? Quote Share this post Link to post Share on other sites
vladac81 23 Posted October 26, 2011 (edited) Mozes da memorises ali samo pod uslovom da imas elektropomicna sedista Edited October 26, 2011 by vladac81 Quote Share this post Link to post Share on other sites
tatamata 2 Posted April 28, 2012 nadam se da neko već nije stavio... Quote Share this post Link to post Share on other sites
marybo 0 Posted September 19, 2012 od skora imam stila 1.9 jtd 3v kada sam ga kupio nakon vadjenja kljuca iz brave i izlaska napolje se sam zakljucavao, posle skidanja akumulatora to vise ne rad...kako ga ponovo ukljuciti i naravno kada ga zakljucam na daljinca nemam alarm samo brave odrade nikakav zvucni signal...hvala unapred pametnim momcima Quote Share this post Link to post Share on other sites
nidza 621 Posted September 20, 2012 Moj to nikad nije radio. :-) Prvi put čujem za ovo.Da li ima fabrički alarm? Quote Share this post Link to post Share on other sites
ivan.ik 625 Posted September 20, 2012 Ima tu opciju, meni je to radio pa sam negde u meniju isključio. Mada iskreno nisam siguran koji su kriterijumi. I dalje imam strah da će me zeznuti i zaključati ključeve. Quote Share this post Link to post Share on other sites
Branko 0 Posted September 20, 2012 Mislim da ako nema alarm ta opcija ne postoji. Quote Share this post Link to post Share on other sites
