despot83 0 Posted March 17, 2013 pozdrav svima. imam fiat punto 1.2 8v koji kad se dobro zagreje izmedju 2000 i 3000 obrtaja ispusta zvuke lupanja lezajeva na radilici.skinuo sam karter i utvrdio da klipnjaca treceg cilindra ima lufta u velikoj pesnici u odnosu na radilicu.zameno sam letece lezajeve ali bezuspesno.zna li neko da lise isplati vaditi motor i odraditi donji deo? Quote Share this post Link to post Share on other sites
Gusar 4 Posted March 17, 2013 Isplati se i to sto pre da ti ne okrene lezaj... Quote Share this post Link to post Share on other sites
Branko 23 1 Posted March 17, 2013 Moras to raditi,jer nista nisi postigao,nema ti druge,jbga Quote Share this post Link to post Share on other sites
despot83 0 Posted March 17, 2013 nisam majstor za kola ali prckam po malo.ajd onda sutra da vadim motor.pa javljam sta sam uradio. Quote Share this post Link to post Share on other sites
Gusar 4 Posted March 17, 2013 (edited) posto nije uspela zamena lezajeva znaci da je radilica pobegla malo mora da se obradjuje... Edited March 17, 2013 by Gusar Quote Share this post Link to post Share on other sites
Goran Zemun 441 Posted March 17, 2013 Taj motor cesto razbije rupu u klipu, pa osovinica prosto landara gore dole. Inace osovinica i klipnjaca imaju cvrsti spoj. Quote Share this post Link to post Share on other sites
despot83 0 Posted March 17, 2013 (edited) mislis da je problem u maloj pesnici?ili u samom klipu? Edited March 17, 2013 by despot83 Quote Share this post Link to post Share on other sites
Goran Zemun 441 Posted March 17, 2013 Mislim da je problem u velikom zazoru izmedju osovinice i klipa. Quote Share this post Link to post Share on other sites
despot83 0 Posted March 17, 2013 tu je resenje novi klipovi? Quote Share this post Link to post Share on other sites
Goran Zemun 441 Posted March 18, 2013 Da ali prvo moras rasturiti motor da vidis da li je to kvar. Quote Share this post Link to post Share on other sites
despot83 0 Posted March 18, 2013 zna li neko koja je cena klipova sa karikama Quote Share this post Link to post Share on other sites
MS PK 7728 Posted March 18, 2013 Zna npr Ap sport ili slicne prodavnice auto delova Klikni na baner na vrhu stranice Quote Share this post Link to post Share on other sites
despot83 0 Posted March 19, 2013 ovako stoje stvari. klipnjaca i klipovi dobri bez luftova.odneo radilicu na brusenje i uljnu pumpu na proveru.blok na merenje cilindra i honovanje.zamenicu lezajeve i karike.pa sta mi bog da. Quote Share this post Link to post Share on other sites
mare batica 0 Posted March 22, 2013 meni se takodje čuje neko čangrljanje kada dodam gas,negde izmedju 2 i 3 hiljade obrtaja,ne bih konkretno znao da kažem iz kog dela motornog prostora se čuje,ali mi zvuči kao da je negde pri dnu,kod katrera. da li je moguće da te zvukove ispušta radilica,ili neki deo izduva? Quote Share this post Link to post Share on other sites
MS PK 7728 Posted March 22, 2013 Moguce je ali ti to niko ne moze reci preko foruma, mora da cuje majstor uzivo. Moze da budu i lezajevi a moze i kao kod kolege koji je maler bas da ima lufta i u pesnici, sto je mnogo redje a i skuplje. Quote Share this post Link to post Share on other sites
mare batica 0 Posted March 23, 2013 ja kao i svaki Srbin odmah pomislim na najgore.jbg, nisam imao sa kim da proverim gde se čuje taj zvuk dok neko drži gas.medjutim,danas uhvatim ortaka da mi pomogne i zajedno utvrdimo da taj zvuk dolazi od lima koji stoji preko izduvne grane,pao mi je kamen sa srca. Quote Share this post Link to post Share on other sites
despot83 0 Posted March 23, 2013 evo i mene. danas upalio motor.konacno.za sada motor peva.definitivno je bio problem u lezajevima radilice.hilzne i posle predjenih 150000 km nisu ni mrdnule.zamenio karike.honovao hilzne.obradio i radilicu i zamenio lezajeve.cirka bez ruku 300e.sa setom kvacila naravno Quote Share this post Link to post Share on other sites
Gusar 4 Posted March 23, 2013 Dobro si prosao... Quote Share this post Link to post Share on other sites
MS PK 7728 Posted March 24, 2013 Glavu nisi dirao, set zupcastog i garnitura dihtunga i semeringa ili je to cena samo za ovo sto si naveo? Quote Share this post Link to post Share on other sites
despot83 0 Posted March 31, 2013 veliki servis sam odradio 1000 km pre ovoga.kupi sam samo semerige i dihtung glave.glavu samo ocistio zamenio ulje i filter. a da dihtung uljne pumpe napravio. karter se lepi lepkom.inace je 300 e sa svime time. presao od sklapanja oko 800 km za sada sve je ok. Quote Share this post Link to post Share on other sites
Gusar 4 Posted March 31, 2013 nadam se da si odradio uljne kanale na radilici posto je moguce da je problem nastao zbog zacepljenja nekog od njih... Quote Share this post Link to post Share on other sites
despot83 0 Posted April 3, 2013 mislim da bi bilo glupo da odneses radilicu na masinsku obradu a da ne provere sistem za podmazivanje.ne znam, valjda su proverili.valjda. Quote Share this post Link to post Share on other sites
strahinja987 8 Posted March 8, 2020 Pozdrav momci, naime na mom 1.2 8v kad se motor bas dobro zagreje prilikom ubrzanja i posebno voznjom uz brdo dakle pod opterecenjem, cuje se zveckanje iz motora dok ne ode u vise obrtaje, isto zveckanje sam cuo na zastavama kad im ventili zveckaju, ali sta je to kod punta? Na hladan motor sve ok, u leru nema zveckanja kolko god turirao nista, samo pri opterecenju i na vreo motor! Auto lepo ide, u leru lepo radi jedino sto to zvecka i to se cuje jasno npr kad su otvoreni prozori i kroz usku ulicu gde se zvuk odbija od ograda pa tad ga jasno cujem kad dodam gas tad zazvecka dok ne ubrza...pomozite savetom, moj majstor nesto nagadja najcrnje, da je klip dobio luft mozda, mada mi to ne pije vodu, i u leru bi lupao vise nego zveckao? Hvala svima Quote Share this post Link to post Share on other sites
