Milosnis18 7 Posted September 2, 2011 ja se ubih od trazenja ali nema. danas sam menjao prvi put ulje od kad je imam zamenio filter ulja, vazduha ali za benzin nema a kupio sam u AP-sportu a majstor kaze druze ko ti prodao ovo uzimaju ti pare badava, a ne nosi? Quote Share this post Link to post Share on other sites
klaywert 0 Posted September 2, 2011 ako sam te ukapirao, da li si hteo da pitaš da li filter ima dovoljan protog goriva, ulja, šta? Quote Share this post Link to post Share on other sites
Xepoj 1 Posted September 2, 2011 nisi ga ukapirao covek hoce da zna da li njegov auto ima filter goriva jer su mu ga ovi u AP sportu prodali, a on ne moz' da ga nadje ja samo mogu da pretpostavim da nemas filter goriva jer,moj bravo (2000god) nema filter, dok ga stariji modeli imaju... Quote Share this post Link to post Share on other sites
integralac 2566 Posted September 2, 2011 nema filtera sto je otudjujes? Quote Share this post Link to post Share on other sites
Milosnis18 7 Posted September 2, 2011 Koji shit znaci dizne me cekaju da ih cistim poceo je ujutru da trokira dok je ladan )) ma malo mi nelogicno ovoliki motor a nema filtera ali ok ko ga sisa. Integralac nisam te razumeo skroz?? Quote Share this post Link to post Share on other sites
integralac 2566 Posted September 2, 2011 otudjivanje=prodajanadjoh je na oglasu Quote Share this post Link to post Share on other sites
Milosnis18 7 Posted September 2, 2011 nema je vise ja zaboravio da to stoji... delete upravo Quote Share this post Link to post Share on other sites
Radan 0 Posted September 3, 2011 Kako bre nema filter goriva? Ja na mojoj Kapi (isto 2.0 20v) menjao, stoji odmah pored rezervoara. Jedino ako je neko prespojio cev i izbacio filter... Quote Share this post Link to post Share on other sites
klaywert 0 Posted September 3, 2011 ali i da ga nema, jer mi je 2000% nelogično da ga nema, uvek može da se stavi tj ugradi. Quote Share this post Link to post Share on other sites
integralac 2566 Posted September 3, 2011 ja sam taj info dobio od martinijacovek je odrzavao moju od uvoza tj 6 godinakad sam je ja uzeo pitao sam ga, odgovor nemamozda je kod tebe naknadno uradjen ili mozda bas moja nema ???? Quote Share this post Link to post Share on other sites
Milosnis18 7 Posted September 3, 2011 gde kod rezervoara druze? ja sam na kraju sam uparkirao na jednom kanalu i pratio creva od motora do nazad nema, creva idu odmah u rezervoa? Quote Share this post Link to post Share on other sites
Radan 0 Posted September 3, 2011 Na mojoj Kapi je odmah pored rezervoara (prema motoru), blizu desnog praga. Tacno i ima prostor taman za filter. Licno sam menjao sa kolegom, doduse pre 2 godine, kad sam dobio set svih filtera iz Italije. Ne deluje mi da je "nabudzen" jer svi oni prikljuci deluju original (sa onim supljim srafovima). Sam filter je onako srednje velicine, oko 10 cm u precniku i mozda isto toliko dug, koliko se secam. Cak sta vise, sigurno je tako fabricki, jer je taj novi filter bio apsolutno isti kao stari, tako da sigurno postoji filter za taj auto, a cim postoji filter, mora da postoji i mesto za njega ;-) Quote Share this post Link to post Share on other sites
Milosnis18 7 Posted September 3, 2011 a ja bas sad trazio nesto na netu i kao zavisi za koje je trziste auto bio neki su nosili filter a neki ne, verovatno je moj bas za to trziste. tako da ko ga je.. )) Quote Share this post Link to post Share on other sites
Srdjan 0 Posted September 3, 2011 Kod mene isto nema. Tako da ima i jedna i druga varijanta. Quote Share this post Link to post Share on other sites
Milosnis18 7 Posted September 3, 2011 znaci dizne jer je poceo da stuca kad je hladnije znaci ujutru preko dana nema... Quote Share this post Link to post Share on other sites
Martini 11 Posted September 4, 2011 Od 6/98 filtera nema, nego je on integrisan u vidu fine mrezice u kuciste benzinske pumpe. Quote Share this post Link to post Share on other sites
Milosnis18 7 Posted September 4, 2011 tu nema ciscenja tog filtercica znaci samo dizne mogu da zajebu stvar? Quote Share this post Link to post Share on other sites
Martini 11 Posted September 5, 2011 Dizne a moze malo i protokomer. Quote Share this post Link to post Share on other sites
Radan 0 Posted September 5, 2011 Martini, kad si vec spomenuo protokomer, moze li on da se cisti i kako? A i kako znas kada je los? Quote Share this post Link to post Share on other sites
Martini 11 Posted September 5, 2011 Protokomer na kappi se ne cisti kao klasican jer je jako osetljiv. Desava se da puca i da teze prima gas kad je hladan a meri se putem dijagnostickog uredjaja. Quote Share this post Link to post Share on other sites
