branna 0 Posted November 10, 2014 Ok hvala na brzim odgovorima. Resavacu nesto cim pre. A prijatelj je stvarno dobar on me zeznuo nesvesno a njega su svesno zeznuli u ovlascenom servisu. Mislim da je njemu teze. Sledi otvaranje motora i sve sto ide uz to. Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted November 10, 2014 (edited) Njemu moze da bude tesko samo ako on placa opravku. A ako ide iz tvog dzepa, mislim da je tebi teze. No, srecno!! Edited November 10, 2014 by Buca_Tipo Quote Share this post Link to post Share on other sites
deki87 7 Posted November 10, 2014 Otvorite pa cete videti,glavu odradite obavezno,a su hilzne dobre onda samo nove karike eventualno leteci i lezeci i cepaj. Quote Share this post Link to post Share on other sites
MS PK 7718 Posted November 10, 2014 I eventualno ulje i obrada radilice, i set dihtunga i zupcastog i termostat i lamela? i eventualno jbg Quote Share this post Link to post Share on other sites
deki87 7 Posted November 10, 2014 De bre ti i buca ste pravi bukvalisti,mozda je samo glava problem,dok se ne skine nista... Quote Share this post Link to post Share on other sites
MS PK 7718 Posted November 10, 2014 To to, pa premere klipovi, pa hilzne..pa igranka pocinje Quote Share this post Link to post Share on other sites
Buca_Tipo 31 Posted November 10, 2014 Ma kad ga otvoris il ga radis ili ne. Ne bi se igrao na pola ako vec ostaje auto kod mene. Quote Share this post Link to post Share on other sites
deki87 7 Posted November 10, 2014 Znas vec kako to ide... Quote Share this post Link to post Share on other sites
branna 0 Posted November 10, 2014 Koliko otprilike kosta ova moja igranka ako radim motor najcrnji scenario i da kazem onaj manje crn scenario ako su hilzne ok. I koliko moze sa kosta drugi motor sa papirima. Quote Share this post Link to post Share on other sites
MS PK 7718 Posted November 10, 2014 Pa samo majstor je 150-200e.. Najcrnja 1000e i vise, prosecna nekih 600e otprilike. Drugi motor dosta jeftinije, da lupim 200-300e. Zovni neki otpad, servis. Quote Share this post Link to post Share on other sites
Branko 23 1 Posted November 10, 2014 Citam i glava i glava,sta ste zapeli,moze jos hiljadu uzrocnika da bude... Druze da se ti ne bi zaludeo ovde,a vidim da hoces,odvezi to kod malo boljeg fiat majstora i bice ti sve jasno Quote Share this post Link to post Share on other sites
deki87 7 Posted November 10, 2014 Racunaj majstora oko 150e+glava sa obradom ravnjanje,nove vodjice,nove gumice,novi ventili hidrotest od 150e-200e+novi dihtung oko 30e+ulje oko 35e+20e antifriz+karike set ne znam kolko je al nije ispod 100e i nadalje da se vidi oko radilicu sta je ali trebalo bi da bude ok,mada ako dobro palio zimi moguce da su karike ok ali kad se vec rastura valja i to da se odradi.Polovan motor sa domacim papirima ti treba klot jer sve imas do 300e. Quote Share this post Link to post Share on other sites
MS PK 7718 Posted November 10, 2014 Ko bre zapeo? Quote Share this post Link to post Share on other sites
Branko 23 1 Posted November 10, 2014 Otvorite pa cete videti,glavu odradite obavezno,a su hilzne dobre onda samo nove karike eventualno leteci i lezeci i cepaj.Nece na dizelu da pomogne,samo zamena karika,ne znam za takav slucaj.Ti bre,haahahhah ne zna ,ali samo vrtite,glava,glava :) xaaxax,predlozite coveku majstora i gotovo,resen problem najgore je nagadjati,a ne vidis kola,pa ti covek lose objasni i onda tako odes u desetu stranu... Quote Share this post Link to post Share on other sites
bojankov 36 Posted November 10, 2014 Ma ganjaj jtd i ubaci ako bude roknuo motor:-) Quote Share this post Link to post Share on other sites
MS PK 7718 Posted November 10, 2014 Ja je nisam ni spomenuo Quote Share this post Link to post Share on other sites
branna 0 Posted December 31, 2014 Prvo da pozelim svima uspesnu novu godinu. Puno zdravlja a ostalo ce se vec nekako resiti. A sada ono sto mene muci. Pomooooc! Gde da nadjem uljnu pumu za mareu 1.9 td100 98 godiste. Quote Share this post Link to post Share on other sites
branna 0 Posted December 31, 2014 A i karter mi treba posto je postojeci varen na cepu pa ga nije moguce odvrnutii ispustiti ulje. Quote Share this post Link to post Share on other sites
goche 0 Posted August 5, 2015 (edited) Pozdrav svima.... Na 1.9 TD motoru je uradjena generalna sve je ok vuce ko blesav pali na zub ne dimi uopste na auspuh,ali trosi ulje... Evo za predjenih 2000 km potrosi mi 1 litar ulja. Ponavljam znaci motor dobro vuce ne dimi na auspuh pali na zub ali trosi ulje,a nisam primetio da negde kapi ulje.Sta bi mogao biti problem?Skinuo sam creva od interkuleru i u njima je imao malo ulja.Probao sam turbina da liima luft na osovini i tu nema nikakva lufta pa svaki savet bi mi dobro dosao da znam sta jos da pogledam... Edited August 5, 2015 by neshaoct spojeno Quote Share this post Link to post Share on other sites
MS PK 7718 Posted August 5, 2015 Pa ako ne duva motor onda vuce turbina, nema trece Quote Share this post Link to post Share on other sites
goche 0 Posted August 6, 2015 Pa zar nema onda da dimi na auspuh?Ja sumljam na gumice ventila menjao sam tad ali nisam siguran u njihov kvalitet bile su jeftinije 400 din? Quote Share this post Link to post Share on other sites
deki87 7 Posted August 6, 2015 Moze da trosi ako su lose nastelovani ventili tj od prilike. Quote Share this post Link to post Share on other sites
MS PK 7718 Posted August 6, 2015 Pa mogo bi al ne bi ni iso i dimio bi i mozda trokirao...gumice su ti uvek jeftine koje god da stavis Quote Share this post Link to post Share on other sites
