bane000 108 Posted April 25, 2015 Na mojim felnama ET je 35. Quote Share this post Link to post Share on other sites
panther 0 Posted November 10, 2015 Pozdrav drugari, kupio sam felne za mog punta mk2.b (troje vrata), felne su sa sportinka za mk2.b, 6j et33. Trenutno su na njemu 185/55/15, e sad hocu da stavim 195/50/15 pa me zanima da li je to ok na ovu jotazu i et, razmisljao sam i o 185/65/15 (posto mi ih drug poklanja). Sta vi mislite. Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 10, 2015 Naravno da je ok, ja na 6J imam i 195/45 i 195/50 zimske... Quote Share this post Link to post Share on other sites
panther 0 Posted November 10, 2015 A sta mislis o ovim 185/65 Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 10, 2015 Ne znam, morace neko drugi, to je za moje poimanje previsoko... Quote Share this post Link to post Share on other sites
beli_Punto 123 Posted November 10, 2015 Mislim da će da češaju malo. Quote Share this post Link to post Share on other sites
panther 0 Posted November 10, 2015 Ok, hvala :-) Quote Share this post Link to post Share on other sites
Axic 19996 Posted November 10, 2015 A sta mislis o ovim 185/65Mozes i njih, kod mene su letnje gume u toj dimenziji 185/65 R14 i nista nigde ne cese. Quote Share this post Link to post Share on other sites
paun ts 1 Posted November 10, 2015 Za 185/60/15 sam siguran da mozes da montiras i da nece nigde da cese. Quote Share this post Link to post Share on other sites
gzezelj 0 Posted November 10, 2015 Imao sam jedno vreme 195 na istim 6J felnama. Meni to lično ružno izgleda na 6J felnama, preuska felna za tu širinu guma, na 6.5J još nekako, ali 6J je preusko. Meni su lepše blago strečovane gume 195 na 7J ili 7.5J Quote Share this post Link to post Share on other sites
paun ts 1 Posted November 10, 2015 Ali zato ET mora biti manji od 33 ili da se ubace distanceri. Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 10, 2015 Cekaj...aj sad, sporting/hgt felne su 6 ili 6.5J? Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 10, 2015 Aj rekoh cisto da proverim sebe...Znam o cemu pricas, ali ima dosta i do gume...recimo meni na GoodYear F1 195/45 nema onog stomaka od gume, kao na balonjarama, vec jednostavno sa ivice felne, guma pada potpuno ravno do asfalta...jednostavno i bukvalno kao i da je felna 6J (sto i jeste, jel da), ali bukvalno toliko sirinu ima i guma...kada se pogleda od nazad - sve stoji idealno. To je jednostavno do gume, dimenzije tj. profila i pritiska na koji se duva. Dok sa zimskim gumama ima mali stomak, pogotovo kada pogledas gumu kada je volan namotan, kada nije meni i to izgleda kako treba...bas cu slikati danas yokohame 195/50 nazad Quote Share this post Link to post Share on other sites
YUgisa 2528 Posted November 10, 2015 Ako guma ima onaj zastitni rub za felnu, onda lepse nalegne na uzu felnu, ako nema, onda izgleda malo balonasto deformisano, takodje bez obzira sto na gumi pise odredjena dimenzija, u praksi nisu uvek efektivne dimenzije jednake tj razlikuju se od napisanog. Quote Share this post Link to post Share on other sites
Milutinac 5906 Posted November 10, 2015 Evo ga...195/50 15 na fabričkim čelicnimMeni tu sve štima Kazem, 195/45 mi jos lepše stoje, drugacija guma potpuno, i kad je van felne donji deo taj gazeci i malo iznad njega onako kockastije deluje... Quote Share this post Link to post Share on other sites
gzezelj 0 Posted November 12, 2015 Evo recimo kako stoji na mojim 7J 195/45 R16 Quote Share this post Link to post Share on other sites
Srkii 3 Posted August 22, 2017 (edited) Koji profil zimskih guma staviti na alu felne 17 fabričke Grande punto 215 /40/ 17 ili 215/ 45 /17 ,trenutno su letnje 215/40/17 Hvala. Edited August 23, 2017 by neshaoct spojeno Quote Share this post Link to post Share on other sites
sasadoncic02 24 Posted August 22, 2017 215/40/17 da bi ti obim točka odgovarao po fabričkoj preporuci. Quote Share this post Link to post Share on other sites
Bingodalton 734 Posted August 22, 2017 Mozes slobodno i 215/45, meni su te letnje. Vagenovac fura 225/45 letnje. Taman nece da laze brzinomer Quote Share this post Link to post Share on other sites
Srkii 3 Posted August 22, 2017 Ove letnje lepo izgledaju sa dimenzijom 215/40/17 pitam iz razloga da 45 ne budu visoke znaš ono mada nije neka velika razlika pa tako nešto mislim Quote Share this post Link to post Share on other sites
Bingodalton 734 Posted August 22, 2017 Slikacu moje pa ces videti. Malcice su samo bucmastije. Evo jedne. 1 neshaoct reacted to this Quote Share this post Link to post Share on other sites
Srkii 3 Posted August 22, 2017 Pa kažem nije neka velika razlika u visini ,videću još koje ću uzeti Quote Share this post Link to post Share on other sites
