vicent 1261 Posted April 27, 2015 Kažu da na Stilu kat. ne vredi baš puno,zbog keramike u njemu,tipa 25-30eur. Ja za Puntov dobio cevku i 50eur. Ne znam kakav je ovaj na Stilu 59kw. Možda je isti kao Puntov. Po broju se zna sve! Quote Share this post Link to post Share on other sites
Marko Topola 45 Posted April 27, 2015 Ja sam pitao ove sto otkupljuju, za moj kat sa lybre 81kw daju 170e. 46803232 sifra kat. Quote Share this post Link to post Share on other sites
vicent 1261 Posted April 27, 2015 Pa šta čekaš,to veliki servis? Quote Share this post Link to post Share on other sites
Marko Topola 45 Posted April 27, 2015 Cekam sredu da majstor zavrsi neki auto. Rekao mi da kupim cev, samo ne znam koji precnik cevi? Taman cu i egr da blokiram, sutra stizu plocice... i map da ocistim, kao i interkuler... malo da prodise auto.. Quote Share this post Link to post Share on other sites
MS PK 7718 Posted April 28, 2015 Pa legni i izmeri f cevi. Quote Share this post Link to post Share on other sites
vicent 1261 Posted April 28, 2015 Mislim da je cev 52mm. Idi kod nekog krštenog auspuh majstora, nemoj da ti vari cev, nek je proširi s obe strane i lepo je umetneš na postojeću. Najbolje da stavi šelne. Quote Share this post Link to post Share on other sites
dellas 1555 Posted April 28, 2015 Da li mora da se iskljuci egr softverski ili je dovoljno staviti plocicu? Ovih dana skidam katalizatore pa bih uradio i to. Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted April 28, 2015 Koji auto?Obican jtd moze samo sa plocicim a jtd 16v (mjet) mora i softverski. Obicno edc15 ne moraju softverski dok edc16 mora. Quote Share this post Link to post Share on other sites
asterix 7 Posted April 28, 2015 A muti jet 120 KS? Quote Share this post Link to post Share on other sites
Dusan 4 Posted April 28, 2015 Mora softverski. Quote Share this post Link to post Share on other sites
dellas 1555 Posted April 28, 2015 530d e 39, mislim da on ima edc15 komp. Quote Share this post Link to post Share on other sites
deki87 7 Posted April 28, 2015 Ne treba kod njega. Quote Share this post Link to post Share on other sites
Kuvalja 406 Posted April 28, 2015 Mislim da kod tebe moze samo plocica, uostalom, stavis pa vidis, necea nista sjebati, gresku posle samo obrises ako prijavi.@asterix, kao sto Dusan rece kod tebe mora softversko gasenje tvoj ecu je edc16c39 Quote Share this post Link to post Share on other sites
Stilisa 312 Posted April 29, 2015 Samo da se zahvalim kolegi Marku na plocicama. Ko iz fabrike. Sad ce Lakijev GP da leti. Quote Share this post Link to post Share on other sites
Marko Topola 45 Posted April 29, 2015 A moja Lybra? Quote Share this post Link to post Share on other sites
Markobgd 609 Posted May 1, 2015 Nema na čemu, tu smo da se pomognemo... Quote Share this post Link to post Share on other sites
rikard0204 0 Posted May 26, 2015 (edited) Ocigledno se nije oglasio ni jedan vozac Fiata/Lancie/Alfe sa motorom 2.4TD... Kod ovog motora gotovo da nije moguce iskljuciti EGR jer ECU odmah preko meraca mase vazduha prepozna izostalu funkciju i ometa normalan rad sistema za ubrizgavanje goriva. Auto sa ne ispravnim ili blokiranim EGR-om nakon (na kratko) ustaljenog gasa vise nece da ubrzava, vec trazi vracanje na obrtaje ler gasa i tako u krug... Kod JTD sistema nema takvih problema, a kolega Vukajlo je tacno napisao funkciju EGR-a. Posto mi je stuka ubrizgavanje kod dizel motora, moram se sloziti sa vecinom kolega da je gorivo koje se kod nas prodaje ne zadovoljavajuceg kvaliteta, i da se u usisnim kanalima javljaju vece kolicine naslaga garezi nego sto je predvidjeno.Evo jednog korisnog saveta kako smanjiti funkciju EGR-a, a ne zatvoriti ga potpuno:Jednostavno, napravite zaptivku od lima (debljine oko 1mm) po uzoru na limenu zaptivku gde se cev EGR-a spaja sa usisnom granom. Zatim, na sredini probusite rupu 3-4mm i postavite taj lim na mesto fabricke zaptivke. Na ovaj nacin niste potpuno iskljucili EGR, ali ste znatno smanjili dotok izduvnih gasova u usisni sistem. Napominjem da ce opet biti potrebno s vremena na vreme ocistiti sam ventil od garezi.Konacno, na ovom forumu pronadjoh resenje mog problema sa fiat mareom 2.4 td 98 godiste kod koje je zatvoren EGR ventil pokusacu ovih dana da ga osposobim i otvorim ili da pokusam da na zaptivki probusim manju rupu pa javljam rezultate eksperimenta. Tacno se tako ponasa kao u postu forumasa bosim posle konstantne voznje nece da ubrzava kako treba kao da je ugusena kad pustim pedalu gasa i vratim obrtaje na ler ponovo vuce kao blesava nampominjem da nema nikakvog dima ni prilikom paljenja ni prilikom voznje pozdrav. slazem se sa gospodinom "bosim" da kod kappe i maree se nemoze iskluciti egr samo mehanicki. imam kapu 2,4 td i bio sam kod bosh majstora i rekao mi je da je problem kod tih motora da se egr mora iskljuciti i softwerski. svaki elektronicar koji radi nekakav tuning ili remap moze vam to napraviti.(tako su bar meni rekli) za nekakvih tjedan dana idem kod auto elektronicara pa vam javim kako je proslo. cijena toga kod mene u hr je 600kn tj oko 80eur cca. da se nebi krivo shvatili potrebno je i mehanicki i softwerski onesposobit egr. zaboravio sam reci da imam iste simptope kao gospodin sa mareom. auto vuce super i odjednom ostane bez turba i trazi vracanje obrtaja pritiskom kvacila na par sekundi i onda opet vuce. Edited May 26, 2015 by rikard0204 Quote Share this post Link to post Share on other sites
steel 21 Posted May 26, 2015 Kod mene je na stilu Jtd 115ks 2005 godiste izbacio gresku na egr ventilu nakon zatvaranja Quote Share this post Link to post Share on other sites
deki87 7 Posted May 26, 2015 Na svakom jtd 59kw-85kw izbacuje ali ne pravi problem. Quote Share this post Link to post Share on other sites
joshibeast 74 Posted May 26, 2015 Izbacuje grešku u računaru ali ne na tabli.I na običnim JTD-ovima se može softverski ugasiti.Kolega Igor mi je to objašnjavao. Quote Share this post Link to post Share on other sites
steel 21 Posted May 26, 2015 Meni je izbacio gresku na tabli i na kompjuteru Quote Share this post Link to post Share on other sites
joshibeast 74 Posted May 26, 2015 Koliko od zatvaranja do greške si prešao?Ja sam oko 1500 i još uvek ništa. Quote Share this post Link to post Share on other sites
igor0511 2821 Posted May 26, 2015 Meni na svaka 3-4 meseca izbaci grešku jer egr nije čišćen od zatvaranja.Samo registruje da je prljav. Eko neko želi da softverski zatvori mapu na jtd-u uradiću mu ja. Naravno džabe Quote Share this post Link to post Share on other sites
steel 21 Posted May 26, 2015 Presao sam nekih 300-500 km Quote Share this post Link to post Share on other sites
